Attempting Data Recovery WD20EARS series HDD Reads as 0 byte drive.
  • abajor
    • 178
    I was wondering if there is a knowledge base on troubleshooting HDD failures and when it might be viable to try certain repair/recovery techniques.
    I recently got a WD20EARS 2TB Drive from a customer in hopes of retrieving data. The drive reads as zero size, I can't hear any head activity but it does appear the platter is spinning I can feel some gyroscopic action picking up the drive.
    As a shot it the dark I bought a donor board and swapped the rom chip. Same issue zero byte drive.
    I'm assuming that the armature is no longer functional internally so no data can be extracted from the Drive without clean room data recovery services, but would like any second opinions on whether or not there is anything else I can try.
    Thanks.
  • ikelectro
    After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
    by ikelectro
    Schematic : DAOP5EMB6E0 REV:E​
    I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
    Any help or guide to proceed?...
    03-19-2025, 08:17 PM
  • vbogoev
    Lenovo S6000 won't turn on. Data recovery needed.
    by vbogoev
    Here I have the mentioned tablet with motherboard s6000-mb-h401. The tablet won't turn on, no display, charging normally. I manage to connect to UART port and got this output when I try to start it:
    Code:
    [PWRAP] pwrap_init_preloader
    [PWRAP] pwrap_init
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=0 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=1 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=2 rdata=5AA5
    [PWRAP] _pwrap_init_sidly [Read Test] pass,SIDLY=3 rdata=5AA5
    [PMIC_WRAP]wrap_init pass,the return
    06-20-2023, 06:36 AM
  • federalhouse
    **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
    by federalhouse
    I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
    **Background:**
    I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
    **What I've Tried So Far:**
    1. I accessed
    08-01-2024, 07:03 PM
  • perfm2
    HP EliteBook Folio 1040 G2 won't detect a drive after reformat.
    by perfm2
    So I've worked on dozens of HP and Dell laptops and have never encountered this before.
    Steps taken in my usual process.
    Reset security settings in the BIOS
    Ensure existing HD comes up into the OS
    Shut down the laptop and disconnected the main battery
    Removed old M2 drive and replaced with a new 1tb Mushkin Temptest NVME drive. (I'm aware the bus is Sata III but the drive should still work at a slower speed right? Been my experience in other laptops)
    Replace battery connector and close up the laptop
    Insert my USB drive with my Windows 10 image I've...
    03-21-2023, 08:45 PM
  • reformatt
    Intel iMacs, 3rd party SSD failures and Fusion setups
    by reformatt
    I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
    As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
    So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
    12-18-2024, 10:34 PM
