Can This Be Done and if so How ?
  • mmartell
    • Oct 2013
    • 3189
    I have a sat receiver that will record to usb thumb drive and a tv that will play the recorded file without issue.
    Is there an off-the-shelf in-line device that will satisfy usb protocols and buffer the output and feed it to the input so as to play the output in real or near-real time ?
    • 31281
    Re: Can This Be Done and if so How ?
    no.
    • mmartell
      • Oct 2013
      • 3189
      That was concise.
        • 31281
        yes, i wanted to be clear and specific.
        both devices are looking for a filesystem before they concern themselves with the file itself.
        also both devices are acting as "master" initiating the action.
        • mmartell
          • Oct 2013
          • 3189
          I thought for that reason there could be no instantaneous transfer of data but I'm sure a savvy programmer could emulate a filesystem on either end and use a buffer instead of a real file. That's why I asked if there was an off-the-shelf solution instead of using pc's.
          I figured it was a rare enough idea that I would ask about it
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            https://www.amazon.com/UGREEN-Transf...V90EGXGA2TCQVC
            Ive never even got these to work on Windows, let alone some embedded *Nix and RTOS systems...
            Follow the white rabbit.
              • 31281
              i think those used special software drivers to emulate serial-over-usb or ethernet-over-usb.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                ^ Exactly. Thats all we got, so if OP wants to build drivers for it all... Well, have fun.
                • Goldwing1973
                  Sonos Play 1 pulsing power supply
                  by Goldwing1973
                  I'm rather new to repairing electronics, i do know the basics of most components but never actually repaired a PCB, but i want to change that.
                  So, i bought a faulty Sonos Play 1 speaker with the intention of finding the fault, and replace the damaged part.
                  Well, i did find the fault, i replaced parts that i thought caused the problem, but no-go.
                  The problem is a pulsing power supply, when i connect the mains to the board and hook up my thermal cam i see R306,307 and 308 getting warm, but i assume that's normal.
                  But, whats is not normal is the pulsing of resistor...
                  07-04-2025, 12:59 PM
                  Huawei Honor Play Mobile Phone Schematic
                  Huawei Honor Play Mobile Phone Schematic...
                  11-06-2024, 07:10 AM
                • dbuergi
                  Sonos Play 1 Gen. 2 with no power
                  by dbuergi
                  i got a Sonos Play 1 Gen. 2 with no light and no power. Until now i only worked on Gen. 1 and know which components "like" to blow up but at this board everything looks fine. Until now i also didn't find any short.
                  The only problem i found was chip 6D9 heating up to 110c when power supply is connected. Since this is a PMIC i will replace it.
                  Do you have any other ideas what to check or can these chips get faulty without any other component quitting the job?
                  09-12-2024, 12:23 AM
                • mecha1166
                  Tascam CC-222MKIV Need PLAY / RECORD button assy on CD side.
                  by mecha1166
                  Hi. A customer brought in a Tascam CC-222MKIV. Play/Record buttons on CD are broken. I am looking for a mechanical parts breakdown so I can get the part number for this key assy. I found the schematic online, and I can tell you the schematic locations for those switches themselves. There is a plastic assembly with buttons that each have shafts to poke the surface switches on the circuit board right behind the faceplate. That is what I need. Thanks!
                  07-25-2024, 01:49 PM
                • MAVA
                  Anyway to recover Hi-8 tapes that donot play?
                  by MAVA
                  Anyway to recover Hi-8 video tapes that do not play? It is not the problem of the this Hi-8 player.
                  Maybe someone has a trick, or recommends a player that can play these tapes.
                  The player I have is a Sony Camcorder TR-101, and it will not play them anymore. I just want to play them one more time to convert them to digital format.
                  Thanks,
                  Martin
                  01-27-2021, 12:36 PM
