So I finally got around to putting the second 3.2ghz in my supermicro now that I got my delta 700w.
Well, its doing the same thing it did with the rosewill 500w. Hangs up after post. If I reset the bios and unplug it for about a hour, then it will get as far as the screen to chose which windows to boot. Also, it didn't do this before because the rosewill had the switch on the back I just flipped to restart it (didn't have the power button plugged in), but if I hold the power button to turn it off when it is hung up, it eventually turns off. All the fans stop, no input to monitor, but the keyboard stays lit up and frozen until you unplug the psu and it discharges. Strange.
Anyways, is there any settings I should change in the bios to make this work? It says that there is two processors installed, both at 3.2ghz in the bios.
