Weird SSD Issue
+ More Options
Latest Activity
  • Per Hansson
    replied
    Re: Weird SSD Issue
    Well, it's not really a OCZ this drive, but a rebaged Toshiba drive.
    So you might need to use Toshiba's tools for it (if such exists).
    If not I've had success with Linux hdparm: https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
    However please exhaust all other options before you try that.
    For example the MS-DOS utility hdderase.exe is a "safer" tool...
  • CapLeaker
    replied
    Re: Weird SSD Issue
    Was the error something like "drive is security locked"?
  • ratdude747
    replied
    Re: Weird SSD Issue
    Originally posted by stj
    it's probably in secure mode - like a password - send a full erase sequence to it.
    Topcat sent me the SSD... and yup, the SATA password somehow got set. Seems to be a common OCZ issue (why friends don't let friends buy OCZ?)
    I tried to use an OCZ boot disc to secure wipe it but it immediately fails (forgot what the error was). Likewise, I couldn't find any OCZ master passwords online.
    I'm all ears to other suggestions (or if you happen to have the OCZ master password, no it's not Toshiba's 32 spaces, I tried).
  • RJARRRPCGP
    replied
    Re: Weird SSD Issue
    If the utility in Parted Magic shows that it's frozen, use the desktop menu to put it to sleep for some seconds, then wake it back up.
    Don't use the "Sleep" button in the Parted Magic disk utility menu-> There's a bug that makes the BIOS state fucked up and apparently causes motherboard BIOSes to keep falsely reporting an overclock failure, possibly until you clear the CMOS!
  • kaboom
    replied
    Re: Weird SSD Issue
    Originally posted by junktv
    That deoxit is expensive.
    Borderline overpriced, actually.
    But I had to get mini squeeze tubes of the "red" and "gold" to clean a tape deck rec/play switch.
    It wouldn't stay "good" after repeated attempts with CRC 2-26.
    Any stuff cheaper and available at stores? I'm sure I could use something like that. I know I have some pots and switches that need cleaned.
    https://www.homedepot.com/p/CRC-2-26...2004/100398344
    Also works good on DIMM and card edge contacts with either sturdy paper towels or swabs.
    replied
    Re: Weird SSD Issue
  • junktv
    replied
    Re: Weird SSD Issue
    That deoxit is expensive. Any stuff cheaper and available at stores? I'm sure I could use something like that. I know I have some pots and switches that need cleaned.
  • kaboom
    replied
    Re: Weird SSD Issue
    I've had some strange issues caused by dirty SATA plugs and contacts on drives, both mechanical and a brand new SSD. The SSD in question is actually running perfectly in the E6400 I'm posting from. After imaging the original HDD to the SSD, this laptop didn't even see the SSD when placed into the internal bay. Yet it worked fine in the ext enclosure...
    Spray the SATA cable plugs with Deoxit or your favorite substitute. Also scrub the SATA connector, both power and signal, with a Deoxit-dampened swab.
    A few months ago, the HDDs (it would've seemed) in my main PC got slow. Sometimes holding the IRQs, just as a bad drive would in the old days. Re-enabling UDMA would always revert back to PIO, after any attempts to copy. I pulled the drives and cleaned the HDA-PCB contacts, and connected them to another system & backed them up. Great speeds now...
    But in the main system, back to slow-ville. An 8 hour+ ETA for what should've been an hour's worth of copying. Tried several combinations of drive/SATA cable, finally discovering one which was suspect. Sprayed the ends of all 3 with 2-26 and cleaned the SATA contacts.
    That did it. We were off, to the moon, Alice!
  • Topcat
    replied
    Re: Weird SSD Issue
    If you toss it, can I have a crack? I'll pay shipping...
    Yea. I'll let you know in the next few days if it comes back to life.
  • ratdude747
    replied
    Re: Weird SSD Issue
    Originally posted by Topcat
    If it was ESD, that'd be a first in all my years...but I suppose it's possible. DBAN seems to be communicating with it....so I'll let DBAN zap it and see if it comes back to life.....last ditch effort before it ends up in the trash.
  • RJARRRPCGP
    replied
    Re: Weird SSD Issue
    Originally posted by goontron
    ^ Ive had SMART erases bring SSDs back to life. Last ditch effort if DBAN fails
    ATA secure erase time! Parted Magic is the easiest Linux distro to do that with!
  • goontron
    replied
    Re: Weird SSD Issue
  • Topcat
    replied
    Re: Weird SSD Issue
  • ratdude747
    replied
    Re: Weird SSD Issue
    ESD? Was it used as part of a RAID array? The latter has done this to me, had to "remove" the drive from the array on a compatible controller before it would work right.
  • Topcat
    started a topic Weird SSD Issue
    Weird SSD Issue
    Long story short, I pulled a working SSD out of a system (upgraded it to a larger one) and connected the old pull to another controller. Ever since, the drive is no longer accessible, even in the system it originally came from. BIOS's see it, but it can not be initialized, read, partitioned, etc. I've tried a couple utilities on it, which see the drive....but some say 'lost partition', and timeout attempting to recover it. I can care less about the data on it, I dumped it before I started diddling with it.....but is there any way to recover/reuse the drive itself? It was perfectly fine before..... It's a 240gb OCZ TRION150.
  • SuperJames
    Dell G3 17 3779 Weird power cycling and shutdown/restart issue
    by SuperJames
    This one's a weird one, and still unsolved despite it having gone back to Dell once.
    Specs
    i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
    Backstory
    I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
    10-23-2023, 04:09 PM
  • ugamazing
    820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
    by ugamazing
    So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
    1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
    2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
    04-10-2024, 08:06 AM
  • Spider1211
    Weird but interesting issue with DELL 3542 (intel mb 13269-1)
    by Spider1211
    Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
    Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
    Backstory:
    Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
    Power supply draw:
    Voltage: 19.40V
    Amp draw: 0.006 - 0.007A
    Amp draw...
    04-07-2021, 03:21 PM
  • tommygun26
    Hp 6510b weird issue
    by tommygun26
    Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
    02-26-2023, 06:00 AM
    APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
    by sam_sam_sam
    This started a few days ago and does this about every 8 hours
    After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
    The battery backup is about 3 or 4 years old
    Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
    06-02-2024, 02:30 AM
