Dell GX270 motherboards
  • DellSux
    • Mar 2005
    Hey - is anyone having a problem with blown capacitors od Dell Optiplex GX270?
    I have had about 25 incidents. The computer boots and displays a message about CPU temps. Upon closer inspection the capacitors close to the CPU are bloated and some oozing liquid. Curious if anyone else is having the same issue...
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    the search function is quite useful
    https://www.badcaps.net/forum/showthread.php?t=450
    i assume yours also have the nichicon HN(M) series caps failing?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      100% failure rate in 3 months on a lot of 250 machines.
      you are not alone.
      and another division of my customers company is starting to report failures and will be sending me a bunch of boards too.
      • DellSux
        • Mar 2005
        This is ridiculous. Shouldn't Dell be at fault for this? We purchased around 110 of these. These computers are under warranty but it's going to take time to replace each motherboard and I'm certainly not going to wait for them to fail. I'm going to call my sales rep and rip him a new a$$hole.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          it would be interesting to know how dell deals with your problem. keep us up to date.
          • MD Willington
            • Sep 2004
            • 702
            Take pictures too...Make sure we have a big ol shot of the Dell brand name and the capacitor brand...my dell gx260 has the same nichicons but they are in good shape, it turns out it was certain machines manufactured between a specific time period...that co-insided with the latest SARS outbreak...and subsequent decontamination efforts at factories in Asia...
            Nichicon knows about the issue:
            http://www.nichicon-us.com/english/seihin/index.html
            MD
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              i have seen that sars item before but it is not conclusive. do you have actual info that sars and the HN(M), HM(M) series failures are linked?
              • MD Willington
                • Sep 2004
                • 702
                No..that was all I could find...but at least Nichicon fessed up...
                MD
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                  Dell Thunderbolt Firmware
                  by SMDFlea
                  Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                  Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                  The SKU is in brackets (****)
                  EDIT: NVM65...
                  01-26-2025, 06:22 AM
                • dell_sadness
                  Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                  by dell_sadness
                  BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                  Have extracted the BIN and want to know how to rebuild a clean BIOS
                  I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                  I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                  Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                  11-12-2025, 02:54 PM
