i got a flash of back light then no display here is the backup file
Need bios for Hp 245 G7 hagrid-6050A2983601-MB-A02(A2)
Re: Need bios for Hp 245 G7 hagrid-6050A2983601-MB-A02(A2)
here virgin bios extracted from hp support
S.N-5CG908433TAttached Filesif you find these attachements useful please consider making a small donation to the site
What worked for me is the following:
I downloaded the file 084A2.rar provided by qayyum786 then i used the AsProgrammer_2.1.0.13_fix and flashed the bios with this file, once finished i was able to turn on the computer but i was getting an error every time the computer turned on, the next step was to create a USB recovery drive for my computer model, i went to the HP website and downloaded the Bios Firmware for my computer and created USB recovery drive, i went back to my computer and followed the following steps:
1.- Turn off the computer that requires the BIOS recovery, and then wait 5 to 10 seconds.
2.- Insert the USB flash drive with the BIOS file into an available USB port on the computer.
3.- Press and hold the Windows key and the b key at the same time, and then simultaneously press and hold the power button for 2 to 3 seconds.
4.- Continue to hold the Windows and b keys, but release the power button. You might hear a series of beeps.
5.- The HP BIOS Update screen is displayed and the recovery began automatically to install the lattes firmware update.
All the step you ca find them on the following link:
https://support.hp.com/us-en/documen...820-3438449-16
Once my computer was fixed i created a backup from the bios from my computer and uploaded maybe it will work for you too, My computer is an HP 245 G7.
I hope it works out for you too.
Have fun.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks Cronosmx,your file is work 100%...
post the serial number, backup, problem description etc. Read the rules https://www.badcaps.net/forum/troubl...before-posting
post the original content of the bios chip, even if it is corrupted..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Hi everyone, thanks for the thread. I also need the bios for HP 245 G7.
S.N: 5CG9136SRL
BIOS: Winbond 25Q64FWSIQ
The corrupted BIOS is attached.
It was my dumb error. I was experimenting with flashing and re-flashing the BIOS chip with a CH341A.
Didn't double check the dump. When I re-flashed, I got an error. Power is there but the screen is blank.Attached Filesif you find these attachements useful please consider making a small donation to the site
Apologies if this appears to be spam but I've solved my own problem.
I extracted the 084A0.BIN file from the HP BIOS tool and this worked for me without a hitch.
I have attached this to the post. I hope it helps someone else.Attached Filesif you find these attachements useful please consider making a small donation to the site
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
Channel: BIOS Requests ONLY!
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by cr4zychrissHello everyone,
I have successfully used a CH341A programmer and can read/write/verify both flash chips, but using my backups/extractions has failed to restore power. The root cause is likely a corrupted Intel Management Engine (ME) region or an incompatible EC/BIOS pairing. System & Hardware Details- Barebone / Chassis: TongFang GK7MRFR
- MB: MB: GK5MP5X V1.0 Prod :GK5MRFV10T04201310281
- Rebrand: PC Specialist
by abhorsenHey guys,
Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...-
I'm not a super pro like some here, when it comes to firmware. I have a machine with the following specs:
ENVY X360
15-ew0013dx
SN: CND2261KS3
Prod: 698V0UA
Board: LA-M021P Rev 1A
Chip# Winbond 25R128JVSN
Basically, when I power it up, I get no video, and the fans run hard - nothing else. Seems like a BIOS issue to me, so I posted a request in the BIOS request section. I haven't heard anything back(and that's fine) So I tried downloading the BIOS from HP, then I extracted it and flashed it onto the chip. Unfortunately, all I get is the power...10-09-2024, 08:40 AM - Loading...
