AMD wins!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: AMD wins!
    Originally posted by stj
    and amd k6-2 chips were great.
    Albeit my K6-2 450 sometimes suffered random errors at stock! Now, I think it was most likely the higher temps. And it's not typical to get errors, despite high temps, when stock!
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Re: AMD wins!
      my cyrix systems were fine,
      there was an old rule - not cpu specific.
      the rule was: avoid pc-chips and other "cheap" chipsets like the plague!!
      i remember they had lots of issues if you tried to use the then-new pci slots for example.
      You must have had the unicorn-powered ones then. I had horrible luck with CPU's of that era that weren't Intel.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • lti
        • May 2011
        • 2557
        Re: AMD wins!
        My K6-2/500 on an Asus P5A motherboard was slower than a 333MHz Pentium II in most applications, but it was stable. That was the first computer I had that didn't crash.
        I also had a Cyrix MII-333 (the weird 83MHz bus version). It was equivalent to a 200MHz Pentium MMX in everything I tried to run on it, but it was also stable on a decent motherboard.
          • 31201
          Re: AMD wins!
          i still have the K6-2, it ran for over a decade 24/7 before i retired it.
          100MHz bus using sdram and a FIC VA503 mobo.
          just dont use the usb ports - usb1.0 was bugged, intel fucked the design spec. (intel again!!)
          • Dan81
            SNES-powered
            • Oct 2013
            • 1866
            • Romania
            Re: AMD wins!
            K6-2 was still useable last time I checked.
            I think I still have a SS7 machine, although mine has a Pentium MMX 233, 256MB of RAM and a 4.3GB HDD.
            Didn't use the onboard USB either, as I opted for a NEC-chipset based PCI USB2.0 card.
            GPU is a 3dfx Voodoo 3 3000 AGP.
            Main rig:
            Gigabyte B75M-D3H
            Core i5-3470 3.60GHz
            16GB DDR3-1600
            Samsung SH-224AB DVD-RW
            Delux MG760 case
            • Stefan Payne
              • 1267
              Re: AMD wins!
              Originally posted by mariushm
              They called it Zombieload
              hm...
              https://en.wikipedia.org/wiki/Zombie_Land_Saga
              • Stefan Payne
                • 1267
                Re: AMD wins!
                With Reliability or in general?
                The Problem with K6(-2) was the shitty aluminium heat spreader and also the tooth paste between die and Lid.
                Yes, AMD introduced Heatspreader and not soldering the Heatspreader (they then did that with the K8)...
                €dit:
                here some pictures of that:
                https://www.overclock.net/forum/10-a...d-amd-cpu.html
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: AMD wins!
                  €dit:
                  That reminds me of Ivy Bridge, LOL.
                  Arc A770 16 GB
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Re: AMD wins!
                    Still have a AMD K6-233 in a Intel chipset motherboard. The machine would actually be stable except I deliberately put in the worst ram I have (it has flaky cells).
                    It only runs SDRAM at PC-66 speeds, and since I don't really need the computer, it got the bad 256MB PC133 stick. Compound the fact the L2 is disabled with "that much" RAM in the machine...
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16958
                      Re: AMD wins!
                      €dit:
                      More in terms of reliability. The Pentium2 kicked the creamcheese out of the K6-2. I actually have a K6-3 450MHz chip around here somewhere, it was a turd too, but better than the 2...but its kind of unusual, so I didn't junk it.
                      Team : 49813
                      Join in!!
                      Team Stats
                      • lti
                        • May 2011
                        • 2557
                        Re: AMD wins!
                        I still have everything I mentioned except the P5A. I now have a second K6-2/500 in a Compaq with an SiS 5598 chipset. It's even slower (mostly because of the early chipset integrated graphics), but it runs okay. USB 1.0 even works.
                          • 31201
                          Re: AMD wins!
                          my spec was:
                          FIC va503a mobo
                          512MB of pc133 ram
                          AGP nvidia TNT graphics, later upgraded to G-FORCE4
                          pci soundblaster card.
                          pci scsi card
                          pci network card (realtek)
                          it was fucking fast - probably because of the scsi card.
                            • 31201
                            Re: AMD wins!
                            watched that - it was really funny.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Re: AMD wins!
                              Still better then L1 being disabled, AFAIK. Disabling L1 would make even DOS slow, LOL.
                              Arc A770 16 GB
                              • ivtec
                                • Dec 2008
                                • 1967
                                Re: AMD wins!
                                I still have 2 desktop Lenovo sandy-bridge mother boards cpu=Intel+Core+i5-2400 3.10GHz
                                and 2 Hp laptops one DV5 and other DV6 Intel duo core 2.ghz and a older Laptop AMD Celeron CQ60 and Sony vaio XP Pentium M 1.5ghz for what i do no complains. i'm old school and cheap never had new Tech and will die without the top of the line hardware.Oh i forgot my Emachines Desktop EL1330 AMD Athlon(tm) II X2 250u Processor
                                • sigmeyer
                                  Toshiba 50UL4B63DG faulty screen?
                                  by sigmeyer
                                  I got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
                                  08-30-2025, 08:13 AM
                                • Behemot
                                  Need Catalyst 15.6 for Win 7 x86-64
                                  by Behemot
                                  Anybody has? I don't even have the strength to whine about how EVERYBODY on the whole fucking planet is so dumb to only REPEAT link to frelling AMD site WHICH CEASES TO EXIST after few months instead of HAVING the stinking file to download FROM THEIR OWN SERVER, for fucks sake. Would laugh if it did not make me cry So after quite intensive search, this thing seems to be impossible to find. For the record - 15.7.1 is totaly fucked up for DXVA, 15.6 is latest reported working one.
                                  This is actually quite interesting that AMD always FUCKS UP some driver line, usually...
                                  02-10-2019, 06:56 AM
                                • surfer349
                                  LG Gram 13 Battery not charging, USB-C nor DC plug
                                  by surfer349
                                  Looking for advice.
                                  https://www.amazon.com/gp/product/B078WRN1S8/
                                  I have this LG Gram 13, from 2020. Recently, it seems that the battery simply won't charge. It's drained down to 0%, and will now only turn on when plugged in, either through USB-C or the DC charger plug.
                                  I've opened the back to look for anything obvious but it all looks fine. I tested the voltage on the DC charger and its all fine.
                                  What next? Is it possible the battery is fucked? I've read there are control circuits on the battery itself that regulates charging. Can that...
                                  10-03-2023, 09:42 AM
                                • CapLeaker
                                  Astron RS-7A/10A not regulating output voltage low
                                  by CapLeaker
                                  Either I am getting old or dumb, probably both.
                                  This “simple” linear power supply is driving me insane. Should be easy, right?
                                  Here is the story. Got that Astron RS-7A or 10A as stone dead. I mean turned on and got 0.00V not even an mV on the output. Why dat? Darn electrolytic output capacitor shorted at the binding posts. No, problem… new one in stock and mounted.
                                  Turned the PSU on again and now I got 0.1V on the binding posts. Everything clear like sunny day and replaced the LM723 regulator IC in the socket. Had it made, I thought....
                                  09-17-2023, 08:33 PM
                                • jesi
                                  need help with hp laptop 16867-1
                                  by jesi
                                  hi there
                                  no sound on this crap laptop giving me headaches
                                  mb 16867-1 nba_rockets_mb 448.0by04.0011
                                  need schematic and alc1305h ic i think
                                  many thanks
                                  03-25-2019, 07:17 AM
