Windows 7 Networking Woes
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Preface: I'm posting it here since it seems to be more of a software issue than a networking hardware issue. Also, a rant to start:
    Right now I'm in windows 7 repair hell with my wife's laptop... It still has the crappy stock dell image of 7 home premium... which I cannot reimage because she "HAS" to have microshaft office 2007 which was either pre-installed or more likely installed by her dad... I use libreoffice, so I don't have a copy of such.
    Anyway, I've mostly fixed the POS, a beat to hell lame ass inspiron with an i3 and 3GB of RAM... I'd like to shelf the turd and give her my ASUS x83v + a new battery (which is one generation older but tons faster) but noooo I can't do that.
    Anyway, now that I've cleaned five tons of horseshit off it (malware and the like), I've almost gotten it to the point of running OK (given the meager hardware) but there is one issue that I can't seem to nail down. For some reason I can't get it to see anything on the network other than itself and one of my workstations; I'd like to map the shared folder on the home file server to a network drive and then access a printer connected to the server like I've done on everything else in the house.
    I've disabled homegroup, re-enabled network discovery, correctly set the workgroup (which isn't "WORKGROUP" or "MSHOME")... but all it sees is itself and a workstation on the network. Manually using the "//address" trick in the address bar didn't work either.
    I'm sure it's the laptop and not the server, as every other unit in the house seems to talk to the server just fine.
    Suggestions (I repeat, she won't let me re-install windows or replace the turd)?
    sigpic
    (Insert witty quote here)
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: Windows 7 Networking Woes
    Sounds like messed up network protocols to me. Perhaps malware caused. Check the status of installed protocols for Windows Networking and uninstall/reinstall.
    Also Windows File Sharing.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      use jellybean to get the 2007 key then wipe and reinstall.
      I know how you feel on the network drive mount part of it..... i wasnt aware that "smbmount" was deprecated by "mount.cifs". i just learned that. my reaction was: "really!!! now i have to go relearn the syntax and how to debug the goddamned thing?!?!? for fuck sakes!"
      Follow the white rabbit.
      • Mad_Professor
        A Mech Warrior
        • Feb 2011
        • 1587
        Firewall?
        check services.msc for Server, Workstation, TCP/IP NetBIOS Helper, and Background Intelligent Transfer Service are started and running.
        Also it's backslash not forward slash. \\fileserver
        It's not wise to map a drive with all this ransom-ware running around.
        • ddscentral
          • Mar 2008
          • 151
          • Lithuania, EU
          I usually don't bother cleaning messed up Windows installations and just reinstall instead.
          Malware and Junkware can mess up the system badly and sometimes cleaning existing Windows installation may be next to impossible or too time consuming.
          • seanc
            • Nov 2008
            • 1319
            Open an admin command prompt and reset the network stacks with the following 2 commands:
            netsh int ip reset
            netsh winsock reset (I think) might need to be:
            netsh winsock reset resetlog.txt
            Check what Madprofessor says.
            He's right, it is backward slash, try and map using IP address.
            Use the map network drive option in Computer and specify the right credentials too.
            Has she had any Blackberry software installed?
              • 31204
              care to expand on the "Blackberry" bit?
              • diif
                • Feb 2014
                • 6978
                • England
                I'd take the i3 over the Asus. Buy her an SSD if you want to speed the thing up.
                Have you run sfc /scannow from an elevated command prompt ?
                Clearing malware is easy it's repairing the damage they do that is tricky.
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  First, the whole reason I CAN'T reinstall windows is the f*cking MS office install she HAS to have. Otherwise, I'd wipe it and be done. It already has SLIC for 7 so I'd just throw on ultimate. But NOOO that won't work... she's addicted to sucking bill gates soft(ware) dick when it comes to word processing.
                  SSDs are presently out of budget, at least in the size needed for her ripped movie collection she also "MUST" have. The POS has an i3 and only 3gb of ram (IIRC running 64 bit 7 home premium.
                  I'll look into it more. Agreed that the services could be fucked. For some reason I remember home premium giving hell about this in the past (I generally use 7 ultimate + SLIC mod or use one of my 3 upgrade keys).
                  MP- I've been mapping network drives for years at the house (me + my parents) and never had an issue... the wifi is WPA2 protected so that shouldn't be an issue.
                  sigpic
                  • Sweet & Spicy
                    Techie's Wife
                    • Apr 2013
                    • 281
                    (this is ratdude posting from her account, as I didn't want to dick up her chrome settings and am too lazy to add another account on this POS laptop or grab another laptop)
                    Now it is seeing another desktop too... but still no server. I tried the backslashes, no bueno. I can however talk to the server via PuTTY without issues.
                    I tried to uninstall and reinstall the windows networking client... but when I went to re-install, all the clients and services (and all but one of the protocols) are GONE from the install menu (only option is the "have disk" button). WTF?
                    I wanna baseball bat this POS so bad right now... the joys of married life...
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Understood. So what is needed is to repair the existing Windows installation. Period. It is very tedious but it is within the realm of possibilities. You have to somehow find and replace corrupted system files. You have to find and remove all registry keys referencing malware associated files and processes.
                      Look into HijackThis
                      http://sourceforge.net/projects/hjt/
                      Doing the sfc /scannow is good idea too, but it often won't catch everything.
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        You may be required to reinstall Service Pack 1 and all Windows hotfixes!
                        If you replace files the crude way.
                        If any files are replaced with pre-SP files, definitely required to reinstall SP1!
                        ASRock B550 PG Velocita
                        Ryzen 9 "Vermeer" 5900X
                        Arc A770 16 GB
                        eVGA Supernova G3 750W
                        Alienware AW3423DWF OLED
                        • goontron
                          5000!
                          • Dec 2011
                          • 4108
                          • US
                          why not grab the office key with a keyfinder then wipe, reinstall, and reinstall office?
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            ^I may look into that...
                            sigpic
                              • 31204
                              does office run in wine?
                              • goontron
                                5000!
                                • Dec 2011
                                • 4108
                                • US
                                2k7 yes, 2k10, partly.
                                • Topcat
                                  The Boss Stooge
                                  • Oct 2003
                                  • 16958
                                  This. I refuse to remove shitware (malware, spyware, junkware, etcware)....if someone wants a machine cleaned off, it gets wiped.
                                  <--- Badcaps.net Founder
                                  Badcaps.net Services:
                                  Motherboard Repair Services
                                  http://folding.stanford.edu/
                                  Team : 49813
                                  Join in!!
                                  Team Stats
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    It depends on the malware ad to whether I wipe or clean machines. A Samsung Evo 128Gb or even 240GB is not that expensive. Put the hardruve in an external caddy for the films
                                    magic Jellybean will recover the key for Windows and Office.
                                    You could reinstall Windows and Office and check everything works. The HDD in the caddy can then have everything wiped apart from the films.
                                    8GB of DDR3 and an ssd. That laptop will fly, its the malware that's making it slow.
                                    • seanc
                                      • Nov 2008
                                      • 1319
                                      I have a particular set of users give me laptops which are able to do everything except map network drives or connect to windows server resources. No malware at play.
                                      I've not been able to work out what it is that they install to break them, but I know they often load Blackberry software, so I'm just trying to work out a link
                                      I tend to notice Netbios over TCP/IP being disabled.
                                      RD if you do an ipconfig /all, what's the status of Netbios over TCP/IP?
                                        • 31204
                                        the blackberry desktop thing is huge and tries to integrate the fone with the desktop.
                                        maybe it inserts some type of hook to re-route the drive mapping through the usb.
                                        • omega
                                          Troubleshooting of redundant F750E-S0 Dell PowerEdge Server
                                          by omega
                                          Hello all,
                                          as a beginner electronics hobbyist, after a few years I would like to place another post on this Forum section, given that I did not succeed in finding any useful advice among the other posts.
                                          Over the last years, I have been using a PowerEdge Dell Server with two redundant PSUs, namely the 750W F750E-S0 ones (aka 06W2PW). Unfortunately, last summer one of them failed (perhaps owing to an overheating), and the server had for working to take into account the other one only. Of course I opened and tried to troubleshoot the failed PSU, but each cap I tested seemed to...
                                          02-09-2024, 03:34 PM
                                        • howardc64
                                          Samsung UN55JU650DF network/streaming problem
                                          by howardc64
                                          Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
                                          This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
                                          07-09-2025, 12:44 PM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
                                          HP ZBook 15v G5 Mobile server 15v Specification for Upgrade or Repair
                                          This specification for the HP ZBook 15v G5 Mobile server can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15v G5 boardview and 15v G5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ZBook 15v...
                                          09-06-2024, 11:39 AM
                                        • hikomalek
                                          SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                                          by hikomalek
                                          Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                                          When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                                          Transformer:
                                          |Info| Primary | Aux | AB | CD|
                                          |Ratio|1|25|40|12|
                                          |Voltage AC|230V|9.2V|5.8V|19V|
                                          |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                                          I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                                          09-19-2025, 03:30 AM
