Reassembling solvent-welded cases
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    I often have to pull apart solvent-welded plastic cases (wall wart, brick, device enclosure, etc.)
    But, putting them back together -- in a way that doesn't look amateurish -- is always a challenge.
    I've tried different adhesives to minimize the "sloppy mess" but they always, still, look like they've been taken apart and reassembled...
  • jondoe
    • Nov 2016
    • 547
    Re: Reassembling solvent-welded cases
    The solvent they use to bond plastic water piping and such is good and stronger than cyanoacrylate super glues, it does take a bit of practice to a) get the wall wart apart cleanly and b) glue it cleanly. Less is more is my rule.
      • 31283
      polypipe
      from plumbing shops.
      • Curious.George
        • Nov 2011
        • 2305
        • Unknown
        Originally posted by stj
        polypipe
        The solvent-style adhesives don't work. The act of cutting the case open, removes (destroys) material. So, the resulting case is "shorter" than the original. If there are internal structures (e.g., heatsinks, metal frames, connector shells) that neatly fit inside the case, you can't squeeze down on the shell to bring the two cut surfaces close enough together to come in contact with each other.
        Adhesives that aren't viscous enough flow straight through the gap between the two half-shells.
        So, you need a viscous adhesive that, itself, will cure to be as strong as the case itself -- acting like a "filler" as well as adhesive.
        I've found many of these. But, their viscosity makes them hard to apply cleanly; excess inevitably slops over the exterior of the case. And, cuz the case is plastic, any solvents strong enough to clean up the mess end up dissolving the external surface features of the case (e.g., remove the textured finish)
        While the reassembled case may be physically intact, it very obviously looks like a patch job!
        I don't do these kind of repairs for a living so if I'm doing it, it's:
        - because I couldn't just rescue a compatible device
        - for a close friend that I'd like to have a "quality" result
        • diif
          • Feb 2014
          • 6978
          • England
          I have some stuff called Plastic Weld. Administered with a syringle/needle it's fairly mess free. Capillary action does its thing and the glue melts the top later of plastic.
          Crack rather than cut the case open and it works well.
            • 31283
            polypipe is a gap-filling gel.
            plastiweld is like water.
            different tools for different jobs.
            or use dark silicone??
            • petehall347
              • Jan 2015
              • 4448
                • 31283
                yes, used the silver version on my 12v test supply.
                not a good idea for customer gear though!
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Polypipe is the name of the company. They do solvent for ABS or PVC or do you mean something else ? https://www.mrcentralheating.co.uk/s...nt-small-125ml
                    • 31283
                    that link looks like the stuff i had.
                    didnt know it came in black though!!
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Ill give it a try. It's certainly cheaper than Plastic Weld, that somehow manages to evaporate out of a sealed glass bottle.
                      • Curious.George
                        • Nov 2011
                        • 2305
                        • Unknown
                        The silicone may be a win -- if I can find a dispenser with a small enough "nozzle" (as you typically only want a 1/16th inch bead to fill the gap).
                        Or, maybe get a bunch of disposable syringes (large bore plastic tubes instead of needles) and consider each to be a one-use product.
                        Then again, maybe the syringes would work with the epoxy as well? The problem there is always going from the mixed two parts to "application" without getting all sorts of it on the outside of the case (if you could squirt it into the gap it might be a win as it is reasonably viscous and 5 minute setting times are manageable)
                        • R_J
                          • Jun 2012
                          • 9623
                          I just repaired a Macally PS-AC4, i just used clear rtv silicone all around the edge, worked perfect, I have used crazy glue but found it won't hold well, in one case I used 5 min 2 part epoxy, It worked good too, none of these products will really stick that well to plastic so there is no problem opening them again if needed.
                            • 31283
                            put tape on the edges of the case,
                            apply the stuff, smooth it down with a card.
                            then peel the tape off - clean finish.
                            i use shitloads of masking tape - a thousand uses for that stuff.
                            • Curious.George
                              • Nov 2011
                              • 2305
                              • Unknown
                              Then the sides of the case differ, in appearance/texture, from the face and back of the case. Plus, you've "scraped" the side to have square edges instead of the rounded ones typical on most injection molded cases (as well as removing the draft angle that was present on the original sides).
                              And, you have a couple of places where you've had to work-around the power inlet and outlet while not trying to let the original surface/texture peek through (cuz you've obliterated it, elsewhere along the sides).
                              If, instead, you confine your adhesive to the gap between the two half-shells, you can make the adhesive look like it was intended to be the "original" adhesive. That's why I take the effort to use hot knife or thin saw blade to cut the case in half -- so the only missing plastic lies in the gap.
                              I'm going to start looking for disposable syringes -- preferably small barrels so they don't need a lot of adhesive to be effective -- and try using them as applicators. Similar to the fancy solder paste dispenser that I use with my Leister.
                              • clearchris
                                • Dec 2013
                                • 687
                                I haven't had much success gluing these types of cases. Were I to try another, I'd probably just print a replacement case on the 3d printer and I'd design it to assemble with screws.
                                  • 31283
                                  you can probably buy good cases, but company's like VERO and Hammond dont sell stuff cheap!
                                  • Curious.George
                                    • Nov 2011
                                    • 2305
                                    • Unknown
                                    These are G-jobs, for friends. I'm not going to spend hours measuring the guts and designing a suitably sized enclosure to house it -- then print it. They can go buy a replacement if it gets to that point! Hence the reason I opt to just find a similar replacement (often same make/model) and gift it to them -- to save me the time of disassembling, repairing and reassembling.
                                    It took me an hour to do this process most recently for a set of three power supplies. I figure the average of 20 minutes per supply is cost (time) effective -- it will take me that long to dig through a gaylord full of power supplies in search of a suitable replacement (THREE such replacements).
                                    But, I'd like not to have to be apologetic about the appearance of the results! (actually, these came out "decent" -- though you can tell they were repaired)
                                    • petehall347
                                      • Jan 2015
                                      • 4448
                                      drill holes for cable ties .will also let some heat out .
                                        Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                        The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                        Securing a good thermal interface between...
                                        10-07-2024, 04:35 AM
                                      • jayjr1105
                                        9v super basic wall wart issue
                                        by jayjr1105
                                        This is one of those worthless and time wasting repairs but it's bugging me and I want to figure it out. Simple 9v 1a SMPS wall wart and it's bouncing between 8.2 and 9.4v without load. I've pulled out every single cap and all tested fine. I've replaced the opto and same exact issue. All diodes are testing fine. I'm not sure if the IC can cause this or if the IC had issues you wouldn't get anything at all on output....
                                        03-03-2022, 08:32 AM
                                      • bubblegum_bob
                                        Blaupunkt 40” TV 40/233I-GB weird lines like moire effect after reassembling
                                        by bubblegum_bob
                                        the backlight wasn't working and after some online research, i stripped the display (total nightmare) to find one led at fault.
                                        I bridged the faulty led and after i reassembled the TV, the background lighting works fine, but the screen got some strange lines.
                                        It's not visible, if you sit straight in front of it.
                                        But change the viewing angle and it gets annoying.
                                        What could be the cause of this? Did i broke the Display while reassembling?
                                        09-28-2020, 11:15 AM
                                      • eccerr0r
                                        Bestec BPA201S-12V 12V@1.6A wall wart repair
                                        by eccerr0r
                                        110VAC-220VAC
                                        I had one of these croak on me, was wondering why it died.
                                        I had been running it on 120VDC (first half of my transistor magic smoke generator, err, inverter) and that was a suspect, turns out it wasn't.
                                        Cracked it open with a vise, it split up very cleanly. It's a cheap 3-transistor optoisolator feedback design, trimmed by sticking in resistors in a parallel slot.
                                        noted the output was shorted. Pulled secondary rectifier - short still there. Pulled out zener crowbar... short gone and zener was shorted! Checked switch transistor......
                                        09-27-2020, 11:32 PM
                                      • conghuyms
                                        Issues leading to the loss of 1.8V EN on the RX5700XT graphics card
                                        by conghuyms
                                        Hello everyone.
                                        I’ve seen many questions related to the 1.8V EN power rail on the RX5700XT graphics card. Could everyone help gather and summarize the different cases where this power rail is lost? This would help members and readers more easily troubleshoot and fix similar issues on their own cards in the future. Thank you all!
                                        As for me, I encountered this issue when the 1.8V EN rail was lost due to a faulty transistor Q10021. Are there any other possible cases?...
                                        07-08-2025, 09:49 AM
