AMD wins!
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
Re: AMD wins!
You must have had the unicorn-powered ones then. I had horrible luck with CPU's of that era that weren't Intel.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
Re: AMD wins!
My K6-2/500 on an Asus P5A motherboard was slower than a 333MHz Pentium II in most applications, but it was stable. That was the first computer I had that didn't crash.
I also had a Cyrix MII-333 (the weird 83MHz bus version). It was equivalent to a 200MHz Pentium MMX in everything I tried to run on it, but it was also stable on a decent motherboard.Comment
Re: AMD wins!
K6-2 was still useable last time I checked.
I think I still have a SS7 machine, although mine has a Pentium MMX 233, 256MB of RAM and a 4.3GB HDD.
Didn't use the onboard USB either, as I opted for a NEC-chipset based PCI USB2.0 card.
GPU is a 3dfx Voodoo 3 3000 AGP.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Re: AMD wins!
The Problem with K6(-2) was the shitty aluminium heat spreader and also the tooth paste between die and Lid.
Yes, AMD introduced Heatspreader and not soldering the Heatspreader (they then did that with the K8)...
€dit:
here some pictures of that:
https://www.overclock.net/forum/10-a...d-amd-cpu.htmlLast edited by Stefan Payne; 05-18-2019, 07:01 AM.Comment
Re: AMD wins!
With Reliability or in general?
€dit:
https://www.overclock.net/forum/10-a...d-amd-cpu.htmlASRock B550 PG Velocita
Arc A770 16 GB
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
Re: AMD wins!
Still have a AMD K6-233 in a Intel chipset motherboard. The machine would actually be stable except I deliberately put in the worst ram I have (it has flaky cells).
It only runs SDRAM at PC-66 speeds, and since I don't really need the computer, it got the bad 256MB PC133 stick. Compound the fact the L2 is disabled with "that much" RAM in the machine...Comment
Re: AMD wins!
€dit:
https://www.overclock.net/forum/10-a...d-amd-cpu.html<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Re: AMD wins!
I still have everything I mentioned except the P5A. I now have a second K6-2/500 in a Compaq with an SiS 5598 chipset. It's even slower (mostly because of the early chipset integrated graphics), but it runs okay. USB 1.0 even works.Comment
Re: AMD wins!
Re: AMD wins!
It only runs SDRAM at PC-66 speeds, and since I don't really need the computer, it got the bad 256MB PC133 stick. Compound the fact the L2 is disabled with "that much" RAM in the machine...ASRock B550 PG Velocita
Arc A770 16 GB
Re: AMD wins!
I still have 2 desktop Lenovo sandy-bridge mother boards cpu=Intel+Core+i5-2400 3.10GHz
and 2 Hp laptops one DV5 and other DV6 Intel duo core 2.ghz and a older Laptop AMD Celeron CQ60 and Sony vaio XP Pentium M 1.5ghz for what i do no complains. i'm old school and cheap never had new Tech and will die without the top of the line hardware.Oh i forgot my Emachines Desktop EL1330 AMD Athlon(tm) II X2 250u ProcessorLast edited by ivtec; 05-22-2019, 11:19 AM.Comment
by sigmeyerI got this 50 inch tv the screen starts off with almost nothing visible but the top part of it , and it would slowly kick in and the picture would be visible , but then over time it would go greyish with the top of it mostly intact. I did have instance where the screen would be fucked like that and i would touch the cpu and memory to see if it would react and a couple times it would screech on the speakers and restart. After that it would show a better picture somewhat but afterwards i touch the cpu and not much is achieved. Im wondering is this a screen fault or should i pursue this with a donor...
by BehemotAnybody has? I don't even have the strength to whine about how EVERYBODY on the whole fucking planet is so dumb to only REPEAT link to frelling AMD site WHICH CEASES TO EXIST after few months instead of HAVING the stinking file to download FROM THEIR OWN SERVER, for fucks sake. Would laugh if it did not make me cry
So after quite intensive search, this thing seems to be impossible to find.
For the record - 15.7.1 is totaly fucked up for DXVA, 15.6 is latest reported working one.
This is actually quite interesting that AMD always FUCKS UP some driver line, usually...-
by surfer349Looking for advice.
https://www.amazon.com/gp/product/B078WRN1S8/
I have this LG Gram 13, from 2020. Recently, it seems that the battery simply won't charge. It's drained down to 0%, and will now only turn on when plugged in, either through USB-C or the DC charger plug.
I've opened the back to look for anything obvious but it all looks fine. I tested the voltage on the DC charger and its all fine.
What next? Is it possible the battery is fucked? I've read there are control circuits on the battery itself that regulates charging. Can that... -
by CapLeakerEither I am getting old or dumb, probably both.
This “simple” linear power supply is driving me insane. Should be easy, right?
Here is the story. Got that Astron RS-7A or 10A as stone dead. I mean turned on and got 0.00V not even an mV on the output. Why dat? Darn electrolytic output capacitor shorted at the binding posts. No, problem… new one in stock and mounted.
Turned the PSU on again and now I got 0.1V on the binding posts. Everything clear like sunny day and replaced the LM723 regulator IC in the socket. Had it made, I thought.... -
by jesihi there
no sound on this crap laptop giving me headaches
mb 16867-1 nba_rockets_mb 448.0by04.0011
need schematic and alc1305h ic i think
many thanks
Channel: Schematic Requests ONLY!
03-25-2019, 07:17 AM -
- Loading...
