OST RLX 0444 capacitors
  • Fomhoire
    • Mar 2005
    • 8
    Anyone know anything about these capacitors? I ordered a new Epox 8VTAI and this is what is on them.
    For the record, I called Asus, Epox, MSI, Gigabyte, and another motherboard manufacturer. They all claim they are only using Sanyo, Panasonic, Rubycon or Nichocon on all new motherboards. I took a look at the displays at Frys, the information given to me over the phone turned out to not be true. All the brands have at least some crap brand capacitors on them. Epox told me they only use Sanyo. MSI states Nichocon or Panasonic only. My assumption is they don't know what brands are on all their current boards, but it sure sounded like they were familiar with the question and knew what answers to give.
    These are otherwise reputible companies. In the past I've had nothing but good luck dealing with Epox. I'm just hoping the OST capacitors have been revised. I will be watching them closely.
  • Fatal0E
    • Jan 2004
    • 252
    junk
    worst part about them is they will often fail but not show any visible sign of it
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      agreed.
      just recap it now and save time.
      they are crap.
      • rugger
        • Feb 2005
        • 55
        For the most part, Asus seem ok. Their boards ussually have Rubycon capacitors where it counts (the high capacity, low ESR caps). There may be some crappy brands of caps on the board, but you will find that they are low capacity normal capacitors that have rarely fail anyway.
        There have been reports of asus being cheap with their very lowend boards, so do keep an eye open in any case.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          wrong....asus p4c800 deluxe which is not what i would call a cheap board = united chemi-cons and OST everywhere else.
          • Fatal0E
            • Jan 2004
            • 252
            and some of the new premium boards with Ltec and OST everywhere
            do have an A8V-Deluxe on the shelf at work with ALL chemicon, they cant seem to make up their minds
            • rugger
              • Feb 2005
              • 55
              Wow, that sucks
              Looks like I'll have to inspect every motherboard I buy closely before buying it.
              • Lance Thornton
                • Jan 2005
                • 84
                Abit has learned their collective lesson. Nothing but Rubycons all over their newest boards. Good luck!
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Re: OST RLX 0444 capacitors
                  Gee wiz, my newest motherboard, an Asus A7V8X-X has Chemi-con and OST caps, but all of the caps on the motherboard are fine!!!! The motherboard's already almost 3 years old and have been OC'ing with it since June, 2004!!!!
                  It has been utterly stable. Has ALWAYS passed Prime95!!!! Since I have gotten my OC problems solved, I have yet to see Prime95 fail.
                  The motherboard has OST RLX caps.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • dragon3x
                    by dragon3x
                    power on.
                    Here are some examples :
                    switching supply area).
                    than 6.3 V.)
                    03-21-2025, 02:46 PM
                  • slybunda
                    AA and AAA battery charger capacitors?
                    by slybunda
                    hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                    it has inside:
                    2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                    2 x 470uf 16v LZ105c branded as G.Luxon
                    not heard of these brands are they any good?
                    iv attached photos of the charger and the board inside for an idea on the type of...
                    12-24-2023, 04:41 AM
                    After all of...
                    07-13-2024, 08:14 PM
                  • Ady2017
                    Are there any datasheets available for Elna RJG capacitors?
                    by Ady2017
                    I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                    05-25-2025, 02:19 PM
                  • ctroxtell
                    Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                    by ctroxtell
                    I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                    01-03-2025, 08:57 PM
