Headphones not detecting in XP
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys, I have a Toshiba Satellite a205 laptop running a fresh install of windows XP. I have been having some interesting issues with the headphone jack detection. If I plug headphones into the jack, the sound keeps playing from the speakers and not out of the headphones. The realtek audio manager also shows that there is nothing plugged in. If I leave the headphones plugged in and restart the computer with them in, when the computer boots up the sound will play from the headphones just fine. The thing is if you unplug the headphones the laptop will keep trying to play out the headphone jack and no sound will come from the speakers. The realtek audio manager shows that there are headphones connected to the jack even though there aren't. The only way to get the speakers back is to restart it again.
    I know the port itself is not the problem because it detects when the headphones are plugged in and unplugged perfectly fine on another installation of linux I have. My drivers are installed correctly and up to date. Any ideas what the problem could be?
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
    • 31161
    Re: Headphones not detecting in XP
    check the bios,
    if it has an Azalia sound chip then it can run in emulation mode pretending to be some old crap.
    • hasefroch
      • Apr 2013
      • 42
      • Argentina
      IIRC, that Toshiba is from the generation that was crippled to not work correctly in xp. Due to this, the usual suspects are:
      -Wrong driver (this means right chipset with bad connector assignment).
      -You have to either install the hotfix KB 888111 or have SP3 installed before installing the audio drivers or the audio codec won't be recognized accurately.
      I don't have the notes about the install anymore, but basically this it what I did:
      -Download the drivers for windows vista 32 bit from Toshiba's official web.
      -Unpack the driver with WinRar
      -Uninstall the actual driver. If necessary, cancel the prompt of 'new hardware'
      -From the unpacked driver, go to the folder MSHDQFE, select the correct version of the hotfix 888111 and install it. Reboot if prompted.
      -When the 'new hardware found' prompts, select the option to install manually and point it to the WDM folder from the driver unpacked.
      This should solve it.
      Some audio chipsets also require to delete a wrong registry entry generated for the old driver, so the new driver can write the correct config. Sadly, I can't recall exactly which one, only that was related to HDAUDIO (possibly HKEY_LOCAL_MACHINE/System/CurrentControlSet/Enum/HDAUDIO , but don't quote me on that).
      Hope this helps.
      • canadaboy25
        What is normal?
        • May 2013
        • 509
        Hope this helps.
        Thanks so much this fixed it. I already had SP3 installed so all I had to do was uninstall the old driver and install it again using the driver from the WDM folder.
        Thanks again.
        canadaboy25
        • atrace63
          • Oct 2016
          • 5
          You need to install driver.
          • jiroy
            • Jun 2016
            • 2416
            • Lebanon
            Although it might be a Drivers problem , but sometimes it's not . So before heading to reinstalling , Formatting or anything else , one should check and understand how Multimedia players work .
            Let's take for an example the VLC Player (Or any other player ) and start watching a movie or a song with it . If a Headphone is inserted , it won't produce sound , and it will act like it isn't there . From the VLC panel , click on Audio devices , and you'll see two or three options . One of them will be Headphones , click on it and the Headphones will pop up .
            • bohaboha
              how to install gl usb2.0 uvc camera device driver on windows 10
              by bohaboha
              Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
              but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
              any help?
              01-26-2025, 08:33 PM
            • harp
              how to install old display driver in win10
              by harp
              It is time to upgrade my system, so I want to extend working surface with second monitor. The graphics card is Asus EN6600LE Silencer with 256MB, and have DVI and VGA output connectors. I try to find pure *.inf drivers (like in old days...), but nothing package beside a hundereds and hundereds MB instead... At last, downloading a last driver (148MB) from https://www.driverscape.com/download...eforce-6600-gt but in it, thre is no readme, install, setup or working inf file... So, nowadays is instalation hardware pass a new level of rocket science or I miss something? Pleas help if you have...
              06-04-2025, 12:40 PM
            • ongobongo
              Radeon RX 6700 XT chrash while driver install, memory PWM-Driver?
              by ongobongo
              Hi guys,
              I have a new project, a PowerColor RX6700XT GPU which starts up fine but crashes as soon as some load comes up, the driver install is enough for this. The install won't succeed and the card crashes with ramping fans.
              What I figured out so far:
              As the card starts up, all voltages are there.
              The core rails seem to work fine, all of them run at 500KHz (measured with a normal multimeter as I don't have an oszilloskop at hand).
              That said, I think I have a problem with one of the memory rails. The top two drMOS on the right side (see picture) power the memory....
              09-15-2023, 12:57 PM
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • osrex
              LED DRIVER KEEPS DYING
              by osrex
              Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
              i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
              i have no datasheet at all for the LED lights, all i have is its length.
              long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
              as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
              05-05-2025, 03:36 PM
