Yamaha RX-A1020 full dead
  • hemant_2222
    Hemant
    • Jul 2015
    • 71
    • India
    Hello Everyone,
    Greetings!
    It has been very long time that I opened up my garage again because I got something that I could not stop myself and this time I have a Yamaha RX-A1020 super powerful (at least from inside structure 😉 ) AV receiver. When this unit came to me this Saturday it was full of dust and what not but the standby LED blinked when pressed and power relay clicked once but no display. It worked 3 times after normal reset like other Yamaha receivers and then again it had to be unplugged to get his behavior back. I opened everything and cleaned it up and re-assembled it again ( I checked the output transistor and the related section but it seemed to be fine, no shorts ) and it came back to the same state as before. After some more attempts of reset I think I damaged some thing big 😩. Now there is no led blink and nothing.
    The power supply where it supplies +5 V and the GND to the digital PCB, is now shorted. I have dismantled the digital board out of the amplifier but it is still the same. I know VCC and GND shorts are too complex to resolve and requires great deal of patience to look into, BUT believing the members of this super forum, I am requesting your assistance in getting moved on.
    If anyone could PLEASE guide me, where to being with I would appreciate that. This is the first time that I have opened up this complex looking receiver and I look forward for your help.
    The schematic is here: https://elektrotanya.com/yamaha_rx-a.../download.html
    If you need any more details, please let me know. I can provide more inputs as I can.
    Thank you so much for reading this post.
    Regards,
    Hemant
  • roadrash
    Yamaha HTA-5630RDS Amplifier dead
    by roadrash
    Belongs to my son and he just says it stopped turning on. Any help greatly appreciated. Theres 240v in and fuse is ok but no power anywhere else.
    12-12-2024, 10:19 AM
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • disorder
    ps5 edm-033 dead after hdmi/usb ports destroyed
    by disorder
    hello guys,
    i need help to repair a edm-033 ps2
    history : as always hdmi port and usb ports destroyed after unplugged
    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
    so i changed it
    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
    i don't see any projection of liquid metal on pcb.
    01-14-2025, 12:48 PM
  • sanalelevenstar
    Yamaha RX-V485 Wn9711 Update
    by sanalelevenstar
    Help Needed: Yamaha RX-V485 Network Issue After Firmware Update (WN9711 Error)
    I'm facing an issue with my Yamaha RX-V485 receiver. During a firmware update, the process failed, and now the USB, Bluetooth, and network functionalities are not working. Occasionally, the receiver displays the error code WN9711.
    I came across Yamaha Technical Bulletin No. 0103, which describes a similar issue for models like the RX-V4A, RX-V6A, and RX-A2A. According to the bulletin, the issue can be resolved by shorting soldering points (e.g., J260 for RX-V4A or...
    12-04-2024, 04:32 AM
  • zunasthegreat
    Chieftec GPS-450-AA with dead 20N60C3
    by zunasthegreat
    Hello everyone hope all doing well!
    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
    09-01-2024, 07:12 PM
