old X58 triple channel board... memtest86 memory speed?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8703
    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any indications when it's actually using three or more channels and are single thread applications taking advantage of it?
    I only have one known working dual channel board with all DDR3-1600 modules reporting 20GB/sec in memtest86. My triple channel (6x4GB modules) and quad channel (8x8GB modules) boards are getting crappy results around 11-14GB/sec, though it may be due to having mixed brand DDR3-1333 and DDR3-1600 modules but they all have the same size and ranks as far as I know.
  • dmill89
    • Dec 2011
    • 2534
    I just dug out my x58 system and got similar results 11.6 GB/s with 6 matched 4GB sticks of Timetec (with Hynix chips) DDR3-1333.
    Specs as follows:
    Motherboard: Gigabyte GA-X58A-UD3R
    CPU: Intel Xeon W3680
    RAM: 24GB (6x4GB) Timetec DDR3-1333.
    GPU: Nvidia (EVGA) Geforce GTX1060
    SSD: Samsung 870 Evo 250 GB
    I also have a P55 system (so same era, but dual-channel) and it does even lower at 9.52 GB/s with 2 4GB sticks of Hynix DDR3-1333.
    Specs as follows:
    Motherboard: Gigabyte GA-H55M-UD2H
    CPU: Intel I5-661
    RAM: 8GB (2X4GB) Hynix DDR3-1333
    GPU: Nvidia (MSI) Geforce GTX 770
    HDD: Western Digital Veloci-Raptor 10K RPM 500GB
    As well as a P45 board (so a generation older) that uses DDR3 and it only gets 3.89 GB/s with 2 4GB sticks of Corsair DDR3-1333
    Specs as follows:
    Motherboard: Gigabyte EP45C-UD3R
    CPU: Intel Core2Quad Q9450
    RAM: 8GB (2X4GB) Corsair DDR3-1333
    GPU: AMD (Sapphire) Radeon R9-380
    SSD: Samsung PM871 256GB
    For some newer DDR3 systems here's a quad channel X79 system getting 13.9 GB/s with 4 8GB sticks of Corsair DDR3-1600
    Specs as follows:
    Motherboard: Asus X79 Sabertooth
    CPU: Intel Xeon E5-2690 V2
    RAM: 32 GB (4X8GB)Corsair DDR3-1600
    GPU: AMD (Gigabyte) Radeon RX470
    SSD: Imation X-Pro 256 GB
    And a dual-channel Z97 system getting 19.1 GB/s with 2 8GB sticks of Crucial DDR3-1600
    Specs as follows:
    Motherboard: Gigabyte Z97X-Gaming 3
    CPU: Intel I7-4790
    RAM: 16GB (2X 8GB)
    GPU: Nvidia (Gigabyte) Geforce GTX-1080
    SSD: Western Digital Blue SN570 1TB
    So I believe your results were probably typical for an X58 board, and it looks like on these older boards the CPU/Chipset were probably more of a limitation than the memory itself.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      Thanks for testing! Nice...
      Looks like either the triple/quad channel is either a lie, or still just memtest86 doesn't test it properly, but my machines are working as expected.
      Yeah I was kind of shocked my dual channel Z68 completely rips my X58 and X79 boards. It's ripping my DDR4 laptop too, so something just didn't seem right.
      Incidentally my 4x2GB = 8GB DDR2-800 Core2 Quads also get around 4.4GB/sec ... wonder if it's just FSB limitation...
      • lti
        • May 2011
        • 2557
        An old i3-2330M is a little faster, but this might not be an accurate comparison since Lubuntu came with a different Memtest86+ version.
        Click image for larger version  Name:	WIN_20250629_10_25_52_Pro.jpg Views:	3 Size:	296.6 KB ID:	3670863
        I'm a little surprised that I got HDMI capture working, but Windows forgot how to open .jpg files.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8703
          Yeah I get ridiculously fast speeds with IMC dual channel 2nd gen (like my Z68, 20GB/sec), but the triple, quad, and limited single channel (my i3 with differing modules) are slower (11, 14, 10GB/sec respectively). Something still fishy going on...
          • dmill89
            • Dec 2011
            • 2534
            For curiosity sake I spun up Memtest 86+ on some DDR4 systems (where you'd expect the speeds to be much higher than DDR3) and the results are definitely a bit "screwy".
            First a quad-channel X99 system with 4 8GB sticks of Adata (Hynix chips) DDR4-2400 is showing 12.6 GB/s
            Click image for larger version  Name:	DSC_1585.jpg Views:	0 Size:	1.46 MB ID:	3671052
            Specs as follows:
            Motherboard: Gigabyte GA-X99-UD5 WIFI
            CPU: Intel Xeon E5-2690 V4
            RAM: 32GB (4X 8GB)Adata DDR4-2400
            GPU: Nvidia Geforce GTX-1070
            SSD: Hynix BC901 256 GB
            A dual-channel 6th gen (skylake) Intel system with 2 8GB sticks of Kingston DDR4-2400 showing 18.6 GB/s
            Click image for larger version  Name:	DSC_1586.jpg Views:	0 Size:	1.56 MB ID:	3671053
            Motherboard: Lenovo ThinkStation P310
            CPU: Intel Xeon E3-1230 V5
            RAM: 16GB (2X 8GB) Kingston DDR4-2667
            GPU: Nvidia (PNY) Geforce GT-1030
            SSD: Hynix PC711 256 GB
            And my most powerful system (which should be absolutely wiping the floor with everything else) a dual-channel AMD X570 system with 4 32GB sticks of Team-Group DDR4-3600 showing 17.3 GB/s
            Click image for larger version  Name:	DSC_1587.jpg Views:	0 Size:	1.56 MB ID:	3671054
            Motherboard: MSI X570 Gaming Plus
            CPU: AMD Ryzen 9 5900XT
            RAM: 128GB (4X 32GB) Team Group DDR4-3600
            GPU: Nvidia (PNY) Geforce RTX-4070 Ti
            SSD: Western Digital SN850 2 TB
            And User Benchmark is showing 52.7 GB/s on this same system:
            Click image for larger version  Name:	User Benchmark 3 (Mem) 20250621.jpg Views:	0 Size:	99.5 KB ID:	3671055
            So something seems verry "off" with how Memtest 86+ is determining memory speed.
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8703
              No Windows here so can't run...
              For Linux however, tried hdparm -T ...
              This resulted in different results. I haven't tried the X58 yet, but my
              C2Q with Q45 6.5GB/sec (significantly faster than memtest86+, near 50% faster)
              i3 with H81 4.3GB/sec (possibly tainted result as running something in background, much slower than memtest86+, near 50% slower)
              i7 with Z68 14.2GB/sec (slower than memtest86+ but in ballpark)
              • dmill89
                • Dec 2011
                • 2534
                Specs as follows:
                Here's what passmark (running windows 7 on this system, so my options are limited on compatible "recent" benchmarking tools) has to say about that X58 system for camparison:
                It is showing 19.6 GB/s threaded, 13.1 GB/s cached read, 8.8 Gb/s uncached read, and 8.5 GB/s write. (though it is showing the memory speed as 800 Mhz, but the BIOS shows it as 1333 Mhz 🤔)
Name:	X58 MemoryMark.jpg
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8703
                  Hmm. Just tried hdparm -T (aka cached buffer read speed) on my X58A ... got 10GB/sec which is close to the memtest86 speed. Machine is running a RAID5 mechanical HDD so this sure ain't disk read speed...
                  Code:
                  # hdparm -Tt /dev/md127 /dev/sda
                  /dev/md127:
                  Timing cached reads: 20794 MB in 2.00 seconds = 10410.97 MB/sec
                  Timing buffered disk reads: 856 MB in 3.00 seconds = 285.33 MB/sec
                  /dev/sda:
                  Timing cached reads: 20366 MB in 2.00 seconds = 10196.04 MB/sec
                  Timing buffered disk reads: 232 MB in 3.00 seconds = 77.33 MB/sec
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1352
                    • France
                    I looked at your posts and was interested in doing some tests too.
                    Well, I have a slot that's no longer working; I threw a bit of random RAM into it.
                    After enabling NUMA in the BIOS, performance doubled.
                    ​​There's dual and single rank. I'll try to find a complete identical batch to retest.
                    • m1ch43lzm
                      • Mar 2019
                      • 910
                      • Peru
                      Here's mine, this is a laptop with AMD Ryzen 3 3200U CPU, 8+4GB DDR4 running at 2400MT/s, substract 2GB eaten by the integrated GPU (Vega 3)
                      Passmark Memtest86 11.3 (UEFI), it gives me 9865MB/s, I also ran both benchmarks there
Name:	passmark memtest86.jpg
ID:	3671969 Click image for larger version
Name:	passmark memtest86 1.jpg
ID:	3671970 Click image for larger version
Name:	passmark memtest86 2.jpg
ID:	3671971 Click image for larger version
Name:	passmark memtest86 3.jpg
                      Memtest86+ found in systemrescue 11.00 from last year, slightly lower at 9.28GB/s
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8703
                        That's weird. My DDR3 laptop has integrated graphics but gets 11GB/sec in memtest86+, though it does have two 8GB DIMMs (not matching, don't know if matched enough to support dual channel).
                        hmm...need a better standardized way to compare windows benchmarks with linux and memtest86+ which appears to be wrong for triple and quad channel boards.
                        • m1ch43lzm
                          • Mar 2019
                          • 910
                          • Peru
                          Tested memtest86+ on another 2 desktop PCs
                          1. Ryzen 3 2200G, 2x8GB DDR4-2666 OC'd at 3000MT/s, 2GB eaten by the integrated GPU
                          Click image for larger version  Name:	r32200g.jpg Views:	0 Size:	129.6 KB ID:	3672017
                          18.6GB/s, running in dual channel
                          2. Ryzen 7 5700G, 2x16GB DDR4-3600, 4GB eaten by integrated GPU (forgot to disable it, I have a dedicated GPU on this PC)
                          Click image for larger version  Name:	r75700g.jpg Views:	0 Size:	103.3 KB ID:	3672018
                          38.9GB/s, more than double , I expected maybe 20% more just by the RAM speed difference
                          The amount of RAM/CPU cores seems to have an effect ... Yet I beat dmill89 on memtest86+ with only a quarter of RAM (32GB) and half the cores/threads (8C/16T) Ryzen CPU
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8703
                            Seems triple and quad channel are not being properly represented, double channel works much better.
                            • spleenharvester
                              Reverse engineering of 18650 4-channel tester
                              by spleenharvester
                              Hi friends
                              I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                              05-04-2025, 02:43 AM
                            • mikey5791
                              Help on car amplifier only one channel works
                              by mikey5791
                              Hi all forum members,
                              Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                              My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                              08-06-2025, 10:36 PM
                            • dicky96
                              American Audio VLP1500 Distorting on one channel
                              by dicky96
                              Hi guys I have a VLP1500 amplifier here - one channels works fine and the other channel distorts even at low volume settings
                              Protection and Clip LED are off
                              There is something wrong with the BIAS voltages around T16 and T18 (in particular) on the bad channel
                              I tested all diodes and transistors in this area in circuit with diode mode - both channels seem identical. Same in resistance mode across all the resistors here.
                              The output DC voltages on pin1 and pin8 of the 5532D dual op amp at the input of each amplifier module are the same, and the audio...
                              07-13-2022, 05:25 AM
                            • dicky96
                              Hitachi V19B01922 Channel Tune problem
                              by dicky96
                              Hi Guys
                              I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                              He also has an LG TV, so three screens in the bar
                              I installed three Satlink ST-6503 DVB-T Modulators
                              This model https://www.aliexpress.com/item/32916553905.html
                              These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                              02-09-2023, 09:20 AM
                            • sima112
                              Marantz pm 6005 right channel not worknig
                              by sima112
                              Hi guys,
                              I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                              01-30-2023, 12:11 PM
