Can a Desktop board run without lan chip?
  • lezsimply
    The Wanderer
    • 657
    • Philippines
    Hi. Just wan't to know if desktop motherboard can run without lan chip. I've got 2 motherboards here which suffered short circuit during a lightning strike. This cause lan ports to light without cable or activity. I also notice the lan chip getting very hot. I want to remove it to make the board usable. Is this possible? Thanks guys!
  • brethin
    • Dec 2008
    • 1907
    Re: Can a Desktop board run without lan chip?
    It is possible but just because the lan chip is bad doesn't mean there is no other damage from the lightning strike. Try disabling the lan port in the bios to test the rest of the board functions.
    • lezsimply
      The Wanderer
      • 657
      • Philippines
      I already took some test of the board. I even installed windows 7 and run it for about an hour and no problems occurred except of course of the lan port unusable. I do not exceed an hour because chip is really getting very hot not even a 1 second touch.
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        I removed LAN chip here https://www.badcaps.net/forum/showthread.php?t=37844
        Didn't fix board's starting problem, but didn't make it worse either
        better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
        • lezsimply
          The Wanderer
          • 657
          • Philippines
          OK thanks man! By the way have you washed your board? Might do the trick
          • c_hegge
            • Sep 2009
            • 5219
            Removing the Ethernet controller IC is no problem for most boards. The board in my main rig (a Gigabyte GA-Z77M-D3H-MVP) had it's Ethernet controller removed after a lightning hit, and it's been perfectly stable.
            • lezsimply
              The Wanderer
              • 657
              • Philippines
              Thanks hegge. I'm in the process of removing it now. I'll keep you posted.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • gusto
                How do I remove the chip from the board
                by gusto
                I am new to hot air soldering. I need to remove one chip from the board. I have a hot air solder and I set the temperature to 350°C. I slowly started heating the chip, but the solder didn't melt. I heated it for about 5 minutes, but the solder still wouldn't melt. I increased the temperature to 450˚C and still nothing. After a while, the board started to change color, but the solder still didn't melt.
                Fortunately, I'm testing it on old network switches to see how it works.
                What am I doing wrong?
                I've seen a lot of videos on youtube and everyone got the solder melted and the...
                10-08-2024, 10:55 AM
              • Stephen
                A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
                by Stephen
                As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
                5.16V .47amp
                5.16V .47amp
                5.16V .47amp
                5.16V .04amp (this guy is the issue) (U3200)
                So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
                11-27-2023, 03:57 PM
