Complex Backlight Issue. Please advise Asus DA0BKXMB8D0
  • IamPritesh
    • Aug 2017
    • 356
    • India
    So I have this Asus TUF laptop ( BOARD ID : DA0BKXMB8D0 ) which has no backlight. tested this with multiple screens and each has different result.
    Original Screen ( FULL HD ) :
    Has Data
    No Backlight
    0V on EDP connector Pin 39,40
    Backlight Enable has 3.3V
    TEST Screen 1 (ONLY HD)
    No data
    No Backlight
    8V on EDP connector Pin 39,40
    TEST Screen 2 (ONLY HD)
    No data
    No Backlight
    5V on EDP connector Pin 39,40
    LDVS CONNECTED TO MB BUT NOT TO LED SCREEN
    19V on EDP connector Pin 39,40 and also on the display cable ( So probably not a cable issue I think )
    Attaching schematic .Would love to know what exactly is causing the drop in 19V Vin that is connected to the LDVS .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Complex Backlight Issue. Please advise Asus DA0BKXMB8D0
    Display cable is likely burnt.
    • IamPritesh
      • Aug 2017
      • 356
      • India
      If I dont connnect the led screen I get full 19V on the both the ends of display cable.
      • mon2
        • 14792
        Does the original screen work on another logic board?
        You can see the text / graphics with a flashlight?
        Remove all power. Meter in resistance mode. Check the resistance to ground for the lcd pin 39,40.
        Then check the same in diode mode. Meter in diode mode, red probe to ground. Black probe to pin 39,40.
        Post the readings.
        • piernov
          • Jan 2016
          • 4439
          • France
          Of course fuse is good…?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            This doesnt proves cable is not bad.
            • IamPritesh
              • Aug 2017
              • 356
              • India
              Post the readings.
              This doesn't proves cable is not bad.
              The original screen was bad and only specific screen works on this asus machine. Something to do with the panel_id signal maybe ?
              The machine is no more with me. Since I could not source the new compatible screen, had no choice but to return the laptop.
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • shahnld
                Lenovo legion 5 pro startup issue
                by shahnld
                Good day Experts
                I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                08-24-2025, 12:31 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
