Tascam CC-222MKIV Need PLAY / RECORD button assy on CD side.
  • mecha1166
    • 37
    Hi. A customer brought in a Tascam CC-222MKIV. Play/Record buttons on CD are broken. I am looking for a mechanical parts breakdown so I can get the part number for this key assy. I found the schematic online, and I can tell you the schematic locations for those switches themselves. There is a plastic assembly with buttons that each have shafts to poke the surface switches on the circuit board right behind the faceplate. That is what I need. Thanks!
  • flibidy
    Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
    by flibidy
    I have here a Magnum IA.100 which belongs to my parents.
    The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
    Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
    What Ive done........
    01-01-2025, 01:26 PM
  • bouny56
    Lenovo E15 Nm-c421 usb-c work only in one side
    by bouny56
    ​Hello
    Laptop E15 I5 10gen
    Mb nm-c421
    I have a problem with the usb-c power dc.
    The motherboard start only in one side of the usb-c
    Replace the usb-c port 2 times same problem
    With the usb-c meter, one side 20v ok, other side the usb-c meter don't come on
    Try to test the pin with the Mechanic Tail insertion tester and every pin are ok ?
    Can the pd controler be the fault ? Or something else maybe ?
    Thx
    02-11-2025, 03:15 AM
  • howardc64
    by howardc64
    07-24-2025, 05:17 PM
  • Stephen
    A2442 MacBook Pro 14" Two Left SIDE USB C ports charge but no data
    by Stephen
    Right SIDE usb.c port charges and transfers data without issue, two left side uSB c ports charge but do not receive or see data. Was liquid damaged, and repaired significantly and thought we were in the clear but appears this is the last issue that is rearing its head. I am trying to locate the RETIMER chip that communicates the DATA TX/RX but I cannot seem to find it on the schematic or maybe I am just so tired my eyes wore out lol. Any help would be great.
    05-29-2025, 10:35 AM
  • dicky96
    Xilence XP600 600w ATX PSU - No PWM Controller on primary side - how does it work?
    by dicky96
    Hi guys
    I have a faulty Xilence ATX PSU here
    The fault basically is I have two short circuit power transistors on the primary side of the large SMPS transformer - they are 2SC3320.
    There is another smaller transistor on the primary side C3866 which tests ok
    The PSU has three transformers - it looks like the 2SC3320's drive the big one and the C3866 drives one of the small ones. There is a separate PFC PCB with it's own controller and MoSFETS
    There is also a short on the 3.3V output and a near short on 5V - I suspect this probably blew...
    05-11-2021, 07:55 AM
