intersting windows thing.
Re: intersting windows thing.
Looks like that's some sort of notifier/nag screen to upgrade to Windows 10 when it comes out.
http://windowsitpro.com/windows-10/m...-and-windows-7 -
I must admit, I rarely update my system beyond actual service packs unless a huge security breech is found. Automatic updates are always disabled around here.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
I update, but wait a while and do research first. Saved me from those faulty updates that came out recently."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
I never had that problem with Windows 2000 and later. It always still responded, even when it looked like it crashed.
OTOH, Microsoft had to make a patch for Windows 95 and Windows 98 for that issue.
It was common to see Windows 95 and Windows 98 locked up at "Windows is shutting down" on campus PCs connected to the LAN.
Microsoft had a bug where Windows 95 and Windows 98 were more likely to do that when connected to a LAN.
Even good ol' Windows 98 SE had that bug, IIRC!
Why did Microsoft fail to fix that by Windows 98 SE RTM in 1999?Last edited by RJARRRPCGP; 04-11-2015, 08:20 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
I don't know, my 98 would hang up like that all the time. They never did fix it. XP did it too, way too often. Mostly 7 just crashes on me, BSOD with memory dump. I think it's the video card that does it. It's not too often so no real problem. One of my game programs is from 98 and it has to change resolution to run it. Sometimes when it comes back the screen is all messed up. More like a tye-died picture than aero. After restarting it works fine again until I play that game.sigpicThe Sky Is Falling
Dude, it didn't disable 256 colors and forgot to change the screen res back.I don't know, my 98 would hang up like that all the time. They never did fix it. XP did it too, way too often. Mostly 7 just crashes on me, BSOD with memory dump. I think it's the video card that does it. It's not too often so no real problem. One of my game programs is from 98 and it has to change resolution to run it. Sometimes when it comes back the screen is all messed up. More like a tye-died picture than aero. After restarting it works fine again until I play that game.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
Permanently Retired Systems:
Kooky and Kool Systems
sigpicComment
I'm not sure. It looks like a tye dyed T shirt. When I move the mouse it blanks out until I stop and then the screen comes back. Makes it hard to shutdown and restart. Takes a few minutes to start task manager and shut down.sigpicThe Sky Is Falling
Had a similar problem with 95/98 but they'd hang on startup when on the LAN, when they finally pulled out of the hang there'd be no IP address. Packet sniffing found it to be caused by 95/98 not getting along with spanning tree protocol and we had to change all the routers and switches to enable port fast (disabling STP).I never had that problem with Windows 2000 and later. It always still responded, even when it looked like it crashed.
Why did Microsoft fail to fix that by Windows 98 SE RTM in 1999?Comment
I just did a win7 reload on a laptop. This update was shown as optional, not critical. It's win7 64 pro.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
Yeah, I need to turn off automatic updates, because I leave the computer for JUST 5 MINUTES, and I come back, and it's doing an update ...
I've heard that the crashing can be due to driver issues. And it's not the programming of the drivers. Apparently, I heard that there is some sort of intrinsic flaw in the way windows handles drivers, which could cause them to do something at the same time (or something to that effect) and cause the system to crash.
Fortunately, I've never had any problems with windows 7
Muh-soggy-kneeComment
It can cause problems, but that's usually by people installing updates too fast before everyone else has had time to test them and find the bugs...
Never updating at all means you are going to have an OS full of known security holes that malware writers just love to exploit."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
**Ding!** Level up to Agent24!! He's right, momaka. I've had to deal with my dad's computer being infected before.It can cause problems, but that's usually by people installing updates too fast before everyone else has had time to test them and find the bugs...
Never updating at all means you are going to have an OS full of known security holes that malware writers just love to exploit.Don't buy those $10 PSU "specials". They fail, and they have taken whole computers with them.
sigpicComment
All of my computers are clean, that's all I can say. On my XP machines, SP2 is enough. The only update you really need if you have SP2 is the one that prevents the DownAdUp worm infection. No other issues other than that. A strong hosts file and ABP in Firefox go a long way to protect my PCs. Oh, and a dash of common sense, of course
by japlyticIn a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
Tried (only with keyboard/mouse connected):- BIOS + database update
- Using latest Windows 11 image built with official image creation tool
- Previous setup version for Windows 11 installer
- Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
- TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
- Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
06-19-2025, 04:59 PM -
This specification for the Acer Aspire Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD 144Hz, Windows 10, Black) boardview and Acer Aspire 7 A715-42G 15.6 inch Gaming Laptop - (AMD Ryzen 5 5500U, 8GB, 512GB SSD, NVIDIA RTX 3050, Full HD...09-07-2024, 01:00 AM
This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...09-07-2024, 12:40 AM
This specification for the HP ProBook 450 G6 + Windows Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Windows boardview and 450 G6 + Windows schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...09-06-2024, 12:20 PM
Hello Guys,
got an Acer here with the problem that when i'm installing windows it just crashes (turns off) and not going back on as soon as i press the power button.
I've tried it with different sticks and windows versions and also with windows 10 and 11 but it's the same problem.
The only difference is that when i want to install windows 11 it crashes during the installation screen when "getting files ready for installation" at 25% - 30% progress and
when i install windows 10 it goes trough until the restart and at "getting devices ready" it... - Loading...
microsoft.
