Dropped PC - Bad HDD?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    So between the truck and the building at LANfest my friend dropped my computer. It seems to boot and SMART data shows no bad sectors but the read errors are going up rapidly. Is it broken?
    • 31278
    Re: Dropped PC - Bad HDD?
    any cables loose?
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Originally posted by stj
      any cables loose?
      Didn't even pop the side panel yet Everything seems to be working perfectly. I'll run an HDtune error scan and a SeaTools long test when I catch a few hours of sleep. So far so good. Basically it fell off the cart and everybody was like "OOOHHHH..." Thank god it was a shitty Dell Vostro 230 case (not the orignal internals of cuorse) not some fancy thing
        • 31278
        i have a case for that type of treatment - came from ebay.
        it has big rubber corners like a speaker box, and a handle on top.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          My laptop would not have even noticed the sudden change in height.
          Follow the white rabbit.
          • shovenose
            Send Doge Memes
            • Aug 2010
            • 6575
            So far nothing seems wrong just a massive amount of raw read errors and seek error rate and that number keeps getting higher and higher insanely quickly.
            • mathog
              • Mar 2010
              • 2655
              In my experience once the error rates start ramping up on a disk, any error rates, the device will soon become useless. Dropping it may have broken off/knocked loose a bit of grit which is now dancing around on the platters. Get any data you want off that disk now.
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                yeah, that HDD is a goner... swap it NOW.
                sigpic
                (Insert witty quote here)
                • shovenose
                  Send Doge Memes
                  • Aug 2010
                  • 6575
                  Even if everything appears to be functioning normally and no bad sectors or pending sectors show up in the SMART data? I'm running a SeaTools Long Test on it at this time.
                  • Mad_Professor
                    A Mech Warrior
                    • Feb 2011
                    • 1587
                    What brand of drive?
                    Three years ago I knocked off a running 2TB samsung bare drive off my desk on to the floor, it made a loud bang. I thought for sure the drive was toasted. It was fine, the read and seek error rate kept climbing though. The drive is still running today without issues and in my desktop now.
                    • shovenose
                      Send Doge Memes
                      • Aug 2010
                      • 6575
                      Originally posted by mad_professor
                      what brand of drive?
                      Three years ago i knocked off a running 2tb samsung bare drive off my desk on to the floor, it made a loud bang. I thought for sure the drive was toasted. It was fine, the read and seek error rate kept climbing though. The drive is still running today without issues and in my desktop now.
                      st2000dm001
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        SMART won't show any bad sectors until it reads them.
                        • Mad_Professor
                          A Mech Warrior
                          • Feb 2011
                          • 1587
                          st2000dm001
                          You're fucked.
                          Backup that data.
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Originally posted by Mad_Professor
                            You're fucked.
                            Backup that data.
                            ok buying new hdd tomorrow.
                            • kevin!
                              recapping PCB.
                              • Jul 2013
                              • 195
                              • España
                              Errors in readings Seagate is a wrong value.
                              All seagates always worth reading errors are rising steadily, and this does not indicate a failure.
                              Look at my Seagate, it has the value of read errors that continues to rise, and already has 87,000 hours
                              The disc you can use, but do not use to store important things.
                              if the computer, she fell, off, I can say that this hard drive has not passed anything, because when you park off, and has a mechanism, in case of fall, the heads not moving.
                              Bye
                              Gaming pc:
                              nVidia RTX 3080 TI, Corsair RM750I.
                              Workshop PC:
                              Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                              Server:
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                See here:
                                https://www.backblaze.com/blog-smart...014-8.html#S7R
                                And here (SMART 1: Read_Error_Rate):
                                https://www.backblaze.com/blog/hard-drive-smart-stats/
                                • SteveNielsen
                                  Retired Tech
                                  • Jun 2012
                                  • 2327
                                  All drives get read errors. They are going to increase over time. The SMART read error rate is basically useless information as the links that Per gives show. In addition, it doesn't tell us what sectors are associated with the errors, it could be the same sectors giving read errors over and over again. It does not indicate the drive will fail soon. Of course back up data important to you, which should be done anyway, continue to use the drive and keep an eye on it. I have seen LOTS of drives suffer a fall (in and out of computers) and keep working just fine for years. If you want to replace the drive anyway of course that is your choice.
                                  • Wester547
                                    • Nov 2011
                                    • 1268
                                    • USA.
                                    Bye
                                    Your drive not only has 87,157 power on hours but 2,348,146 power cycles. That's over 2 million power cycles! Don't you think that's a tad unhealty?
                                    I would also recommend replacing the OP's drive. Modern Seagate drives (desktop drives at least) aren't very good anyway.
                                    • SteveNielsen
                                      Retired Tech
                                      • Jun 2012
                                      • 2327
                                      I don't know, I've seen just about all makes fail prematurely and I've seen all makes take a beating and get bad sectors and go on working fine for years. Modern drives in general aren't very good in my opinion. I don't always trust SMART data either. It's better than nothing to monitor disk condition though.
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Personally I prefer Seagate over WD in recent years. 7200.11 and 7200.10 series were crap though. I have deployed many ST1000DM003 through clients, friends, personal computers, and work and have had good luck. The few WD10EZEX I have used have been good as well.
                                        The older WD Blacks and Greens are absolute garbage. The latest ones are fine. It bothers me they have a half dozen series now though.
                                          Component tester which one is worth the money from it capability to test and identify
                                          I am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
                                          Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
                                          There are so many versions of this type of device and I do not have enough information to make a good decision at this point
                                          When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise (...
                                          06-30-2022, 08:23 PM
                                        • spleenharvester
                                          TP-Link Kasa KP105 - rapidly power cycling when plugged in
                                          by spleenharvester
                                          One of my KP105 smart plugs failed today. It started very rapidly power cycling (you could hear the relay clicking on and off and the LED was going green/orange repeatedly).
                                          I was going to just bin it but I opened it up out of curiosity. Found a swollen cap in the corner (bottom right of image). AiSHi brand, 470uF 10V 105*C. Not sure what purpose it serves exactly so can't comment on whether it is appropriately specced. Other members of this forum have reported similar findings with off-brand smart plugs but this is the first time I have seen evidence of this happening with a brand...
                                          05-21-2025, 11:26 AM
                                        • Jembang
                                          coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
                                          by Jembang
                                          good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
                                          11-01-2024, 09:55 AM
                                        • ranchhandbumper
                                          1992 Toyota Truck Speedometer
                                          by ranchhandbumper
                                          I am working on a 1992 Toyota pickup that has an electric speedometer. It is an analog needle speedometer and is driven by electricity.There is no cable. The transmission has a reed switch that sends a 12 volt pulse to the speedo 4 times per tire rotation.
                                          According to GPS, the speedo is showing speed progressively slower below 50mph and progressively faster above 50mph. This also affects the odometer.
                                          I've included a photo of the findings. The "control" is information I found on the net that correlates expected MPH based on a given hertz.
                                          I removed...
                                          11-12-2022, 08:12 PM
                                        • fuxxy
                                          Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                                          by fuxxy
                                          This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                                          Plug the set in, and it will turn on and functions with no issues.
                                          After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                                          Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                                          08-02-2022, 09:44 AM
