damaged boot config from interrupted Vista install
  • tw2005
    • Oct 2011
    • 6458
    This is a messy one.
    Story goes like this.
    i have a Dell precision 380, P4 3.4Ghz HT CPU, it's reaching it's end of life with mobo isues etc. Vista ultimate Sp2
    I got a dell precision T3500, Xenon quad 3.2 Ghz.
    Plan was to swap the HDD old PC to T3500 and boot in safe mode then load drivers. i know with the difference in machines it was a long shot but i have been lucky in the past.
    this time, no good no matter what i tried. so did sysprep on old machine, took a few goes to get that to happen then swapped.
    At first it lasted longer on bootup making me think it was configuring the new PC , then blue screen.
    back to ld PC, also now damaged, blue screen, so I can't remember exactly but I think i tried loading windows setup and then stooping it in hope this would get it to load when swapped again to t3500.
    no good, just blue screen.
    Now i can't get out of the setup dialog in the old pc and just quits , failed setup installation , previous attempt incomplete( not exact words but that's the overall situation)
    I've tried hirens, bcdedit, there's no restore points as i suspect a vrus killed them.
    i then tried a registry restore in hirens but from 2014.
    that really stuffed it as i forgot it was XP then not the current vista.
    managed to reverse last changes and back to previos failed setup message.
    i did do a complete backup of the registry before all this unfolded but it won't load those in hirens.
    I definitely out of my league now and stuck.
    if there's a way to extract the reg backup to the old system I think that may work, don't know how.
    i have alot of programs loaded on the old machine and have no chance of finding discs,keys etc which is why I'm trying so hard.
    At some point i guess i'll have to quit , save my files at least and blow away the rest.
    i was going to try a claen install over windows but i expect that will just blow away the programs as well but keep my files?? Would like input on that one.
    Any suggestions?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: damaged boot config from interrupted Vista install
    I've not had much success of repairing Vista installs for my customers especially if malware hasn't been cleaned properly.
    Have you tried a upgrade install in the new PC ? you will need a Vista install disc with sp2 though or a copy of Windows 7.
    • tw2005
      • Oct 2011
      • 6458
      no not yet. will that option be available booting up from 7 pro? Is 7 pro an allowable upgrade on top of vista ultimate?
      i know when I did the upgrade from XP pro it would only allow ultimate.
      if that's possible that's a good solution I assumed was not available in which case i need to give myself an upper cut for wasting time trying everything else
      • diif
        • Feb 2014
        • 6978
        • England
        I've yet to encounter a legit copy of Vista or Windows 7 Ultimate so i couldn't say.
        There are people saying that only 7 Ultimate is an upgrade path for Vista Home Premium so you will need to check, maybe upgrade to 7 Ultimate.
        • tw2005
          • Oct 2011
          • 6458
          i'll have a go and see, thanks
          • tw2005
            • Oct 2011
            • 6458
            no dice, boot from 7 pro, get upgrade option then instructs you to restart to windows and perform upgrade in that environment which can't be done
            • SteveNielsen
              Retired Tech
              • 2327
              The file system is undoubtedly munged at this point. Do a file system repair, may need something like UBCD that has utils to repair file systems, then try booting the Vista disc and do a Startup Repair. If that doesn't work you're probably out of luck unless someone knows of a magic bullet out there.
              • tw2005
                • Oct 2011
                • 6458
                i'll try it. loading safe mode i see it gets to the same file as another vista machine i have which works but just blue screens. if i could work out where this setup config is loaded and delete it it may get back into the original OS.
                not a normal situation so googling such an issue has proven too hard. i have tried startup repair booting from the OS disc but does nothing
                • SteveNielsen
                  Retired Tech
                  • 2327
                  Yeah, that might work if you can locate the file(s) that are corrupted, but you need to repair the FS before doing more. Otherwise it's likely to make matters worse or at least prevent you from progressing further.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    When you ran sysprep did you use the generalize command ?
                    • Mad_Professor
                      A Mech Warrior
                      • Feb 2011
                      • 1587
                      uh... Vista Startup recovery > cmd prompt > Bootrec.exe /fixboot or Bootrec /fixmbr?
                      • tw2005
                        • Oct 2011
                        • 6458
                        yes
                        • tw2005
                          • Oct 2011
                          • 6458
                          will try, may have already tried it, looks familiar but will try again. just seeing if i can do reg restore from the copy i saved in the same cmd.
                          • tw2005
                            • Oct 2011
                            • 6458
                            thanks but same deal, trapped with this failed setup screen. might be time to just accept it , retrieve what I can and have a fresh install
                              • 31036
                              did you try DaRT. ?
                              • SteveNielsen
                                Retired Tech
                                • 2327
                                What is DaRT?
                                  • 31036
                                  it's ms's tool for manipulating, fixing and pasword-bypassing people's harddrives.
                                  http://www.microsoft.com/en-us/windo...mdop/dart.aspx
                                  btw, there is a different version for every version of windows.
                                  so dont just search for the newest.
                                  Last edited by c_hegge; 06-11-2015, 05:02 AM. Reason: Removed inappropriate comment
                                  • SteveNielsen
                                    Retired Tech
                                    • 2327
                                    So what I've never heard of it before? Lose the attitude and quit being a jerk.
                                    • R_J
                                      • 9540
                                      try googling this "Microsoft Windows MSDaRT ERD Commander 5.0, 6.0, 7.0, 8.0"
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Never heard of dart and I work on PC every day.
                                        Don't be a dick.
                                        I do remember erd commander tho.
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • DynaxSC
                                          ASROCK Z270 GAMING-ITX/AC - IR35201 - NEED THE VRM CONFIG FILES
                                          by DynaxSC
                                          I have an ASROCK Z270 GAMING-ITX/AC motherboard with a fried VCORE controller IR35201 (International Rectifier, currently Infineon).
                                          This chip is unfortunately programmable, so after replacing the chip, it needs to be programmed with a config file, which I do not have, as the chips is not readable any more (total short on power supply pin).
                                          Some of you maybe know, it is possible to read out the config file from a board with a working chip using the USB005 I2C adapter and IR/Infineon software called PowIRCenter. The software is available freely at Infinion...
                                          02-10-2025, 04:52 PM
                                        • duwane
                                          A2141 (2019 16" MB Pro) Strange macOS install issues. NAND? WIFI? FIRMWARE?
                                          by duwane
                                          Hi All.
                                          Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
                                          The issue:
                                          Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,...
                                          10-26-2022, 07:02 AM
                                        • XxMicroSoldering
                                          ASUS Rog Strix G17-712LV Laptop Liquid damaged
                                          by XxMicroSoldering
                                          Hello Guys
                                          I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                                          10-17-2024, 10:45 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
