Testing this board on a wooden surface, sometimes it will start the power supply when I short PWR & Ground on its System Panel block, and sometimes it won't
For a given session, if it starts it'll continue to start after a power off, but if it won't start nothing I can do will persuade it to start (including a change of power supply)
During one of its cooperative phases I discovered that its LAN, although detected by an O/S, would freeze up the session if enabled in BIOS
This applied to both Windows XP & descendents, and Linux - not a driver issue, same setup worked nicely with another, pleasant, A8V Deluxe
Any suggestions ? - I'm tempted to try removing its LAN chip
