intersting windows thing.
    • 31007
    http://www.myce.com/news/windows-upd...nloader-75647/
  • ddscentral
    • Mar 2008
    • 151
    • Lithuania, EU
    Re: intersting windows thing.
    Looks like that's some sort of notifier/nag screen to upgrade to Windows 10 when it comes out.
    http://windowsitpro.com/windows-10/m...-and-windows-7
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Yeah, no thanks. microsoft.
      sigpic
      (Insert witty quote here)
      • rhomanski
        nowhere man
        • 5157
        • U S of A
        uninstall seems to work on mine. That's sneaky but not unexpected.
        sigpicThe Sky Is Falling
          • 31007
          http://www.infoworld.com/article/290...-win7-pcs.html
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            Well now, when I went to shut down it hung up. Had to hold the power switch to finish the shut down. Not nice MS.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              I must admit, I rarely update my system beyond actual service packs unless a huge security breech is found. Automatic updates are always disabled around here.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • Agent24
                I see dead caps
                • Oct 2007
                • 4951
                • New Zealand
                I update, but wait a while and do research first. Saved me from those faulty updates that came out recently.
                -David VanHorn
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  I never had that problem with Windows 2000 and later. It always still responded, even when it looked like it crashed.
                  OTOH, Microsoft had to make a patch for Windows 95 and Windows 98 for that issue.
                  It was common to see Windows 95 and Windows 98 locked up at "Windows is shutting down" on campus PCs connected to the LAN.
                  Microsoft had a bug where Windows 95 and Windows 98 were more likely to do that when connected to a LAN.
                  Even good ol' Windows 98 SE had that bug, IIRC!
                  Why did Microsoft fail to fix that by Windows 98 SE RTM in 1999?
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • rhomanski
                    nowhere man
                    • 5157
                    • U S of A
                    I don't know, my 98 would hang up like that all the time. They never did fix it. XP did it too, way too often. Mostly 7 just crashes on me, BSOD with memory dump. I think it's the video card that does it. It's not too often so no real problem. One of my game programs is from 98 and it has to change resolution to run it. Sometimes when it comes back the screen is all messed up. More like a tye-died picture than aero. After restarting it works fine again until I play that game.
                    • TechGeek
                      Computer Geek
                      • Jan 2015
                      • 2254
                      Dude, it didn't disable 256 colors and forgot to change the screen res back.
                      Permanently Retired Systems:
                      Kooky and Kool Systems
                      sigpic
                      • rhomanski
                        nowhere man
                        • 5157
                        • U S of A
                        I'm not sure. It looks like a tye dyed T shirt. When I move the mouse it blanks out until I stop and then the screen comes back. Makes it hard to shutdown and restart. Takes a few minutes to start task manager and shut down.
                        • SteveNielsen
                          Retired Tech
                          • 2327
                          Had a similar problem with 95/98 but they'd hang on startup when on the LAN, when they finally pulled out of the hang there'd be no IP address. Packet sniffing found it to be caused by 95/98 not getting along with spanning tree protocol and we had to change all the routers and switches to enable port fast (disabling STP).
                          • Topcat
                            The Boss Stooge
                            • Oct 2003
                            • 16956
                            I just did a win7 reload on a laptop. This update was shown as optional, not critical. It's win7 64 pro.
                            Team : 49813
                            Join in!!
                            Team Stats
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              i leave my updates off too.
                              i do any updates at a time of my choosing only.
                              several reports of bad windows updates hosing the machine where you cant even roll back.
                              • ben7
                                Capaholic
                                • Jan 2011
                                • 4059
                                Yeah, I need to turn off automatic updates, because I leave the computer for JUST 5 MINUTES, and I come back, and it's doing an update ...
                                I've heard that the crashing can be due to driver issues. And it's not the programming of the drivers. Apparently, I heard that there is some sort of intrinsic flaw in the way windows handles drivers, which could cause them to do something at the same time (or something to that effect) and cause the system to crash.
                                Fortunately, I've never had any problems with windows 7
                                Muh-soggy-knee
                                  master hoarder
                                  • May 2008
                                  • 12170
                                  • Bulgaria
                                  Windows Update is always off on all of my computers or computers I service/fix. It really causes more harm than good.
                                  In this case, the "don't fix it if it ain't broken" phrase applies IMO.
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4951
                                    • New Zealand
                                    It can cause problems, but that's usually by people installing updates too fast before everyone else has had time to test them and find the bugs...
                                    Never updating at all means you are going to have an OS full of known security holes that malware writers just love to exploit.
                                    -David VanHorn
                                    • TechGeek
                                      Computer Geek
                                      • Jan 2015
                                      • 2254
                                      **Ding!** Level up to Agent24!! He's right, momaka. I've had to deal with my dad's computer being infected before.
                                      sigpic
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        • Bulgaria
                                        All of my computers are clean, that's all I can say. On my XP machines, SP2 is enough. The only update you really need if you have SP2 is the one that prevents the DownAdUp worm infection. No other issues other than that. A strong hosts file and ABP in Firefox go a long way to protect my PCs. Oh, and a dash of common sense, of course .
