best cheap/free scores 1.1
This is a sticky topic.
Re: best cheap/free scores 1.1
Another box of 1T (Hitachi) drives. Look to all be around 11000 PoH with a dozen or so power cycles (no doubt they were sitting in a shelf running 24/7). Looks like they (whoever THEY are) happen to be on a ~15 month upgrade cycle.Comment
And... a box of 1T seacrates with the same ~11000 PoH stats. I need to figure out who is dumping these and see what other kit will be coming down the line!
(Now, I need to start finding boxes to store the damn drives)Comment
Scored this:
https://www.ebay.com/itm/142898676466
Lenovo Thinkcentre A70Z AIO. They say it has screen damage but other than a scratched up bezel, it all looks fine from here. $49 shipped, it will be a good replacement for the Polymac G5 in the kitchen (which is a bit anemic to say the least). Also uses a desktop 775 CPU (not a BGA or even a Socket P laptop chip) so if I want to go nuts with it, I can (at least to the extent that the lenovo whitelists will let me).sigpic
(Insert witty quote here)Comment
I've got some of the M90Z's, they're solid systems for an AiO. I use them in the garage & workrooms.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
sigpic
Got a freebie from the county today. Some cheapass flimsy case with an Allied 300w PSU, connected to a Gigabyte GA-G41M-ES2L with a Pentium dualcore @ 2.6, 2gb RAM, and a 250gb SATA seagate 7200.12 HDD. Working order, this post created from it. I wiped the drive as I promised I would, then threw W7 on it.
I'm sure the PSU needs to be recapped, they always do....and these are junk PSU's anyway....but the system seems stable.
Was also given 2x Cisco Aironet 1200 PoE access points.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Team : 49813
Join in!!
Team StatsComment
^ Ill take it over any of that flashy RGB crap anyday.....Last edited by goontron; 09-07-2018, 09:29 PM.Things I've fixed: anything from semis to crappy Chinese $2 radios, and now an IoT Dildo....
Follow the white rabbit.Comment
Was also given 2x Cisco Aironet 1200 PoE access points.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Scored this:
Came in today... runs fine. Memtest 86+'d w/o errors... no screen issues... it's a bit rough in the front, but damn... Installing 7 on it now. Other than being limited to intel graphics, I could go places with it. It has a wimpy E7500 CPU and a measly 4GB of 1066 DDR3, both of which are upgradeable. Hmm...
Otherwise, no issues.sigpic
Team : 49813
Join in!!
Team StatsComment
https://forums.lenovo.com/t5/ThinkCe...s/td-p/1863224
Whatever it is, it's not just me. I may try ripping the HDD out of my main laptop and booting the arch install off of that... although for a system I'm not personally using, I'd rather not arch it (just asking for trouble).
Wifey almost made a cheap score: NOS APC Smart UPS 750 for "less than $5". Great, except the batteries are beyond dead17 years young! I was honestly looking more for a rackmount one anyway...
Why would it not be an excellent score? Batteries have a lifetime of 3 to 5 years."The one who says it cannot be done should never interrupt the one who is doing it."Comment
It uses regular 7.2AH 12v batteries, they don't cost much.
And they are consumables anyway."The one who says it cannot be done should never interrupt the one who is doing it."Comment
by H34TORecently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...06-17-2025, 07:17 AM
by evilkittyMy Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...-
by aaronkatriniHi all,
- Autorange
- DC volts up to 30V
- Accurate Resistance
- Diode test (Beep mode)
- Frequency up to 200MHz
- Capacitanze up to 5000uF
- as cheap as possible
Other functions are not needed but those which are needed... -
by Dan81Just as the title states. Two cheap SiS machines, surprisingly stable.
What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
CPU - P3 1100MHz Coppermine...-
by eccerr0r"Caseless Cheap Chinese electronic tools" I mean things you get from banggood, ali, fleabay, Am-Zon, etc. like AVR-Transistortester, miscellaneous signal generators, frequency counters, (variable) power supplies, oscilloscopes, low resistance meters, etc., etc. that comes optionally with a case, or comes only with a cheap piece of plastic that barely provides protection to the PCB.
Just wondering what of these (generally flimsy) tools you actually find use (almost) everyday and find indispensable for the price, compared to buying a Fluke or whatnot, if there is an expensive... - Loading...
