Dell GX270 motherboards
  • DellSux
    • Mar 2005
    Hey - is anyone having a problem with blown capacitors od Dell Optiplex GX270?
    I have had about 25 incidents. The computer boots and displays a message about CPU temps. Upon closer inspection the capacitors close to the CPU are bloated and some oozing liquid. Curious if anyone else is having the same issue...
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    the search function is quite useful
    https://www.badcaps.net/forum/showthread.php?t=450
    i assume yours also have the nichicon HN(M) series caps failing?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      100% failure rate in 3 months on a lot of 250 machines.
      you are not alone.
      and another division of my customers company is starting to report failures and will be sending me a bunch of boards too.
      • DellSux
        • Mar 2005
        This is ridiculous. Shouldn't Dell be at fault for this? We purchased around 110 of these. These computers are under warranty but it's going to take time to replace each motherboard and I'm certainly not going to wait for them to fail. I'm going to call my sales rep and rip him a new a$$hole.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          it would be interesting to know how dell deals with your problem. keep us up to date.
          • MD Willington
            • Sep 2004
            • 702
            Take pictures too...Make sure we have a big ol shot of the Dell brand name and the capacitor brand...my dell gx260 has the same nichicons but they are in good shape, it turns out it was certain machines manufactured between a specific time period...that co-insided with the latest SARS outbreak...and subsequent decontamination efforts at factories in Asia...
            Nichicon knows about the issue:
            http://www.nichicon-us.com/english/seihin/index.html
            MD
            Ya'll think us folk from the country's real funny-like, dontcha?
            The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              i have seen that sars item before but it is not conclusive. do you have actual info that sars and the HN(M), HM(M) series failures are linked?
              • MD Willington
                • Sep 2004
                • 702
                No..that was all I could find...but at least Nichicon fessed up...
                MD
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • Akhlz001
                  by Akhlz001
                  09-20-2025, 07:15 PM
                • master3112
                  by master3112
                  07-29-2025, 01:55 PM
                • F R 2568
                  Dell Latitude 5420 does not start (no post) need help to find the reason why
                  by F R 2568
                  Hello all,
                  this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                  I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                  If the laptop is only connected to the AC adapter (battery removed):
                  When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                  The power/battery...
                  01-08-2025, 05:45 AM
                • diamon
                  Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                  by diamon
                  I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                  Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                  Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                  Pictures of these boards:
                  Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                  Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                  Dell...
                  02-28-2024, 12:51 PM
