TP-Link Kasa KP105 - rapidly power cycling when plugged in
  • spleenharvester
    • Mar 2010
    • 913
    One of my KP105 smart plugs failed today. It started very rapidly power cycling (you could hear the relay clicking on and off and the LED was going green/orange repeatedly).
    I was going to just bin it but I opened it up out of curiosity. Found a swollen cap in the corner (bottom right of image). AiSHi brand, 470uF 10V 105*C. Not sure what purpose it serves exactly so can't comment on whether it is appropriately specced. Other members of this forum have reported similar findings with off-brand smart plugs but this is the first time I have seen evidence of this happening with a brand like TP-Link. This seems to be a common failure mode looking at their forums so I bet there are a lot of these out there.
    Anyway I don't plan on repairing it as I smashed the casing with a hammer to remove it. But if you want to try and repair it in a manner that does not involve a hammer, there are 7 clips you need to overcome - one at the bottom, two on the sides and two at the top. You will have a really hard time getting it open but with the right tools it might be possible to do non-destructively.
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 913
    Just smashed a fully working one open, this time a Tapo P100 (I trust none of them now so a worthy sacrifice) - it has an identical PCB (2084500437) and an identical spec capacitor in that position but it is ChengX brand this time. It isn't vented but these plugs have not had the same amount of use so I am not certain this issue is fixed.
    I can't see any date or batch codes on them that clearly indicate which might belong to a faulty batch
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8296
      Usually what makes them not work are bad capacitors, cracked solder joints and bad flash, doesn’t matter what brand. These things are so cheap, mass produced, manufacturing cost cutting, expect cheap. But cheap works too, if you know how to fix it.
      • Agent24
        I see dead caps
        • Oct 2007
        • 5016
        • New Zealand
        Bad capacitor can't hold up the voltage supply to the circuit, when the relay pulls in and draws current, the voltage sags, and the CPU resets...
        -David VanHorn
        • spleenharvester
          • Mar 2010
          • 913
          Does anyone know of a smart plug that doesn't have this problem? It seems like it has been reported to occur with every Kasa/Tapo plug. Not really sure what to do about these other than go back to the old analog timers. I only have 1 alive now
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8296
            I’ve got some Shelly smart plugs. So far I had one device with cracked solder joints that lives in a light switch. Quite tight in there too. Some Shelly devices can run on low voltage DC. Got my air exchanger hooked up to a Shelly running on 12v DC. Then I run 2 smart Shelly smart plugs on the Shelly button to turn stuff on and off.
              • 31161
              i run a rocker-switch.
              it's 100% reliable
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8296
                it's 100% reliable
                Broke those too before.
                • spleenharvester
                  • Mar 2010
                  • 913
                  I tried out some Meross plugs but couldn't get the app to work, it kept telling me to connect to WiFi even though it was already connected. So I've caved and bought some more Tapos and will just fix them when they break. But I just checked my last working P100 out of curiosity and there isn't a junk high ESR AiSHi cap like in the OP, instead there's a low ESR cap so maybe they've resolved the problem?
                  • CapLeaker
                    Leaking Member
                    • Dec 2014
                    • 8296
                    Cap suppliers change. If there is a cent to save, the cheaper one goes in. Profit has to be made after all.
                    • spleenharvester
                      • Mar 2010
                      • 913
                      FWIW I received the brand new Tapos today and they also have the new low ESR caps instead of the junk AiSHi normal-ESR ones on the failed units, time will tell if they're more reliable
                      • Shinju
                        Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                        by Shinju
                        Hey All!
                        Long time forum member here with a problematic laptop issue!
                        I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                        The laptop would not power on with the new battery installed without the power supply being plugged in.
                        When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                        TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                        10-20-2021, 04:58 PM
                      • usbdevice
                        Acer X223HQ (Version Bbd) on/off-power-cycling
                        by usbdevice
                        Hi all
                        There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
                        https://www.badcaps.net/forum/showthread.php?t=50657
                        https://www.badcaps.net/forum/showthread.php?t=40512
                        The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
                        It's my dad's old monitor. He...
                        08-05-2022, 02:21 AM
                      • high-tech
                        Samsung UN55F7050AFXZA ver. TD01 power cycling
                        by high-tech
                        Hello everybody, I could use some help on this one... It's got me guessing...
                        I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
                        (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
                        (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
                        (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
                        (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
                        9. ground (PWM2) 10. 0.9 volts cycling...
                        09-15-2020, 03:39 PM
                      • dbuergi
                        MacBook A2141 one USB port dead and one power cycling
                        by dbuergi
                        I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
                        Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
                        04-25-2025, 11:40 AM
                      • mon2
                        A2141 820-01700 Power cycling (DFU worked ok)
                        by mon2
                        Hi. Working on an A2141 that is power cycling. Powers up fine (20V @ 3.1A peak) -> fan spins ok and then at a higher speed (after we removed the trackpad so the sensors are missing) -> chimes ok but after the high fan spin -> power cycles and repeats this loop. We did manage to DFU the unit with revive mode (4/4 steps completed ok) -> resulted in a brief padlock graphic before power cycling. Unable to toggle the keycaps led since the boot does not reach this far of the cycle.
                        Q: Does the DFU process validate that the nand flash is OK ? We do not wish to restore this board...
                        11-24-2023, 12:17 PM
