Win7 Emulation in Linux
  • Hondaman
    • Sep 2008
    • 1116
    If I install Win7 in VirtualBox or KVM, will Windows be tied to that exact hardware? Can I take the VM and move it to another machine at some point without having to re-activate Win7?
    I bought a replacement board identical to the one Win7 is licensed on. But of course it failed. I have two more identical boards in my basement. Running out of acceptable hardware will not happen for quite a few years, hopefully.
    But I am looking forward to that day when I cannot find any hardware, and I have to use emulation. Does anyone have experience with this?
    • 32067
    wine works well,
    and most VM's let you create a virtual hardware setup.
    • Hondaman
      • Sep 2008
      • 1116
      Which emulators should I try? I have a couple of AMD 5350 test machines, how much RAM will I need? (I have plenty of DDR-3 1600 MHz lying around the house, and hardware that uses it.)
      I do have experience with Crossover, it works well with Office 97 and 2003, I should probably install it immediately.
      Also, I have a KVM switch. On the "other side" of the KVM I have an old i3-3245 system with Mythbuntu 12.10 (I used it to watch television with the HDHomeRun Dual back in the day). I never use it anymore, maybe I should scrap that machine. Maybe my "main" machine (I have two more motherboards I bought new) will now become the "backup" machine (like the i3-3245 used to be). My new "main" machine will be a nice new Ryzen machine like the one suggested in this thread: https://www.badcaps.net/forum/genera...-advice-needed.
      I have CDs of Win98 first AND second edition, maybe I could replace the i3-3245 machine with an AMD 5350 machine to "play around" with virtual machines. Could I tell the VM to pretend I have the same bridge chips (as an example) that my 32-bit single-core AMD Athlon 2900 has? This could be interesting.
        • 32067
        start by going to wine-hq
        https://www.winehq.org/
        and installing the beta version.
        because it's faster than VM methods.
        also before you start, make sure your linux is setup for "MultiArch".
        that is the ability to run 32bit software on a 64bit system.
        because the sad joke is a lot of windoze stuff is still 32bit.
        as for VM's you need to research it, VMware was best but it's gone all cloud-shit thanks to broadcom
        • Hondaman
          Japanese language -- Win7 or Linux Mint?
          by Hondaman
          I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
          Does anyone have experience...
          09-12-2025, 04:32 AM
        • Boardview and Schematic Bot
          ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
          This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-12-2024, 03:28 PM
        • portal7
          Dell Latitude 5440 - Help reading dual Winbond SPI flash in-circuit with CH341A on Linux
          by portal7
          I’m working on a relatively new Dell Latitude 5440, Intel i5 model, and I’m trying to make clean backups of the onboard SPI flash chips without desoldering, if possible.
          The motherboard has two Winbond SPI flash ICs close to each other:
          - UC2: Winbond 25Q256JVEN, likely 32 MB
          - UC6: Winbond 25R128JVSN, appears to be 16 MB
          I’m using a CH341A programmer with a SOIC8 clip on Linux.
          Tools tested:
          - flashrom on Linux
          - IMSProg GUI on Linux
          With flashrom, UC6 is sometimes detected...
          05-14-2026, 12:26 PM
        • double_DD
          Illy Y5 coffee machine - touch buttons broken and need repair
          by double_DD
          First and foremost, I'd like to wish everyone here a happy and successful new 2026!
          Now, let's dive into my current issue. Once again I'm stuck and would like some advices from someone smarter than me.
          I have this coffee machine, Illy Y5, that has a glass top with fancy touch controls. Something was wrong with it, and in the process of multiple openings and closings I managed to break the ribbon connecting the buttons to the circuit board. And as luck usually goes, this happened just a few days after we ordered a new batch of capsules for it. :/...
          01-07-2026, 06:59 AM
        • eccerr0r
          win7 home iso? can I get 10?
          by eccerr0r
          Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
          So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
          09-14-2023, 07:35 AM
