Determine Fuse Size?
  • m4a2t0t
    • Mar 2013
    • 279
    Have a DV7 notebook with LED display and no backlight.
    SMD labeled JS8 below the left side of the connector. How do I determine the max amperage? I know I can remove the fuse and jump the pads to get it working but if there is another surge it will destroy the mobo and/or panel.
    The panel in the laptop is an LG LP173WD1 (TL) (E1)
    LED Power Input Voltage 7v/12v/20v MIN/TYPICAL/MAX
    LED Power Input Current NA/20mA/25mA
    LED Power Comsumption NA/5.7W/6W
    LED Power Inrush Current 1800mA
    20V fuse and 2A to cover inrush current ?
    Any help appreciated.
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Re: Determine Fuse Size?
    Well, if you can't find a datasheet for it you can desolder the old one, solder two wires, connect them to a multimeter and check what kind of an amperage is going to the screen (you should set the brightness to max).
    Btw are you sure that the fuse is the problem? Recently I fixed a dv6 on which the backlight wasn't working and it turned out that the cable wasn't properly inserted into the panel.
    Keyboard not detected, press F1 to continue...
      Are you sure Js8 is for the fuse, I see JS6, JS7 close by.
      • trebo
        • 514
        • Wales, UK
        have you jumpered the jumper???
        those jumpers are common on boards, you should be able to find one on any scrap M/B
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
        • howardc64
          by howardc64
          Problem
          08-04-2024, 10:36 PM
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • dragometin
          Hitachi 40HYC42
          by dragometin
          TV Model: Hitachi 40HYC42
          Power Supply: 17IPS71
          MainBoard: 17MB95M
          Panel: VES400UNDS-2D-NO3
          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
          Is there any variants on 17IPS71 power supply's?
          UART output pins 10 and 12 on scart connector:
          Code:
          12:24:04.595
          08-08-2024, 05:53 AM
