2-dimensional barcodes
  • Hondaman
    • Sep 2008
    • 1089
    Every autumn/Christmas, I find myself wanting to create some barcodes for use at my workplace. I don't have access or authority to use any software at work for this purpose, so I must rely on "home-built" solutions. These barcodes will be printed out and be laminated on a lanyard around my neck.
    I would like barcodes that can be easily resized, so I can find the size that works best for the laser barcode readers that we have.
    I would rather have software (and the final barcode files) here on my local machine (no web-based software, and no proprietary formats if possible). The barcodes I will create could range from, I don't know, 16-20 "squares" on both X and Y axis to 32 or maybe more, and probably be around, oh, I don't know, 20-23 millimeters in each dimension (maybe larger for more complex barcodes).
    I thought about Inkscape for Windows/Linux; I toyed around with it briefly in 2005, but now it seems full-featured, quite complex and better suited to photo editing.
    I suppose the interface would have a "grid". Kind of like working with the gridlines on a 8.5 by 11 inch sheet of paper in a desktop publishing program, but these gridlines would only be for what amounts to a 16 by 16 or a 32 by 32 piece of clipart, basically (the user can choose the exact size beforehand). I could click with a mouse to turn each square white or black, then save the file. That's all I need.
    Is this the best way to accomplish this task? I don't need a huge, full-blown piece of software to create one or two barcodes......
    Any advice would be greatly appreciated !
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: 2-dimensional barcodes
    [stuff elided]
    Originally posted by Hondaman
    Every autumn/Christmas, I find myself wanting to create some barcodes for use at my workplace. These barcodes will be printed out and be laminated on a lanyard around my neck.
    I suppose the interface would have a "grid". I could click with a mouse to turn each square white or black, then save the file. That's all I need.
    Assume you can create a grid "template" that just needs "squares" that are white or black (that may not be possible, depending on the code you are using), you could create a bunch of adjoining squares/rectangles in something as crude as MSPaint, choosing "black" or "white" for the fill color of each square that you draw.
    MSPaint sucks in that it forgets the objects you've created as soon as you've created them (e.g., it "flattens" the drawing after each operation). So, a better tool would be something that treats the squares as individual objects that you can LATER alter (select object, pick new color, lather, rinse, repeat)
    Something like Illustrator, CorelDRAW/PAINT, etc.
    But, this leaves you with the responsibility of creating the individual "squares" having the correct dimensions relative to the symbol as a whole.
    An easier solution is just to find one of the many barcode generating tools, specify the barcode of interest and then just type the desired text -- letting the tool create the symbol at whatever size you require.
      • 31254
      there is lots of software to print barcodes.
      • Huscarl17
        • Apr 2018
        • 8
        A free barcode generator
        https://www.barcoding.com/resources/barcode-generator/
        It's at the bottom of the page.
        I use it to correct UPC's on gaming products and hang tags for product in our hobby shop.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          He said no web based software
          • gg1978
            • Dec 2004
            • 431
            I recall there being a command line 2d barcode generator, although the name of it i am drawing a blank on at the moment. Just found it, it's qrencode from linux..
            https://fukuchi.org/works/qrencode/
            • harp
              please help with complex dmm connector
              by harp
              Maybe now he decide to post... This forum is become so unreliable... I hope you see the attachment... So, I have newer cheap 830 dmm, and I am not happy with beeping mode. Its output is from IC directly, so he wont beep unless the diggit become too low. I want to beep function is thrully analog, like the old one, and think to atempt modification with insert beeping circuit. But, I dont know principle of reading such complex connector, so please if you can draving with red lines path that exist in beep mode... it will help me a lot....
              06-15-2025, 07:04 AM
            • Bloopeta
              Samsung QE55Q7CAM scrambled picture / squares
              by Bloopeta
              Quick question please, not much info or pics to go on unfortunately as its not my TV, and I dont have it infront of me, but was wondering if anyone has come across this before, and what the problem possibly could be?
              Samsung QE55Q7CAM
              Owner states after the tv has been on standby for a long period of time, when switched on, it displays scrambled/blocked image as pictured.
              If one connect cable is disconnected and reconnected or power turned off at the main socket it will work fine with no problems until its been left on standby again for a long time.
              09-02-2023, 03:23 PM
            • IamPritesh
              Complex Backlight Issue. Please advise Asus DA0BKXMB8D0
              by IamPritesh
              So I have this Asus TUF laptop ( BOARD ID : DA0BKXMB8D0 ) which has no backlight. tested this with multiple screens and each has different result.
              Original Screen ( FULL HD ) :
              Has Data
              No Backlight
              0V on EDP connector Pin 39,40
              Backlight Enable has 3.3V
              TEST Screen 1 (ONLY HD)
              No data
              No Backlight
              8V on EDP connector Pin 39,40
              TEST Screen 2 (ONLY HD)
              No data
              No Backlight
              5V on EDP connector Pin 39,40
              LDVS CONNECTED TO MB BUT NOT TO LED SCREEN ...
              02-16-2022, 06:58 AM
            • wattage
              by wattage
              Hello Badcaps Community,
              07-13-2025, 04:41 PM
            • hemant_2222
              Yamaha RX-A1020 full dead
              by hemant_2222
              Hello Everyone,
              Greetings!
              It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and...
              09-14-2024, 11:25 AM
