Changing voltages.
  • ChaosLegionnaire
    HC Overclocker
    • Jul 2012
    • 3264
    • Singapore
    #81
    Re: Changing voltages.
    Originally posted by Spork Schivago
    So can I always fall back on dividing the number of switching mosfets by two?
    nope. some vrms are the "double forward switching" type or the "double output switching" type in that they have 1 mosfet per phase doing the input and 2 mosfets per phase doing the output. which means there are 3 mosfets per phase. counting the number of inductors is the way to go. just try to spot the smaller inductor by the atx12v connector and not count it! only count the same sized inductors!
    • Spork Schivago
      • Mar 2012
      • 4734
      • United States of America
      #82
      Gotcha, thank you!
      -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
      • Spork Schivago
        • Mar 2012
        • 4734
        #83
        Originally posted by diif
        The FSB was replaced by QPI - QuickPath Interconnect on the 1366 socket.
        The memory controller was moved to the CPU.
        So the CPU is directly connected to the RAM then, right? Isn't this what makes the 1366 and the 2011 sockets extremely fast? No bottleneck there anymore?
        I'm still waiting on the new power supply to arrive. When it does show up, I'll let you guys know if it fixes all the jumping voltages or if vCore is still bouncing around. On the 6th, my new iron is supposed to be here. Once that comes, I can start pulling caps if I need to. I'm thinking the PSU will arrive before the iron.
        • Spork Schivago
          • Mar 2012
          • 4734
          #84
          I received the new power supply today. Vcore and 5.00v are jumping a lot. 3.30 jumps every so often. 12.00v jumps very seldom but does jump. Fan speed is still changing just about as fast as vCore. I'm going to start looking at the caps now because my new 120 watt iron came as well.
            • 31011
            try the new psu on another computer - and use the scope.
            then you have a reference to compare against.
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              Have you tried disconnection things like the hard drive,ram and see if it still does it.Try disconnection they separately.
              • Spork Schivago
                • Mar 2012
                • 4734
                #87
                Kinda. I've disconnected the hard drive but not the RAM. I don't really see how the PC can POST without the RAM. Unless, of course, you mean just leaving one stick in and trying it. I don't think it'll be necessary though.
                I just got back from my friends death gathering stuff. I pulled the heat sink off and found the little bigger! One of those polymer caps right next to the CPU. I believe this isn't the best design. The heat from the heatsink will probably fry the caps. There's five caps total, idental. But four of them are in a row, the fifth one is up off by itself. I'm going to replace all of them.
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  #88
                  I believe these are 4v but are the 68uF or 680uF? I'm going to pull a working one and check the capacitance. I do have some nicer 6.3v 680uF polymer caps floating around here somewheres. If the ones on the board are 680uF, I'll use the nicer ones I have. They're Nichicon RL80J681MDN1KX. Even though they have a bit higher voltage rating, I think that'd be fine. So long as the ones on the board are 680uF and not 68uF. These Nichicon ones say 681. If those cheaper caps follow the same naming convention, I'd think the ones on the board are 68uF.
                    • 31011
                    hmm - cant ID them
                    http://capacitor.web.fc2.com/solidcapacitor.html
                    whatever they are, i'v never seen one like that before - tempted to ask to see one opened up - incase they arent poly's
                    • Spork Schivago
                      • Mar 2012
                      • 4734
                      #90
                      Originally posted by stj
                      hmm - cant ID them
                      Yeah, I couldn't find them either but I was looking at 680uF. The size is very hard to find at 4v 680uF. The only ones I could find that really matched the size (either roughly or exactly) where the Illinois Capacitor 687ULR4R0MFF.
                        • 31011
                        well you didnt say the size
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          #92
                          DIGITALTECH kinda fits, wrong colour though. The caps say:
                          89
                          680
                          4J.
                          I can try opening the bad one up tomorrow if you want. Just tell me the best way to do it. I'll pull a good one tomorrow and test it with my Peak Atlas ESR meter to figure out the capacitance for sure.
                          I figure they're probably real cheap.
                          • Spork Schivago
                            • Mar 2012
                            • 4734
                            #93
                            Whoops. Lead spacing (between the two terminals) is 3.5mm. The rest of the numbers might not be exact. I only have the one removed and it's bottom is blasted out a bit. Height (of just the metal can) seems to be 9mm, width seems to be 8mm. I think it's very hard to get 680uF, 4v in something that small. Makes me think that 680 is actually maybe 68uF. I thought for the VRM circuit though, these caps would be closer to 680uF. When I pull a good one tomorrow, I'll post the confirmed capacitance.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              #94
                              Okay, I pulled one real quick. I just couldn't wait. 0.02Ω ESR, 1380μF!!! That can't be right! 1380μF in this little package?? How can that be? If they're failing, could they actually register higher than what they're marked as? I can pull a couple others and test them if you'd like.
                                • 31011
                                lol - if your meter could show it i bet leakage is huge!
                                • ChaosLegionnaire
                                  HC Overclocker
                                  • Jul 2012
                                  • 3264
                                  • Singapore
                                  #96
                                  lol no way they are 68uF. that is too low capacitance for cpu vrm output use. they usually use 560-820uF polys for the output.
                                  also, i dont understand the part about the size being hard to find. there is an oscon sepc 560uF 4v 8x9mm part as well as lots of nichicon fpcaps available in the same size as well? were u thinking those were wet electrolytics caps on the vrm output? well, u need to watch those kzgs on the vrm input as well. those need to go as well!
                                  • Spork Schivago
                                    • Mar 2012
                                    • 4734
                                    #97
                                    Thank you for explaining this. I wondered if the VRM circuit used caps around that range. I was looking around the net (over the years) and they always seemed to fall somewheres around there. I wasn't sure though for certain. I know the boards I have around here are around there for the VRM stuff.
                                    What I meant about the size being hard to find, I cannot find very many 680uF 4v capacitors that are around the same physical size. The Illinois ones seem to fit. I could find the 560uF just fine, however, I'd like to stick with the 680uF if that's what these are. I've read many posts how people were switching out 680uF for 560uF OS-CON SEPC's with success.
                                    I do have some 6.3v 680uF Nichicon's that I'll probably try using first. If I didn't have them, I'd probably give the 560uF OS-CON's a shot. I heard they're supposed to be really good caps.
                                    So, what do you think about my ESR meter showing such a high capacitance? I'll start pulling the other ones and checking their capacitance / ESR.
                                    • Spork Schivago
                                      • Mar 2012
                                      • 4734
                                      #98
                                      I heard there's some Sanyo caps out there that people have been using as well and they're also supposed to be real good polymers...
                                      • Spork Schivago
                                        • Mar 2012
                                        • 4734
                                        #99
                                        My meter can detect leakage but not show it. It'll say Leaking / In-Circuit. I now always remove the caps to test them so I can ignore the In-Circuit part. For some reason though, with the cap I checked here, it didn't say anything about leaking...
                                          • 31011
                                          i have seen caps where the uF value shoots up, it is acompanied by very high leakage.
                                          • Capacitorial
                                            Powersupply has all the voltages - Monitor still no power
                                            by Capacitorial
                                            Hello guys,
                                            I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                            I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                            On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                            The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                            The weird thing is, that the Power LED is powered over the TCON board.
                                            On The TCON...
                                            12-28-2024, 02:12 PM
                                          • gjgib
                                            Help reading schematic voltages input/output
                                            by gjgib
                                            Hello, this might be embarassing since I consider it a dumb question but keeps me kinda stuck sometimes in my journey.
                                            I want to know if there is any post in this forum which explains my questions. A) When, where and how do I know when X voltage line is input or output. Example:
                                            I'm battling with this IC to understand it's voltages. It's from non-turning-on Lenovo Ideapad 3 15iil05 - NM-D461.
                                            I see some lines like +5VL / +5VALW / V9B+ / +3VALW being okay and some others like 1.8VALW / +0.6VS / +2.5V_DDR. I just know that some of them are bad or missing,...
                                            05-06-2024, 08:11 PM
                                          • RossMoodley1967
                                            HISENSE LCD LED TV MODEL HX40N2176F LED DRIVER SN51DP IC PINOUT AND VOLTAGES
                                            by RossMoodley1967
                                            Hello
                                            Need to know the voltages that will be present on SN51DP ic when tv is in standby and when powered on.
                                            Just to elaborate on the problem with the tv 1.set came in with flash of HISENSE logo on screen then back into standby.2. Now tv when plugged in red standby light present to quickly changes to blue but no backlights.3.Then an hour ago i checked again , came on standby and stayed until i pressed the power button which changed to power on (blue)4.As far as the led driver circuit goes voltage at output in standby was 38v , power on led light up voltages rise 58v-68v...
                                            03-01-2024, 06:07 AM
                                          • karlp028
                                            MSI Z390-A PRO missing VCORE voltages
                                            by karlp028
                                            I've got an MSI Z390-A Pro motherboard that starts up fine, but it's missing the VCORE (and VGT) voltages. All of the other voltages are present (e.g. VCCSA, VCCIO) and I know the CPU (i7-9700k) is good. Now, the original PWM controller (UP9521P) had an internal short and I replaced it with a new one. All of the enable signals look good. The problem seems to be the PWM signals going to the MOSFET drivers. I checked them with an oscilloscope and they are all flat 1.5V with no pulses. I don't know why this would be and I'm not sure where to look next.
                                            06-23-2025, 01:25 AM
                                          • lol999
                                            Asus Prime x299 Deluxe - no VCCIO VCCSA voltages
                                            by lol999
                                            Motherboard after starting show Q code 00.
                                            No shorts on any rail ( at last I can't finde any)
                                            All voltage are correct on SIO - 3.3V, PCH power 1V , DDR 1.2V, SPI 8 leg 3.3V
                                            Nothing get hot, PSU starting, all lights came ON....
                                            One thing i can see incorrect is no VCCIO and VCCSA voltages and no main power on CPU.
                                            After deep looking I found dead Synchronous Buck converter CSD97374Q4M that is powering VCCIO for CPU but after replacing it nothing changed. Voltages on it are correct....
                                            This buck converter is PWM'ed by Asus DigiVRM ASP1405I-62T. Can't finde any datasheet...
                                            01-21-2024, 02:25 PM
