Q on Proc/Mobo Combo's Performace
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    I Just got a deal from a local guy here in my city who is selling his unused PC parts:
    Athlon 3000+ Socket 939
    Epox EP9NDA3I mobo
    Offered at an affordable price of $65.
    I have a question though:
    Barring any overclocking, how much of a performance increase will I see with this combo like lets say against my current combo: P4 2.6 "C" Ghz & Intel 865gbf mobo.
    Constants:
    1 GB (2x512) RAM (Theoretically both Proc/Mobo Combos can use Dual Channel Mode)
    40GB Seagate Barracuda
    256MB GeForce FX5500
    Linux and Windows XP
    Comments are very much appreciated. :-)
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • gonzo0815
    • Feb 2006
    • 1600
    Re: Q on Proc/Mobo Combo's Performace
    It depends on the usage of your system and the type of Intel CPU. I would assume it is not an very huge performance boost, but may be in some games.
    On the other side, it is not that much money too.
    I would suggest to look for some benchmark charts between your current cpu and the Athlon64.
    • grss1982
      • Mar 2007
      • 225
      • Philippines
      @gonzo0815: Understood. Thanks. :-)
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • Cerberuska
        Mobo MSI B550-A PRO password popup
        by Cerberuska
        Hello guys,
        I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
        BIOS I updated to last one.
        any suggestions?
        And same thing for two different 5600G, and yes, MoBo supposed to support it.
        Thank you...
        11-10-2024, 01:23 PM
      • mrsith
        Dell G3 17 3779 - no display after mobo replacement
        by mrsith
        Hi guys,
        I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
        Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
        04-30-2023, 05:11 AM
      • Ibod
        Corsair cx600 psu & ASRock B450Pro4 mobo wont start
        by Ibod
        HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
        With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
        Not sure where to go from here ?
        Is the PSU at fault or is the mobo causing the problem
        Look forward to any help :-)
        If I plug the 24...
        02-08-2023, 11:00 AM
      • Felipe_Serra_83
        Dell Inspiron 14-5448 - fan turns off and mobo keeps running
        by Felipe_Serra_83
        Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
        So I got this Dell Inspiron to play with.
        No charger, so I connected to my bench PSU.
        The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
        ------What it did (and didn't do)------
        1) I turned it on and it powered on. Powered down in 2 seconds by itself.
        2) Removed RAM, changed slot. Same...
        04-04-2024, 12:39 PM
