best cheap/free scores 1.1
This is a sticky topic.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    #621
    Re: best cheap/free scores 1.1
    Well then I wouldn't have a clue what version of the driver you have.
    -David VanHorn
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Should be pretty recent, an update for it came about a week ago.
      sigpic
      (Insert witty quote here)
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        #623
        Re: Your Best Dumpster Finds
        Update on the microwave:
        The good news is - it works! I tried heating a cup of water in it, and in just 20 seconds it got really hot.
        The bad news: the back where the rust is also gets very hot :| . Also, as soon as the microwave inverter kicks in, you can hear all of the fans slowing down and the inside light dim a lot. I think the rust on the back is definitely shorting it.
        The really bad news: I tried cleaning the microwave and unfortunately, the metal on the back has indeed rusted all the way through . As I was cleaning it with my putty knife (since the paint really was pealing in big chunks), I accidentally tore a few holes right at the bend on the back. So yeah - a new back is needed for sure. The whole thing is soft when I press it with my finger. I think I'll just cut the whole back out and screw a new one in there if that's possible.
        The bottom piece has started to rust quite a bit near the edges too, though. I hope that doesn't have any areas that are rusted all the way through because that will make the repair much harder.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #624
          I would try to save it
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16959
            I found one of those 70's-ish Amana 'Radaranges' in the garbage many years ago....that thing would nuke your food to the glowing point, powerful bastards! I used it for ages and ended up giving it away. It had a bad door switch when I found it. 30 cents fixed it.
            <--- Badcaps.net Founder
            Badcaps.net Services:
            Motherboard Repair Services
            http://folding.stanford.edu/
            Team : 49813
            Join in!!
            Team Stats
            • larrymoencurly
              • Oct 2004
              • 960
              I once found an ancient convection/microwave oven with all-mechanical controls. Convection/microwave ovens aren't cheap. The convection blower fan bearing had seized, and it was hard to find a new one because it had to take the full heat, being mounted downstream (dumb design).
              I've managed to retrieve 7-8 IBM keyboards in various condition, enough to make 4 complete 101-key model M keyboards.
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #627
                Originally posted by Topcat
                30 cents fixed it.
                So that's probably like $10 in today's money .
                Nice find. IIRC, those "Radarange" microwaves were some of the first ones available to the public.
                Old keyboard like that are very nice for typing. I've heard some people argue that the newer "flat" keyboards are better for your hands. If anything, my hands are real tired right now from this flat laptop keyboard.
                I prefer the Dell QuietKey ones - perfect standard layout (i.e. no large Enter key and small Backspace key) and the Space bar never jams, even after washing the keyboard (after taking it apart, of course). Can't say the same about newer keyboards.
                • mariushm
                  • May 2011
                  • 3799
                  #628
                  The old ones are bad because of the click and the sudden stop at the end, it hurts your fingers long term.
                  The flat ones are bad because they have no feel, can't tell where the trigger is so without realizing you have to press much harder than normal just to get the audible feedback.
                  I personally find the feeling of the Microsoft ComfortCurve 2000 keyboard the best... soft buttons, short distance and keys in a slight curve which helps against RSI.. But i realize it's a matter of personal taste.
                  for reference it looks like this:
                  • ben7
                    Capaholic
                    • Jan 2011
                    • 4059
                    You are right, the new ones are just like snap-on and snap-off, after you apply a certain force, they just give-way and go down all the way, making noise...
                    I have used those Microsoft keyboards before, they are great!
                    Muh-soggy-knee
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      I found a Logitech Quickcam for Notebook Pro for $5 today. Other than a ripped Logitech cable tag it was in great shape (included the carry case).
                      Finally I can relocate my Quickcam Communicate STX to the main rig where it belongs.
                      sigpic
                      • Rulycat
                        • Apr 2010
                        • 724
                        • United Kingdom
                        #631
                        Derailing other people's threads again but run glxinfo and see what mesa version you're using. Latest is 8.0.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Code:
                          OpenGL vendor string: X.Org R300 Project
                          OpenGL renderer string: Gallium 0.4 on ATI R350
                          OpenGL version string: 2.1 Mesa 8.0.3
                          OpenGL shading language version string: 1.20
                          other note- under the shell performance is good but there are a lot of glitches... like it bluing out my wallpaper, not accepting mouse clicks, random self-clicking, etc. Annoying as hell and virtually unusable w/o hitting alt+F2 and entering a command.
                          On my 5200fx card it had the usual bugs currently reported for that card under nouveau (prop. legacy drivers are no longer xorg compatible). Performance was also fine.
                          sigpic
                          • tiggerific
                            • Apr 2008
                            • 21
                            #633
                            Went to the friendly neighboorhood dump to drop off batteries for recycling, spotted a 46" Sony LCD box in the electronics area which actually contained what it said on the outside! Model KDL-46EX400 in a bit dusty but otherwise pristine condition. August 2010 manu date. Must have been upgraded to something better. I'll have to get around to popping the back off to check the PSU caps but for now it's going to go up in the guest room.
                            It's the third 40"+ LCD TV I've picked up there that either works 100% or had a couple blown caps.
                            Also picked up a couple laptops 3 months ago which worked fine, good batteries and power adapters.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              #634
                              Got a Westinghouse 26" LCD monitor for $10. Tested it at the guy's house and it would blink the backlights for fraction of a second (so not quite "2-seconds-to-black"). Got it home, tried it, and it works?
                              Granted it does squeal very loudly. Quick check leads me to believe it's not inverter or PSU (PSU has Chemicon KY all-over).
                              Another LCD project with backlight issue. I'm sick of them. I rather get ones with bad t-con or PSU (not caps).
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Resolder the inverter transformers. May also be a transistor issue.
                                sigpic
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #636
                                  Got a small APC UPS today from the trash can at my former job. Haven't cracked it open yet. Was told it doesn't work. Don't know if I'll fix it or not cause I don't keep anything on a UPS and I don't like to. (If power goes out, power goes out. I don't give a shit, I think I can live without my electronics for a few hours/days).
                                  The inverter joints look good (well, as good as lead-free joints get anyways ). Only 4 MOSFETs total driving all 6 transformers at once, so can't have any bad ones (there would be magic smoke if that was the case). It could well be that one of the traffos is out of spec. Now that I think about it, I forgot to check that.
                                  I still hate LCDs, though.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    IIRC the whole point of the UPS is to allow things to shutdown properly as opposed to a sudden reboot. Most are not meant for continuous use.
                                    sigpic
                                    • shovenose
                                      Send Doge Memes
                                      • Aug 2010
                                      • 6575
                                      Code:
                                      I have a solution to all of the issues you're having with your computer and your dual monitor setup.
                                      http://windows.microsoft.com/en-US/w...products/home/
                                      • ratdude747
                                        Black Sheep
                                        • Nov 2008
                                        • 17136
                                        If I am gonna spend as much money as 7 pro/ultimate copy would cost (has to be pro or ultimate, its twin CPU), I'd just get a really nice GPU.
                                        sigpic
                                        • Agent24
                                          I see dead caps
                                          • Oct 2007
                                          • 5095
                                          • New Zealand
                                          #640
                                          I'm not even sure that the Radeon 9000 series support Aero, so that could be even worse...
                                          -David VanHorn
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
