A Real "Burn-In" Test....
  • ArmoredFist1994
    • Dec 2008
    • 25
    I've seen and run a bunch of "burn-in" tests. Prime95, Memtest, etc. Acutally with my faulty motherboard with leaking exploded caps (just sent it in for recap a month ago - not back yet), all those tests ran fine when it booted!
    The REAL TEST is getting it to boot, isn't it? Will it boot repeatedly? That's what it's all about.
    Wouldn't a real reliability test be to just keep turning the thing off and on, off and on, over and over. I know this sounds like abuse of equipment, but if it's going to fail, that's when it'll happen, correct?
    Somebody who knows more about electronics than I, please educate me...what's the deal with turning electronics off and on? I've always waited 30 seconds before turning something on after turning it off so (I believe this is correct) the capacitors can discharge!
    Any input is welcome, thanks.
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: A Real "Burn-In" Test....
    Well, turning a computer on and off repeatidly will hurt even the highest quality components.
    Sure a PCCHIPS mobo may fail quicker that like a Intel or Asus mobo. And a Bestec psu would fail quicker than a Corsair. But you could still cause damage to the Asus or the Corsair. With a software test like memtest or prime95, it works the cpu and capacitors and ram, but won't really damage them. (except maybe the caps may explode, but you can replace them.)
    • ArmoredFist1994
      • Dec 2008
      • 25
      I did run memtest and prime95 on a mobo that had leaking exploded caps, booted only intermittently and it ran both forever.
      When I turned it off, though, the ability of the machine to boot to the OS or even to make it past the post tests was 50-50 at best.
      Running prime95 test and memtest didn't seem to mean anything. It kept going and going through the torture test...never locked up or anything once it did boot....weird.
      Yes, it sounds really stupid to keep turning a device on and off.
      What does that do exactly to damage components?
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        Try this:
        http://www.xtremesystems.org/forums/...d.php?t=197835
        A man convinced against his will is of the same opinion still.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          On starting a marginal power supply will slow things down.
          During a Burn-in it won't usually show any problems.
          Mann-Made Global Warming.
          - Dr Seuss
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            the best thing would be something that loads the cpu up and then idles it repeatedly
            • i4004
              • Oct 2006
              • 2029
              i don't think that would do either...
              esr goes down as temp goes up, and as soon as you turn the machine on temp goes up...and won't really go that much down with cpu idle..
              also this
              "to just keep turning the thing off and on, off and on, over and over."
              is not godo either, as it takes time to cool down...rapid on/off would just mean it boots ok after first few hickups...
              what i'm interested in is why do you need such tests at all.
              it's not like the problem is not apparent(you said one of the symptoms, won't boot) and that you don't have time to react after first symptoms....
              • ArmoredFist1994
                • Dec 2008
                • 25
                That is a very good point! I guess I expected that there was some software burn-in or diagnostic that would have detected the problem. To my surprise, the machine passed all software tests I subjected it to.
                Yes, I know there's a hardware problem, but no software that I ran detected it or caused a failure. The only thing that "caught" it was the cold boot.
                However, running the previously mentioned IntelBurninTest Linpack may have caused a failure....I didn't know about that one until just now.
                I guess the purpose is to put the machine through a safe software test and if there's anything wrong, I expect the program to tell me or cause a failure. If a machine passes a test like that, it can be considered reliable.
                The need, I guess, is for a good reliability test so I can feel confident the thing isn't going to die on me at work.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  There is no software you can run that will say:
                  Hey: You caps are bad.
                  Hey: You MOSFETS are failing.
                  .... Or specific things like that.
                  Reason is there are no devices to measure the needed parameters from which some software could run a logic routine to determine the problem. (Say for a cap: temp/amps/leakage/maybe internal pressure even.) You would need 100's of different sensors and motherboards might cost as much as a car to do that.
                  Fact is most people had that many sensors to deal with they'd be totally lost anyway..
                  - Dr Seuss
                  • ArmoredFist1994
                    • Dec 2008
                    • 25
                    I agree....bummer!
                    • chth96
                      How Can I test PWM DM0365R?
                      by chth96
                      Hello
                      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                      06-18-2025, 04:14 PM
                    • cnti
                      Samsung 245B PLUS - BN44-00195A - bang and smoke - solved - tips
                      by cnti
                      Hi.
                      BacCaps forum is awesome - thank YOU ALL for sharing knowledge!
                      This is about DONG YANG PSU BN44-00195A failiure in Samsung 245BPLUS. It started with bang and smoke from the back of LCD. Downloaded diagram BM44-00192A - a bit different but I will use all parts names from this diagram [and real PSU].
                      BIG CAP CP801 had 315V, on standby pin 5,2V. After shorting S_B ON (through 3,3k ohm resistor) 24V and 5,3V were missing, on CP801 was 312V.
                      RM801 [real PSU: RM801 - 0,22 ohm 1W] - FAIL
                      burned, measured 10M ohm.
                      QM801 [real PSU:...
                      10-19-2023, 05:33 PM
                    • khelane
                      test active pfc power with lamp test
                      by khelane
                      Hello
                      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                      Is there a way...
                      06-03-2025, 01:00 AM
                    • chronic519
                      Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                      by chronic519
                      Hello.
                      GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                      Found issue with a RAM block
                      Replaced, green lines gone.
                      Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                      Used a good card to test and same results low errors 32+.
                      I am just search for some form of command to do a full test on the GPU.
                      I just ran the mats command with my good GPU and passed after roughly 40 min.
                      The repaired one, ran...
                      05-20-2025, 07:56 PM
                    • F R 2568
                      Dell Latitude 5420 does not start (no post) need help to find the reason why
                      by F R 2568
                      Hello all,
                      this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                      I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                      If the laptop is only connected to the AC adapter (battery removed):
                      When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                      The power/battery...
                      01-08-2025, 05:45 AM
