Dead PC?
  • stevo1210
    • Oct 2006
    • 4156
    Dead PC?
    I am trying to help my friend out in trying to find solutions to why his PC refuses to boot now. I cannot see him for a while because he lives quite far from here.... so I've tried to help him fix it over the phone since he has some basic computer hardware knowledge. I know he has assembled a computer before so I can assure I know what he's doing
    This is the specs of his PC:
    * Intel Pentium 4 2.6GHz CPU
    * Asus P4P800-S motherboard
    * 1GB RAM
    * 2x IDE hard drives (IIRC, 1x 40GB, 1x 160GB)
    * LG DL DVDRW drive
    * LG DVD-ROM drive
    * 1.44MB Floppy drive
    * "400W" DEER PSU
    * ATi Radeon 512MB X1650 AGP graphics card
    I got a call from him last week about his computer not booting after he tried
    to take the CPU HSF off the motherboard for a cleanup and oiling because it was noisy. The HSF didn't come out because he didn't know how to unclip it from the HSF holder.... so he decided to lock the locking clips back into place.
    I came over and had a look at that and it turned out that the socket 478 CPU was stuck to the HSF (I was very surprised he didn't bend any pins even though the CPU was being forced into the socket by the HSF locking clip) , so I reseated the CPU, added some Arctic silver and it booted up fine with no issues.... it was fine for the whole week until yesterday night before I went off to bed.... I got another call from him.
    He said that he had gone off to dinner and turned off the PC and now it won't boot (and he needs to get some homework done).
    It doesn't beep (similar to when the CPU fell out of the socket), so he suspected the CPU fell out of the socket so he decides to take the HSF off and the CPU came off with it again. I then told him that CPUs can't fall out of sockets and that the thermal paste is dry so the CPU went with it as he pulled it out.
    So I told him to do what I did the other day.... he heated up the heatsink with a hairdryer and pryed it off. He checked the pins and none were bent or broken and reseated it in the socket and reclipped the HSF. Still he got no boot from his PC and it didn't beep either.
    I told him to reseat the RAM, expansion cards, etc. and it still would'nt boot. I then told him to measure the PSU voltages coming out of the P.O.S DEER rebranded 400W PSU by using a DMM. He jump started it with the wire techinique using two optical drives as the load on the PSU.
    These were the readings he got:
    5V SB (Purple wire) : 5.05V
    12V : 12.30V
    5V : 5.05V (IIRC)
    3.3V : 3.25V (IIRC)
    That's strange.... all the readings are in spec? but then again I think these are averages readings? and I guess that another thing called ripple current may have killed the board?
    I told him to touch the Intel ICH5 southbridge and he reported it as warm, but I don't know if that means dead southbridge yet?
    He also reported that recently he had been getting BSODs frequently which is a worry. I see PCs with crap PSUs get BSODs all the time, could that be the case here as well?.
    He also reported that now one of his Western digital hard drives are now making knocking noises. Doesn't sound too good there, but apparently he left it for a minute and rebooted it and the noise went away.
    Still there are no beeps from the PC and the screen is blank/ off. The motherboar LED is green on bootup, but green LED doesn't always mean good, my Asus K8N has a green LED and is actually dead from a crap PSU frying it.
    Usually there would be a bepp at bootup for system OK. I suspect that if RAM was loose or not in there, it would beep continuously or if the graphics card is loose, it would do the usual long beep three short beep message. I have the same motherboard powering my PC so I kinda have some idea of how the beeps go. When my P4P800S-X died, because of a crappy DEER PSU frying it, it didn't beep at all.... similar to what he is experiencing.
    Right now I don't know what could be wrong, but I want to help him get the computer running again because he's a really nice guy that i've known for so long.... and I don't want him to wonder down to the computer store and get ripped off like so many of my other clients.
    Thanks.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Dead PC?
    Changing PSU would probably be the next logical step i think. It does not hurt even if the board or some other component is shot.
    I think something in the 350 -400w range should be sufficient.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Dead PC?
      that deer is prime suspect.
      pop the lid and have a look.
      caps can be gone and voltage can be ok.
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Re: Dead PC?
        Hmmm ... a bad psu, shaking drives, an apparently dead motherboard: I agree with KC8, the Deer is suspect. Do you have a spare psu and another socket 478 mobo to test all components?
        Zandrax
        Have an happy life.
        • stevo1210
          • Oct 2006
          • 4156
          Re: Dead PC?
          My friend replaced the motherboard today and so far he's told me that the computer booted up and everything's fine. Apparently the power supply is still OK and he has not replaced it. It's a Deer PSU, but I'll try to convinvce him to change that to something decent as I don't really want him to fry another motherboard.
          Thanks.
          • ant3202
            • Jun 2006
            • 275
            • Singapore
            Re: Dead PC?
            Good PSu = GD HEART for components
            • gonzo0815
              • Feb 2006
              • 1600
              Re: Dead PC?
              Don`t worry, the dear will certainly make him an believer in good PSU`s, it`s his own choice how hard the lesson will be.
              What does he think has caused the death of his former board?
              • stevo1210
                • Oct 2006
                • 4156
                Re: Dead PC?
                I went over to my friends place today. And it appears that the new motherboard is an Asrock P4i65G. I don't favour Asrock boards, but hey if it works for him it's fine. I checked out the PSU and it hasn't been replace, it's still the old Deer.
                He has suspected that his old board died of old age or similar.
                Thanks.
                • gonzo0815
                  • Feb 2006
                  • 1600
                  Re: Dead PC?
                  I am absolutely an Asrock fan for the past several builds of my own. I simply love to thinker around with them and the great chip sets they have used.
                  But certainly, i do not recommend them to the novice, as sure as hell there are some trade-offs mad on those boards.
                  But sure, for this silly idiot, i think it will serve well, at least as long as he thinks it will die of age again.
                  For some simple-minded it pays out at then end, but i would not count on that.
                  • wyga
                    PS4 Original CUH-1006A, dead, no beep, no shorts, power supply good, dead ic?
                    by wyga
                    So I've got that console PS4 Original model CUH-1006A logic board SAA-001
                    The console suddenly has stopped working.
                    First there was no beep upon pressing the power button, but eject button will give us a reaction. Then after replacing PSU by original owner with exactly same model it completely stopped working. No beep, no reaction at all.
                    I personally think it is pure coincidence and some IC just died over the time.
                    Both power supplies are good, checked them inside and are working with the other board with BLOD.
                    I have...
                    02-10-2021, 04:21 AM
                  • double_DD
                    How can I be sure that my EC chip is dead?
                    by double_DD
                    As the title suggests, how can I be sure that my EC chip is really dead?
                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                    03-12-2025, 07:47 AM
                  • Docus
                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                    by Docus
                    Hi everyone 😀,
                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                    06-10-2025, 04:24 PM
                  • Beton
                    Finding a dead short component
                    by Beton
                    Hi guys!
                    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                    I have a bench PSU and if I try to inject voltage the voltage...
                    12-10-2021, 01:05 PM
                  • zunasthegreat
                    Chieftec GPS-450-AA with dead 20N60C3
                    by zunasthegreat
                    Hello everyone hope all doing well!
                    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                    09-01-2024, 07:12 PM
