Thanks for the gift newegg
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    I'm sure i'll, fine some use for it
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Thanks for the gift newegg
    Lol
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      Lol......
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        • 31201
        sell it, mac stuff is premium priced.
        • shovenose
          Send Doge Memes
          • Aug 2010
          • 6575
          lol
          • diif
            • Feb 2014
            • 6978
            • England
            I've never. Imaged a Mac, but I use Acronis to clone my customers drives before I start work on them.
              • 31201
              mac is BSD based, you image it with the DD command - no need for a "package" or "APP"
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                And if you are so inclined to use some software package, use Clonezilla!
                Follow the white rabbit.
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  ......... lol
                  Muh-soggy-knee
                  • mecha1166
                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                    by mecha1166
                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                    11-25-2024, 05:22 PM
                  • CapLeaker
                    Dell ATX PSU won’t start, but forcing it works fine?
                    by CapLeaker
                    Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                    Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                    10-28-2024, 06:59 PM
                  • emil_t
                    RTX3090 working fine but fans not spinning
                    by emil_t
                    Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                    04-12-2024, 06:54 AM
                  • edugimeno
                    TD Systems K50DLP8F works fine on 1 HDMI, bad on others
                    by edugimeno
                    I have this TV set that I spent a long time fixing it.
                    I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
                    I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
                    I didn't use that TV much at that time. Now that I'm using it,...
                    10-06-2023, 03:00 PM
                  • kamiewtype
                    MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
                    by kamiewtype
                    I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
                    The specs are:
                    MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
                    Intel core i9-10900kf
                    2x16gb Corsair Vengeance kit
                    BIOS ver is E7D06IMS.1B0, from 6/12/2023
                    The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
                    I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
                    11-01-2024, 10:52 AM
