Data Recovery
  • goontron
    5000!
    • Dec 2011
    • 4108
    • US
    Re: Data Recovery
    Originally posted by eccerr0r
    rooted? Is that default when you buy any phone?
    You can flash the firmware with the phone itself without another machine?
    No root needed if it's signed..... Also, some phones are pre rooted. take oneplus line of devices for example.
    Follow the white rabbit.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      Re: Data Recovery
      did you look for a window old folder?
      otherwise hope the new install didnt overwrite anything important as it is gone for good unless you are a tla with unlimited budget.tell them to stop messing with it till you run recovery software as every disk write threatens the remaining recoverable data.
      as for why the methods are not talked about the reason is that most folks will not be able to do many of these operations safely and will make a bigger mess.some of the customer recovery attempts that i have gotten shipped to me should be listed by the D.O.D under methods of data sanitation when you dont have time for a guttman wipe.and those of us who develop ways to repair faults in drives to recover the data wont give away our work free.would you give away your paycheck?
      • Agent24
        I see dead caps
        • Oct 2007
        • 4940
        • New Zealand
        Re: Data Recovery
        Originally posted by kaboom
        But the backup drive is never left hot in a system, except when backing up/recovering.
        Arguably you shouldn't even do that, Murphy will get you when the PSU blows up and takes out both drives.
        Use 2 separate computers and copy across network.
        Call it the PEBCAK wipe?
        -David VanHorn
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          Re: Data Recovery
          yes.like getting a tottaly dissasembled drive in a baggie that had been shipped from singapore in a bubble mailer.at least it was a common single platter unit and was an easy save in spite of the owners attempt to trash it.
          or one that was "cleaned" with sandpaper and brillo pads.told the guy to keep it unless he wanted it used as an example of what not to do to a drive containing irreplaceable data.
          hard to recover anything from dust around his place.and i doubt a tla could do anything with it regardless of budget!
          • Agent24
            I see dead caps
            • Oct 2007
            • 4940
            • New Zealand
            Re: Data Recovery
            -David VanHorn
            • artois7
              • Mar 2011
              • 159
              #26
              Re: Data Recovery
              Originally posted by fzabkar
              I recommend DMDE. The freeware version has an excellent disc editor and can recover a lot of damaged drives. The full version (US$20) is a powerful data recovery tool.
              http://dmde.com/
              In the disc editor, go to sector 0 and drag your cursor down the vertical scrollbar. If every sector (past the formatted area at the beginning) is full of zeros, then the drive will have been wiped. Otherwise the data should still be there.
              If you have removed the drive from an external enclosure and installed it inside your computer, then be aware that some external drives (eg WD My Book Essentials) are hardware encrypted. The USB-SATA bridge PCB inside the enclosure handles the encryption/decryption. If you install such a drive inside your PC, all you will see will be gibberish. Furthermore, WD and Seagate external 3TB+ drives use 4KB sectoring. If you install such a drive inside your PC, you will expose its native 512B sectoring and render the file system inaccessible. Essentially you will have a 4Kn file system on a 512e drive.
              PhotoRec (freeware) searches for files on the basis of their headers. For example, JPEGs may have "JFIF" text in the header while GIF files begin with "GIF89a". Usually such files will be recovered without file names. That's because the original MFT will have been destroyed by the formatting process.
              Data recovery professionals recommend R-Studio and UFS Explorer. Some use GetDataBack.
              The freeware version of DMDE will allow you to perform an NTFS search. This will find all remnants of the previous file system. You will be able to recover a limited amount of data, but at least you will see whether recovery is possible.
              DMDE did a good enough job; the 'free' limitation of 4k files just means that you have to select all, recover 4k, it will automatically deselect those 4k files so you can continue recovering them 4k at a time.
              That combined with EaseUS Data Wizard did fairly well. I ended up just giving the user an external harddrive with every image file I could find, 70% of it being corrupted, rubbish data. Lots of good stuff in there though.
              Told the user they had to painstakingly go through every folder and the 100's of thousands of files recovered and manually pick out the good data. Figured it would be a good lesson to call me *before* it all goes wrong next time.
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3264
                • Singapore
                #27
                Re: Data Recovery
                omgwtfbbq that sounds familiar... remember reading about something like that in my local computer hardware forum. i can also tell u that it wasnt me. i may be a nub but i'm not that big of a nub.
                i also read another story in my local forums of a guy who wanted to open up his hard drive to fix whatever was wrong with it. the pros told him dont! not unless u have a cleanroom. then he insisted that his room was very clean and very well cleaned (by his mother, i'd bet...) and went ahead and opened his hard drive anyway. "oh my hard drive has a broken head. no wonder it wouldnt work!", he says. :S boy i cant describe how hot he got flamed on the forums for that.
                moral of these stories, dont even think u can fix a hard drive by dicking around with it. u just dont... pfft...
                • kingiii
                  Possbility of data recovery, is it true?
                  by kingiii
                  Hello, A customer told us that there is a data recovery company that can by pass IMac pro 2020 with t2 chipset GPU to get their data back, I am wondering if that is possible. GPU is shorted and Imac wont boot at all. I informed customers that data are almost impossible to be retrived, and they are upset and think we are BS them. Of course being up in Canada, people like to believe that usa will have a better solution for it, a US data recovery company they searched on google told customer that they could get the data back without needing worry about T2 chip or Imac not working all that, I do not...
                  07-02-2025, 02:29 PM
                • DoOm86
                  Swap nand flash smartphone for data recovery
                  by DoOm86
                  Hello everyone.
                  I would like to know more about the following topic:
                  Nand flash on smartphone for data recovery.
                  I have been reading of people swapping nand flash from a faulty mainboard to another in order to save the data.
                  But I also read about encrypted data which to be read must been swap also cpu, or nfc or something else where is located the key to make the data being readable.
                  How does it works? How do I know if data are encrypted or where is the key?
                  I know there are also very expensive external socket where you can put the nand flash in...
                  08-20-2023, 07:10 AM
                • abajor
                  Attempting Data Recovery WD20EARS series HDD Reads as 0 byte drive.
                  by abajor
                  I was wondering if there is a knowledge base on troubleshooting HDD failures and when it might be viable to try certain repair/recovery techniques.
                  I recently got a WD20EARS 2TB Drive from a customer in hopes of retrieving data. The drive reads as zero size, I can't hear any head activity but it does appear the platter is spinning I can feel some gyroscopic action picking up the drive.
                  As a shot it the dark I bought a donor board and swapped the rom chip. Same issue zero byte drive.
                  I'm assuming that the armature is no longer functional internally so no data can...
                  05-18-2024, 08:35 PM
                • welcometoo
                  acer nitro 5 AN515-55 no display / caps lock
                  by welcometoo
                  Hi brothers, please i need help diagnose acer nitro 5 no display issue.
                  model: nitro 5 an515-55
                  motherboard part number: GH51M LA-K862P Rev: 1A
                  i received this laptop with a short in power line, it was a capacitor + a mosfet on VCORE line , the laptop turned on cpu and gpu getting warm all voltages seem ok except vcc_gt but no display/caps lock activity also no hdmi out.
                  i flashed new bios also ec(ene kb9022) the same result .
                  disabled discrete graphics (rtx 3060 ) by cutting its power and shifting a resisror near pch VCC_GT comes but still the same...
                  07-05-2025, 11:11 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
