New Skylake system for a customer, getting low memory problems (win7)
    • 30972
    Re: New Skylake system for a customer, getting low memory problems (win7)
    does this happen if the networking is down?
    i just realised it maybe be doing something in the background - like mining for bitcoins.
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      I'd suggest setting the page file to 4GB fixed. Then, upgrade to Windows 10. That should fix it!
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        It happenes later on a haswell system. Its related to how low the Samsung magician sets the page file, and the fact taking so many damn updates (190+) from a fresh install of windows 7 sp1, and the fact installing updates uses very little ram and mostly the swap file
        • Hondaman
          USB problems?
          by Hondaman
          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
          08-12-2024, 03:26 PM
        • mecha1166
          Anyone here fix a tv and customer cracks panel when they get it home?
          by mecha1166
          About 2 times a year, a customer will do this. We fix the tv, put it on test play, and customer sees it working. They see me pull power and video wire. Sometimes I pick up tv, right in front of them, and carry it out to their vehicle while they are next to me. I set it in their tv gently, and tell them the tv is very fragile, be careful with it. I let them close the door/trunk. That day, or a few days later, they tell me there is a crack inside the tv. Normally I tell them transportation is their responsibility and normally that is the end of it. Has anyone had a customer that was not buying this...
          03-29-2024, 11:27 AM
        • jean luc ferre
          laptop hp g72 b52sf screen problems
          by jean luc ferre
          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
          06-07-2025, 03:27 PM
        • eccerr0r
          win7 home iso? can I get 10?
          by eccerr0r
          Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
          So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
          09-14-2023, 07:35 AM
        • clabr
          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
          by clabr
          Need help to solve some problems with this laptop.
          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
          Before this had happened I observed some other problems:
          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
          12-02-2021, 08:09 AM
