3 different PSUs, still cant get Motherboard to stay on
    • 31017
    Re: 3 different PSUs, still cant get Motherboard to stay on
    i have a FIC VA503 that has been running almost 24/7 since 99'
    had to replace the videocard twice, and the cpu fan a few times, but other than that - solid.
    it runs my fileserver.
    • GR3Y5H3ART
      • Jan 2011
      • 146
      Originally posted by stj
      yea, you can wash pcb's but you must unplug anything and everything you can especially the battery.
      you get a mug, put half inch of dish washing liquid in it, top off wih boiling or very hot wter.
      stir it and pour it over the board in the sink.
      then scrub it with a soft paintbrush and rinse under the tap till all the soap is clearly gone.
      then shake the water off and force-dry it with a fan heater or hairdryer.
      the force drying is the important part - standing water causes corrosion.
      no leaving it outside in the sun type crap.
      btw, this is a common trick with dusty or nichotine stained boards.
      just one thing, dont forget to remove any chipset heatsinks and clean any paste off with IPA first.
      and dont forget to put them back afterwards!!
      wow thanks, definitely saving info
      appreciate it!
      • GR3Y5H3ART
        • Jan 2011
        • 146
        i have a 3 year old build that was my 1st Build and it went well and still going strong
        this build i'm doing w/my bro-in-law and building it for living room so all family can use it
        thanks for the info again and may try the wash w/the Asus
          • 31017
          did you test the cpu from the asus in something else yet?
          • GR3Y5H3ART
            • Jan 2011
            • 146
            fixed, everythings up and running
            installed Windows 7, Firewall, Virus, GPU Update, etc.
            CPU is good, everythings good exception of MOBO perhaps
              • 31017
              you installed a Virus? why? it does that for you!
              • GR3Y5H3ART
                • Jan 2011
                • 146
                #27
                Anti-Virus
                • Spork Schivago
                  • Mar 2012
                  • 4734
                  • United States of America
                  #28
                  I know this might sound kinda obvious, but did you check the electrolytic capacitors on the board to see if any of them looked physically bad? You know, rounded tops instead of flat tops, leaking stuff on the board, etc. I've attached a picture from Wikipedia that shows swollen bad capacitors. I know to truly test for bad caps, you need an ESR meter. If you don't have an ESR meter though, a physical inspection wouldn't really hurt anything...just a thought.
                  -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
                  • reaper57
                    • Sep 2014
                    • 216
                    • Norway
                    #29
                    How did you fix it? There were bad caps weren't there?
                    Keyboard not detected, press F1 to continue...
                    • glovecaps
                      Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                      by glovecaps
                      I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                      My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                      The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                      11-25-2024, 04:23 PM
                    • Docus
                      Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                      by Docus
                      Hi everyone 😀,
                      I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                      To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                      Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                      1. I already own the exact same model, but its plastic chassis is badly damaged.
                      06-10-2025, 04:24 PM
                    • Archimedes
                      HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                      by Archimedes
                      Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                      Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                      Fans are spinning. Blindly could install windows11 and got the device manager...
                      07-30-2024, 05:14 PM
                      ASUS P5GC-MX motherboard recap
                      by momaka
                      Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                      This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                      So here is what the motherboard looked like with its original caps:
                      CPU VRM area up close…...
                      01-27-2021, 11:59 PM
                    • dragon3x
                      After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                      by dragon3x
                      Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                      power on.
                      Here are some examples :
                      (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                      switching supply area).
                      (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                      than 6.3 V.)
                      1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                      I replaced capacitors with aluminum-polymer.
                      3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                      03-21-2025, 02:46 PM
