Two questions (usb and ram)
  • pentium
    • Mar 2006
    • 2778
    Well once my ram arrives I want to close my computer up and have it run trouble free which means that the problems I put aside must be done before the ram arrives or they will never be done.
    First is involving the ram.
    My system has two regular DDR slots and one DDR2 slot. On top with the two 512 DDR sticks I am installing I am wondering if it is safe to put an additional 128 mb of DDR ram into the single unused DDR2 slot or will that cause problems?
    Second problem involves power to the USB ports.
    There are two headers that allow for an additional four USB ports but the problem is that when the computer is off the ports receive power but when the computer turns on the four ports lose all power and nothing can be done to get power back except turn the system off. The other four ports on the back of the board do not have this problem.
    My plan was to sever the 5V line(s) to these four problematic ports and have the required 5V come from a spare drive connector but I don't know if that will cause even more problems (excluding the loss of voltage monitoring on those ports). Would this rewire (which will also be fused) be okay or will I be smelling smoke?
    That is all.
    Find Nedry!
    Check the Vending machines!!
    <----Computer says I need more beer.
  • WNG
    • Sep 2006
    • 354
    Re: Two questions (usb and ram)
    I can't answer you first problem, as I wasn't even aware of boards mixing ddr and ddr2.
    As for the USB headers...usually, the board has an option jumper to whether to use +5V or +5VSB through the USB. Maybe your jumper is set to VSB.
    “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
    We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
    • pentium
      • Mar 2006
      • 2778
      I went through the owners manual and there is no mention of such a jumper.
      Correction, The third ram slot is in a different channel from the first two. You are right when you said that you never saw a board that could support both.
      Find Nedry!
      • shadow
        • Feb 2007
        • 732
        Boards that support two different memory formats generally can only run one set (ie. DDR memory) or the other set (ie. ddr2 memory). Not both sets at the same time. The manual should stipulate this, thou I have a feeling that the manual that you have is not very clear in this regard. Otherwise you would not need to ask here!
        Sorry just realised your reply about this.
        I have noticed in your post that you want to put in a 128mb DDR module into the DDR2 slot. I can tell you right now that this is a big no no!! A friend of mine fried his board in similar circumstances! DDR2 memory has a different number of pins on it and the notch is in a slightly different location. It is totally incompatible with the original DDR modules.
        • hkivan
          • Mar 2006
          • 122
          ddr use 2.5V
          ddr2 use 1.8v
          ddr can't fit into DDr2 slot and vice versa
          • pentium
            • Mar 2006
            • 2778
            That's all I needed to hear. Problem 1 solved/
            Now for that usb trouble.
            Find Nedry!
            • pentium
              • Mar 2006
              • 2778
              I need to know if my USB modification is safe to use soon. I need the system by the weekend.
              Find Nedry!
              • kikkoman
                • Jul 2007
                • 691
                As long as the 5V are relative to the same ground path (= come from the same PS), that should work. But be sure to properly disconnect the old 5V lines.
                The only potential problem (depending on what you intend to connect) is that you might lose the standby power of these ports, so you can't switch the PC on from a USB keyboard connected to a front port for instance. Not really a problem, though.
                btw, ist that still the MSI K7N2-Delta you're using?
                "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
                • pentium
                  • Mar 2006
                  • 2778
                  No problem there. The ports will be used by a card reader and a front USB port.
                  I plan to sever the connection at the fuse (Desolder the fuse) and run an extra lead from the power jack on the back of the case (used to send 12V and 5V to some modified sega glasses).
                  Thanks for the help. I can carry on from here.
                  Find Nedry!
                  • pentium
                    • Mar 2006
                    • 2778
                    I got to clean up the solder a bit but otherwise it's done.
                    Find Nedry!
                    • stevo1210
                      • Oct 2006
                      • 4156
                      Nice work!.... Your USB ports do function properly now.... right??
                      I still don't understand why your motherboard only supplies power to the USB ports when the PC is in soft-off mode.... seems a bit odd.
                      Is your case the type of case that has a removable motherboard tray?? Did you lose the I/O shield for your motherboard?? I see duct tape there instead of an I/O shield.
                      Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
                      • kikkoman
                        • Jul 2007
                        • 691
                        err... pretty drastic. you might have simply cut the cable after the header.
                        regarding your original question: that board supports Dual Channel, the third RAM slot is DDR, too. you SHOULD use it (512MB in each channel; adding more to channel B is okay, too.)
                        btw, I still have that exact I/O shield here, in case you're interested.
                        • pentium
                          • Mar 2006
                          • 2778
                          Yes, I have a removable tray.
                          I never got the shield. This board came from the landfill (which might explain the problems).
                          So I can put a 512 in channel A and 512 in channel B and still get away with 1 gig?
                          How much to ship?
                          Find Nedry!
                          • kikkoman
                            • Jul 2007
                            • 691
                            Yes. Maximum for that board is 3 GB (3x 1GB).
                            How much to ship?
                            Approx. 3 US$. I'm gonna ship another shield to the US on Monday, if you need the exact number.
                            • pentium
                              • Mar 2006
                              • 2778
                              Well my ram arrived today and I was able to see if everything worked.
                              Answer: yes and no.
                              The Modification to the USB ports worked but when it came to the ram the system just gave me memory errors.
                              The D-Bracket hangs at "Checking memory" and the system emits one long beep over and over with no signal to the monitor.
                              My guess: speed.
                              I got DDR266 memory in the hopes it would work. It was tested before it was mailed to me so I assume the ram is just too slow.
                              DAMN!
                              I don't even have another DDR-based system to test the ram on.
                              Find Nedry!
                              • kikkoman
                                • Jul 2007
                                • 691
                                What's the CPU's FSB?
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Hmm... I don't remember I keep away from the bios when I don't need to be in there. according to a previous thread I made I set something at 166mhz but I don't think that's the FSB (that's pretty slow)
                                  I also saw that a little more had been posted after my problems cleared up and I forgot about the thread. Compared to your system my board is spotless and FET temps are okay.
                                  I have not yet gone over the thread completely yet but I'll look it all over again.
                                  EDIT: Okay, since then I have replaced the bios socket (the plastic part).
                                  I'm thinking that clearing the CMOS might cure the problem but I'm not positive.
                                  Oh yeah. It seems later revisions of this board has heatsinks on the FET's.
                                  Find Nedry!
                                  • kikkoman
                                    • Jul 2007
                                    • 691
                                    That depends on what that board's default setting for the RAM clock multiplier is (if it's either fixed to e.g. 1:1 (FSB:RAM) or if it's based on the board's readout of the RAM's EEPROM), because:
                                    if I'm correct your CPU is a 3000+ Thorton, which means a FSB of 166MHz. In synchronised mode (1:1), the RAM would run at 333MHz, which is obviously too fast for your current setup. If the BIOS has that sync mode as a default, a reset won't help, because the RAM clock would still be 333 after that.
                                    That leaves two solutions:
                                    a)If the default mode is auto, the reset will (most likely) work.
                                    b)if not: get some faster RAM from a friend , for example, you'll only need it for a minute.
                                    pop it in, enter the bios, set the RAM clock multiplier (actually divider) to something lower (i won't do the math, but 4/5 should be okay), and it's done.
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      So this ram WILL work with my board?
                                      I need to know before friday.
                                      After that, I can't mail it back to the guy for a refund.
                                      Yeah, The frequency should reset. When I accidentally clocked the system too high once I pulled the battery for the night and the next morning the system would POST again and I was able to readjust the clock again.
                                      I should be able to independantly control the clock speed of the ram.
                                      Find Nedry!
                                      • kikkoman
                                        • Jul 2007
                                        • 691
                                        Did you have faster RAM before? Or is that 128mb stick a faster one (333 or 400) by any chance?
                                        As long as that RAM isn't broken in the first place, it'll work with your board, but you have to gain access to the BIOS first. That's the key.
                                        I assume you clocked the FSB too high (and not only the RAM clock).
                                        A BIOS reset definitely sets the FSB to auto (default), but not necessarily the RAM divider. That's the crucial point here.
                                        On the other hand, if you still have the possibility of a refund.....
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • electronx
                                          Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                                          by electronx
                                          I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                                          1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                                          According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                                          If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                                          06-26-2025, 03:27 AM
