Lite-On DVD drive eject issue
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Here's an odd one. I have two Lite-ON dvd burners that both won't eject correctly. Both of them make a clunk, and one will only eject if one "helps" it start by using a paper clip in the eject hole when hitting the button. The other will work after a few tries but usually "clunks" on the first few hits. One is a PATA lightscribe burner; the other is a SATA Burner.
    Is there a known cause for this issue? First time I've ever had issues with Lite-on drives.
    sigpic
    (Insert witty quote here)
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16956
    Re: Lite-On DVD drive eject issue
    belt weakening/stetching from the motor to the gear, it just starts slipping. It's not strong enough to separate the magnet atop from the spindle for the disc. Usually if there's a disc in the drive it'll eject fine....but empty, it'll do just that. Cleanign them sometimes helps, but they usually have to be replaced.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kaboom
      "Oh, Grouchy!"
      • Jan 2011
      • 2507
      The "clunk" is mechanical slack between the deck-lift cam/slide/rack and tray traverse idler gear engaging.
      Seen many "later" (LG, LiteOn, TSST, mostly) optical drives do this. It's the rails on the bottom/sides of the tray. Either the grease is stiff or rubbed away over the years, and/or dirt & dust is causing too much friction.
      Remove the tray, paying attention to the indexing between that idler gear and the rack gear on the side of the tray. There are usually two mechanical limit pins, posts, or tabs that must be pushed in to allow the tray to extend fully. Once you release the tabs, the tray comes out.
      Clean it! CRC QD works great on the old grease and won't hurt the plastic. Hose the slides & rack gear good.
      My go-to is Super-Lube. https://www.homedepot.com/p/Super-Lu...1030/202932687
      While you've got the drive apart, you should also relube that optical deck lift cam and the pins which engage it. It's sort of a flat piece with inclined slots (the deck's pins engage these) with teeth on one end which engage the idler gear, which moves the tray.
      Hint: Most of the time, the tray is not indexed to that loading gear, and the loading gear is free-wheelable when the tray is out. I've always been able to simply put the deck/rack/slide in the down/eject position and slide the tray in. The rack on the tray will engage the load gear.
      Some drives have a "nub" that sticks up and engages a slot in the bottom-center of the tray.
      Don't forget to clean and lube the slide rods on which the pickup runs. A small amount of Superlube here... Clean the lens too.
      And clean that belt (some lite-ons & sonys are fully geared from motor to rack-drive gear) with iso alcohol and paper towels while it's apart. If the belt is weak, you'll hear the loading motor run but have no tray action.
      Incidentally, Toshiba/Samsung/TSST drives are good for dirty load/eject "pin" limit switches. If yours has these, unhook two tabs on one side only, partially lift (do not remove lest little parts fly away) the bulkhead holding the plungers, and spray some 2-26 in there. No more retracting tray in immediately after ejecting, or vice-versa.
      Have fun.
      And stay warm.
      "pokemon go... to hell!"
      EOL it...
      All style and no substance.
      guilty,guilty,guilty,guilty!
      guilty of being cheap-made!
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        The belts seem to be OK on both (no looser than any other optical tray belts I can remember)... What would be the best lube for these? Sewing machine grease? Silicone Paste? Edit- fail, missed your link.
        sigpic
        • kaboom
          "Oh, Grouchy!"
          • Jan 2011
          • 2507
          No prob.
          One of the more obvious ways to assist is to take lots of pictures as you disassemble something. So obvious, in fact, I forgot to mention it initially.
          Good luck!
          EOL it...
          • R_J
            • 9535
            One thing I found over time is the belt forms to the two pulleys, Usually the smaller being the motor pulley, If you take off the belt and it looks like it is formed to the pulleys and not round it needs to be replaced.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Dangit I hate Lite-on drives. I have a whole bunch of lite-on drives where the hub glues itself to the CD/DVD after a while. This then prohibits eject...
              I had two CD-RW drives and a DVD-RW drive do this, all Lite-on...
                • 31015
                you mean the magnetic clamp-ring?
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Yes, except the it's the motor spindle side, not the magnet side. The top side will separate just fine, just the bottom sticks to the disc. The spindle side has some cork-like material that seems to exude glue that glues the disc down.
                    • 31015
                    must be ancient to use cork - yes they had nasty glue under them.
                    anything half-modern uses a rubber pad.
                    although those can probably turn to sticky mush!
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      Is there a retrofit or quick fix for them?
                      Else I have to treat the drive as a very slow 700MB or 4.4GB hard drive with their last CDRW/DVDRW media in them...
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        Where do you find replacements ? - specifically for an LG GSA-4163B which will only eject if there's a disc in it
                        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                          • 31015
                          you could try removing the cork, cleaning off the glue - IPA/Acetone??
                          then sticking it down again.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            I was starting to do the same, I had a 2005 Lite On SOHR-5239V CD-RW drive that hated lower temps, would randomly stop responding in the middle of the system software reading files!
                            And the facker once caused the XP text mode installer (IIRC) to randomly say "Setup cannot copy the file: town.mid"...
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              The cork has virtually disintegrated, trying to remove it means removing individual pieces of cork...
                              Need to replace the whole thing -- and BALANCE it???
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                I used to get them from MAT Electronics....but I think they're tits up now...its been a while since I've had to buy them. I used to get assortments of belts for various VCR's, etc.....there were some in the kit that would fit optical drives as well...
                                Team : 49813
                                Join in!!
                                Team Stats
                                • pfrcom
                                  Oldbie
                                  • Jun 2006
                                  • 1230
                                  Thanks for the reply - I actually removed the belt and cleaned it with IPA
                                  Eject button works fine now, with or without a disc in the drive
                                  • rounin
                                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                    by rounin
                                    🛠 Original Issue
                                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                    04-19-2025, 01:18 AM
                                  • ugamazing
                                    by ugamazing
                                    12-17-2024, 07:05 PM
                                  • elmark
                                    HP 15-cw1002ua strange keyboard issue
                                    by elmark
                                    HP Pavilion 15-CW1002UA
                                    S/N 5CD0251CBC
                                    P/N 7KE54EA
                                    Hello guys!
                                    I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                    It powers on OK and has no other issues except the following:
                                    • CAPS LOCK does not work at all
                                    • Fn button toggles Flight Mode
                                    • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                    • (with SHIFT pressed: 't%' and 'y^' respectively)
                                    I initially thought it was a keyboard malfunction (internal short, etc.),
                                    but when I press and hold...
                                    06-27-2025, 01:10 AM
                                  • Simone Vergani
                                    Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                    by Simone Vergani
                                    I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                    To assist with troubleshooting, I'm attaching two power circuit schematics:
                                    • Power
                                    03-05-2025, 02:25 PM
                                  • wizard13
                                    Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                    by wizard13
                                    I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                    I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                    • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                    • Part Number (P/N): PYU13E-00C00PFR
                                    • Serial Number (S/N): 22028896H
                                    • System Configuration (SC): A1PYU13E1127
                                    • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                    • Power Input: DC 19V –
                                    02-28-2025, 02:43 AM
