extreme stupidity by customer
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    got in a dell gx270 tower.once open we could not believe we were seeing this!
    btw the psu is ok as well as the system!in another junk pc that came in the same lot was a psu that not only would work fine in this system it had been rebuilt by me 2 years before!
    we need to start handing out dumbass awards.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: extreme stupidity by customer
    Whaaat!
    Franken-P4 connector. And this guy didn't even tape the right wires together (-12 to +12... what the hell?!)
    By the way, is that coffee or something on the 2nd and 3rd pics?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      the 2 lines on that are +5 +12
      and thats about 5 pounds of dirt packed in there!
      5 and 12 were tied together!
      • Scenic
        o.O
        • Sep 2007
        • 2642
        OMG!
        mhh.. another page with lots of pics (and crappy babelfish translation)
        so sad that there are so many people killing HW just because they're too dumb
        http://babelfish.yahoo.com/translate...rUrl=Translate
        Prozessoren = CPUs
        Arbeitsspeicher = RAM
        Laufwerke = drives
        Transport & Verpackung = Transport and packaging
        Sonstiges = other stuff
        • Fizzycapola
          • Oct 2006
          • 423
          Some of them are user error or ignorance. But other issues, like scratching the board, because heatsink clip snaps when it shouldn't, is related to manufacturer using wrong type of steel for HS clip. For example Globalwin used cheap heatsink clips to reduce costs due to the main heatsink being expensive single piece milled, I had to buy a Coolermaster heatsink, whose clip was about three times as heavy thick steel. To hold in the Globalwin heatsink.
          Quite often manufacturers get things very very wrong. Recently I read how a 8800 cooler doesn't not fit 8800 and actually destroys them. And this can make those not in the know, that only assume manufacturers know what day it is, to make errors and look silly, when they're not always.
          Rubycon Rubycon Rubycon
          • i4004
            • Oct 2006
            • 2029
            looking at the mobo section there; you know, cpu heatsink design is really a disaster, so no wonder users destroy them.
            they should just provide solution with 4 screws that would secure the heatsink and end there.
            their attempts to do it all with hands just result in forcing those mobos and plastics beyond limits.
            so for that i don't blame people, but designers.
            socket 775 mobo with heatsink installed out of the box just looks rediculously bended, esp. on matx boards...
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              Whoa! This is the chip hell: burnt cpus, traces broken with screwdrivers, ...
              I won't dream this night
              Zandrax
              Have an happy life.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                i4004; Yea, like the Xeon boards
                4 screws going through the mobo into the chassi steel plate
                Does not become much more simple or safe than that
                Wonder why not all boards just use that?
                But maybe they like RMA's :P
                • i4004
                  • Oct 2006
                  • 2029
                  didn't know somebody actually uses that system, but it just makes so much more sense than crappy clips and plastics...
                  i guess 4 screws propell the price over the roof...stupid cheap fucks...
                  • Wizard
                    • Mar 2008
                    • 2296
                    At one time when P4 just came on, some decent cases had 4 threaded holes for the P4 heatsink bracket. Even Asus once included a steel plate stuck to the bottom of the board in the area of P4.
                    Good AM2/3 now have plate on bottom under the socket.
                    775 socket boards rarely have the plate. Some third-party good heatsinks include this.
                    Cheers, Wizard
                    • Krankshaft
                      • Jan 2007
                      • 2328
                      Haha that to me looked like insect fecal deposits .
                      Don't you love how people think that twisting braided wire together then electrical taping them make a solid connection?
                      Soldering or crimp connectors are the ONLY way to go. I prefer soldering and heatshrink tubing for a nice polished look.
                      I can't stand the heatsink clips either. I seem to waste more time fiddling with them. Than I would just fastening 4 screws.
                      If you want to see a real PITA heat sink clamp. Look no further than the Xbox 360s it uses an X-Clamp which snaps into a grove on each of the 4 dowels extending from the CPU cooler. Torx screws later fasten into the dowels which secures the mobo to the metal EMI casing as evidenced by the holes.
                      https://www.globalconsoles.com/images/xclamps.jpg
                      http://blog.reloadsystems.net/wp-con...2082007065.jpg
                      It is the most poorly designed crap I have ever seen.
                      Not to mention I'm sure countless people have torn off SMT components rendering their boards useless. By trying to improperly remove these clamps by prying. Which almost every wrench turner online says to do.
                      When in essecence you are supposed to insert a screwdriver at the tip of each corner between the dowel and the clamp and push outward. Releasing the claw from the groove.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        I LOL'd at the PSU rewire.... I wish I'd have taken pics of what an 'IT' guy had done to an SX280.......you wouldn't believe me if I told you...
                        <--- Badcaps.net Founder
                        Badcaps.net Services:
                        Motherboard Repair Services
                        http://folding.stanford.edu/
                        Team : 49813
                        Join in!!
                        Team Stats
                        • Scenic
                          o.O
                          • Sep 2007
                          • 2642
                          *hides*
                          *head -> desk*
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            oh yes i would.
                            i have seen much worse than this.
                            like the guy who's dog chewed the power supply for his new at the time toshiba libretto.
                            "since the cord just goes through the brick i eliminated it"
                            yes it caught fire!
                            nobody was able to keep a straight face!
                            i know its not the best thing to do in the presence of a customer but i laughed my ass off!
                            or the owner of a big machine shop who i told several times the switch he was in danger of sticking his fingers in was live with 480 3ph and he was going to touch the live side.
                            he argued with me telling me he had turned it off till i told him to step aside and turned it on.
                            when the hydraulic pumps came on his face went white!
                            • gdement
                              • Jan 2007
                              • 690
                              ... Wow. That's some amazing logic there.
                              I got a phone call from an acquaintance who was buying ram for his computer, so he absent-mindedly popped it out of the machine to look at it. He immediately realized he shouldn't have done that.
                              But Windows didn't crash - it gave him a "memory size reduced" message and kept running. I found that part fascinating.
                              Problem is, that message made him think it was okay, like the RAM was hot swappable or something. So then he decided to put it back in. Of course it fried immediately and burned out everything. Such a shock he didn't have all the pins lined up perfectly when they touched.
                              Fortunately he couldn't see my face, but I really struggled to not sound like I was laughing at him. I'm not sure I succeeded.
                              • jpdoe
                                • May 2007
                                • 237
                                The problem is any idiot thinks he can fix computers. It seems people have a hard time figuring out their capabilities. The problem escalates when they ask the equally inept sales clerk/friend/coworker for advice, thinking he knows best.
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  LOL I would had expected a BSOD or lockup crash.
                                  ASRock B550 PG Velocita
                                  Ryzen 9 "Vermeer" 5900X
                                  Arc A770 16 GB
                                  eVGA Supernova G3 750W
                                  Alienware AW3423DWF OLED
                                    Lenovo ThinkPad X1 Extreme Notebook X Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad X1 Extreme Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Extreme boardview and X1 Extreme schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                    09-07-2024, 06:31 AM
                                    09-07-2024, 05:00 AM
