A1989 Logic Board Repair Issue. One CD3215 chip is the culprit
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    As the title states, got one CD3215 chip being a complete butthole to me. All readings on the other 3 chips read as follows
    5.16V .47amp
    5.16V .47amp
    5.16V .47amp
    5.16V .04amp (this guy is the issue) (U3200)
    So I went ahead and replaced the chip, (actually 3 times with 3 new CD3215 chips) all same issue, at first it wasn't reading at all then it finally started reading. I can rest assured is it not the CD3215 chip now but something else is causing this port to not fully read (god I wish the board would just turn on so we can just recover the data)
    Originally the board had 3 faulty chips (this one was one of them) replaced them, scrubbed epoxy coating and voila all chips work (except for this one). So far what I am seeing is the chip reads correctly on our EDP reader (it wasn't originally now its good)
    But one area I am testing is not getting any voltage whatsoever,
    Q3450 is not getting any voltage readings. Tested R3450 and not getting any voltage readings.
    C3213 no voltage. So I am assuming there is definelty a short somewhere in this area. Replaced a diode and nothing has happened as well since I did notice. a chip on one of the diodes. No luck. Again I replaced the CD3215 with three brand new chips and of course they all read the same so something tells me it is not the CD3215 anymore but something else causing it. If someone can pin point me to the right areas I would be greatly appreciated!
    I am also getting 1VOLT on PPBUS_G3H
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Cashcobra
    • Jul 2017
    • 26
    • GHANA
    • Diagnostic solutions
    • 0V6 diode mode on [n:USBC_TA_CC1] at [p:CB313:1]
      0V6 diode mode on [n:USBC_TA_CC2] at [p:CB314:1]
      5V on [p:FB200:1]
      3V3 on [p:CB308:1]
      1V8 on [p:CB305:1]
      1V8 on [p:CB306:1]
      1V1 on [p:CB304:1]
      ~26V on [p:QB300:1] and [p:QB300:4]
      Check [n:PPDCIN_G3H] on [p:QB300:8]
    • UB400
      0V6 diode mode on [n:USBC_TB_CC1] at [p:CB413:1]
      0V6 diode mode on [n:USBC_TB_CC2] at [p:CB414:1]
      5V on [p:FB201:1]
      3V3 on [p:CB408:1]
      1V8 on [p:CB405:1]
      1V8 on [p:CB406:1]
      1V1 on [p:CB404:1]
      ~26V on [p:QB400:1] and [p:QB400:4]
      Check [n:PPDCIN_G3H] on [p:QB400:8]
    • U3100
      0V6 diode mode on [n:USBC_XA_CC1] at [p:C3113:1]
      0V6 diode mode on [n:USBC_XA_CC2] at [p:C3114:1]
      5V on [p:F3000:1]
      3V3 on [p:C3108:1]
      1V8 on [p:C3105:1]
      1V8 on [p:C3106:1]
      1V1 on [p:C3104:1]
      Check 26V on [p:Q3100:1] and [p:Q3100:4]
      Check [n:PPDCIN_G3H] on [p:Q3100:8]
    • U3200
      0V6 diode mode on [n:USBC_XB_CC1] at [p:C3213:1]
      0V6 diode mode on [n:USBC_XB_CC2] at [p:C3214:1]
      5V on [p:F3001:1]
      3V3 on [p:C3208:1]
      1V8 on [p:C3205:1]
      1V8 on [p:C3206:1]
      1V1 on [p:C3204:1]
      Check 26V on [p:Q3200:1] and [p:Q3200:4]
      Check [n:PPDCIN_G3H] on [p:Q3200:8]
    • 5V to 20V sequence
      USBC CC1/2 & T2-SMC I2C
      Diode mode ~0V6 on [n:USB_XA_CC1] at [p:C3113:1]
      Diode mode ~0V6 on [n:USB_XA_CC2] at [p:C3114:1]
      Diode mode ~0V6 on [n:I2C_UPC_SDA] at [p:R5220:2]
      Diode mode ~0V6 on [n:I2C_UPC_SCL] at [p:R5221:2]
      Power getting to the CD3215...
      5V on [n:PP20V_USBC_XA_VBUS] at [p:F3000:1]
      Basic CD3215 voltages + LDOs...
      3V3 on [n:PP3V3_UPC_XA_LDO] at [p:C3108:1]
      1V8 on [n:PP1V8_UPC_XA_LDOA] at [p:C3106:1]
      1V8 on [n:PP1V8_UPC_XA_LDOD] at [p:C3105:1]
      1V1 on [n:PP1V1_UPC_XA_LDO_BMC] at [p:C3104:1]
      Open [p:Q3100] so power goes through to [n:PPDCIN_G3H]...
      >5V on [n:UPC_XA_GATE1] at [p:Q3100:1]
      >5V on [n:UPC_XA_GATE2] at [p:Q3100:4]
      5V on [n:PPDCIN_G3H] at [p:C7000:1]
      Power to the ISL [p:U7000] ...
      (in) 5V on [n:TBA_VDDA] at [p:C7075:1]
      (out) >=3V3 on [n:CHGR_EN_MVR] at [p:R6907:2]
      Getting [n:PP3V3_G3H_RTC] ...
      3V3 on [n:PP3V3_G3H_RTC] at [p:L6900:1]
      20V switch over...
      20V on [n:PP20V_USBC_XA_VBUS] at [p:F3000:1]
      >20V on [n:UPC_XA_GATE1] at [p:Q3100:1]
      >20V on [n:UPC_XA_GATE2] at [p:Q3100:4]
      20V on [n:PPDCIN_G3H] at [p:C7000:1]
      Final steps...
      5V on [n:TBA_AUX_DET] at [p:C7016:1]
      MOSFETS [p:Q7030] and [p:Q7040] should now be open
      [p:U7000] should be generating [n:PPBUS_G3H]
      Other things to check...
      Measure [p:R7075] for 4R7 value
    ​if all this are check correctly you have PPBUS_G3H
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Update: brought thermal camera up.
      U3100 Is reaching temps of 151 degrees. The meter is showing .37amps on that chip is that even normal?
      sigpic
      • Cashcobra
        • Jul 2017
        • 26
        • GHANA
        if you have short on u3100 or bad controller it will hot
        can you measure and tell me what you get ?
        5V on [p:F3000:1]
        3V3 on [p:C3108:1]
        3V3 on [p:C3100:1]
        1V8 on [p:C3105:1]
        1V8 on [p:C3106:1]
        1V1 on [p:C3104:1]​
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Ok so U3100 and U3200 are in the high temp ranges 5v .17amps on both ports. Other side 5v .39amps on both ports. Both chips are in the high temp range but the other side is not. I will get back to you with measurements tomorrow. I know I am getting close to solving this issue.
          sigpic
          • Cashcobra
            Cashcobra commented
            Editing a comment
            Ok will be waiting
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          F3000- 5v
          c3108- 0.5v
          c3100- 0.04v
          c3105- 0.0v
          c3106- 0.0v
          c3104- 0.5v
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            F3001:1- 5v
            c3201:1-5v
            c3214:1-1.7v
            c3213:1-0.0v
            c3209:1-0.0v
            c3200:1-0.0v
            c3206:1-0.0v
            c3204:1-0.0v
            c3219:1-0.0v
            c3208:1-2.6v
            c3205:1-0.4v
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Also keep in mind these are new chips that have been soldered on correctly. So I can rest assured the chips are not faulty at this point so there is definitely a short somewhere
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                Bump.
                sigpic
                • mon2
                  • 14666
                  Is this still true? Remove all power -> meter in resistance mode -> check the resistance to ground of PPBUS_G3H. Is it a low measurement? Remove the downstream fuses on PPBUS_G3H and check the resistance again on the removed fuse pads to confirm which side of this power rail is being shorted.
                  What is the exact resistance on each side of the removed fuse(s) ?
                  Power up again without the fuse(s) and confirm if the PPBUS_G3H voltage has returned to normal without a downstream load.
                  • PITERPENY
                    Macbook A1989, 820-00850, won't boot. 20V, 0A.
                    by PITERPENY
                    Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                    Here are some measurements, maybe someone can tell what the problem is.
                    The initial problem was a burnt out induction coil L8504 (replaced).
                    When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                    here are some measurementsmotherboard...
                    01-16-2024, 02:19 PM
                  • Cemal Odabasioglu
                    MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                    by Cemal Odabasioglu
                    I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                    Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                    Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                    Observations...
                    01-14-2025, 03:54 PM
                  • bastien
                    OBDATA Raccoon Computer V1 for Macbook Pro Air 2012-2025
                    by bastien
                    It's the end of three years of work, it costs money, it costs time, and you owe me a beer.
                    This is the new database for FlexBV
                    it's optimized to work with it
                    by using board ID has Default name, give us the opportunity,
                    to use other diode board data with sibling board or family board
                    I Merged the whole data (optimal)
                    A2991 A2992 M3 -> -> 2 Entries diode data M1
                    A2681 A3113 A3114 M1 M2 Air -> -> 2 Entries diode data M1 M2 13"
                    A2442 A2485 A2779...
                    03-18-2025, 08:03 AM
                  • asr
                    Finding replacement diode iPad Pro 3rd gen A1701
                    by asr
                    Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                    Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                    07-09-2024, 06:24 PM
                  • ErinV
                    MacBook Pro A1989 820-00850-A not powering on
                    by ErinV
                    Hey everyone!
                    I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                    I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                    The diode voltages around all 4 CD3215's seem fine.
                    For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                    09-30-2024, 10:21 PM
