MSI MS7412 mobo will not boot two hdd's
  • binsonk
    • Apr 2014
    • 182
    Re: MSI MS7412 mobo will not boot two hdd's
    I have tried to install these two drives in several computers. One computer in particular, based on Asus A7N8X mobo, worked well, except there was no sound. It's very unfortunate that there was no sound because I will be using this computer for music video playback. There was no sound because of the unusual way that audio is processed by the nForce2 APU and outputted to Realtek ALC650 DAC. I intend to open another thread on this Asus board with audio issue. Point: Of several computers I tried, this MSI motherboard is the only mobo to fail to see and setup the two hard drives. Therefore, it is unlikely that something is wrong with the two hard drives.
    • binsonk
      • Apr 2014
      • 182
      It's a fact that AwardBIOS v6.00PG does not recognize the CPU, so maybe a BIOS upgrade is called for.
        • 30991
        audio problems on modern boards are because your linux is old.
        a lot of newer boards use stuff like azalia ( probably spelt wrong) soundsystem.
        these chips can detect if you have speakers or headfones or line out on any connector and autoconfigure to it.
        the kernel must handle this or the mixer will not work properly - specially if your using Pulse-Audio.
        • binsonk
          • Apr 2014
          • 182
          The real puzzler about that onboard audio issue is that a PCI sound card doesn't work either.
          http://www.hardwareanalysis.com/content/topic/4104/
            • 30991
            probably because the system wants to use the onboard sound first.
            if you go into the config and change the default audio driver to match the soundcard it will probably work.
            you can get similar problems with a gfx card on a board with onboard video once you try to use opengl or other 3d modes.
            • binsonk
              • Apr 2014
              • 182
              If you'll peruse that thread from Hardware Analysis, linked above, you'll notice that it's not a Linux issue per se. Lots of people having problems with this audio design. There's a lotta good ideas in that thread.
              • binsonk
                • Apr 2014
                • 182
                I'm having trouble with flashing the BIOS with the software provided. If you will be good enough to extract Award Bios version 1.A, you can read instructions and advise. I installed WinXP on a spare hdd connected to the system. I extracted the version 1.A download to a folder on the C drive, namely C:\test. Then I rebooted to Win98 DOS prompt, but could not find C: because C is ramdrive for the DOS files. Couldn't really find any drives from DOS prompt (because DOS can't see NTFS?). So I rebooted to Administrator command prompt, and ran AWFL859G.EXE and got a display of the desired Award Flasher, but it was inaccessible, with a note that Win NT, 2000, XP OS are not supported. So then I generated a (WinMe) floppy boot disk from WinXP, but could not find any drives from A: prompt, similar to Win98 boot disk, error: Invalid drive specification. I also tried to install Win98 on that spare hard drive, but after the first restart, I got an error that the program didn't have enough RAM to continue, even though I have 1.5 GB of RAM. Although instructions say I can do this flash from WinXP, I suspect that it will work only with Win98. Any opinions? Open to suggestions on how to proceed.
                http://us.msi.com/support/mb/K8MMV.html#down-bios
                Insufficient memory to initialize Windows 98
                http://support.microsoft.com/kb/184447
                • Dan81
                  SNES-powered
                  • Oct 2013
                  • 1865
                  • Romania
                  #28
                  Try using a USB pendrive:
                  http://forums.evga.com/How-To-Flash-...de-m15265.aspx
                  Just download the ZIP,make the bootable pendrive using the DOS files provided but DO NOT add autoexec.bat.Just add the flasher and the BIOS file.
                  Oh,and when flashing from USB try unplugging any PATA/SATA harddrive.The BIOS (Award BIOS)won't find anything else to boot from than the DVD-ROM and the pendrive,but it will boot the pendrive straight into the DOS prompt.
                  Method tested on my P4P800-VM with Foxconn 865A01-G-6ELS BIOS and works. Award BIOS booted my 16GB Hama pendrive straight away.
                  Main rig:
                  Gigabyte B75M-D3H
                  Core i5-3470 3.60GHz
                  16GB DDR3-1600
                  Samsung SH-224AB DVD-RW
                  Delux MG760 case
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    If you have a pyhsical floppy drive connected to the motherboard use this method. Download drdflash.exe from a reputable website and follow the instructions for creating a clean boot to dos floppy disk.
                    Then copy to the boot disk AWFL859G.EXE and W7142VMS.1A0
                    Now restart the computer with the boot disk you just created and run the flash program from the A: drive. If flash is good reboot.
                    • binsonk
                      • Apr 2014
                      • 182
                      Okay, I flashed the BIOS. Processor was identified as Sempron 2600. IDE detection was swift, accurate, complete. But I got a GRUB error 18. Legacy GRUB. It's suggested that the fix for this is in BIOS.
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        If you do not have a floppy drive you can also do this with an optical drive. You will need to make a boot cd using a image file to burn to a cd-r. And will need to burn a cd-r as a data disc with the flasher program and bios file on it. Do not transfer the files to the HDD.
                        • binsonk
                          • Apr 2014
                          • 182
                          I changed the date to today, rebooted, got the GRUB boot menu. The timeout counted down, and then the computer rebooted, instead of proceeding to desktop. Stuck in a loop of rebooting after GRUB boot menu. Can't boot a live CD, just hangs before files loaded to RAM.
                          • SteveNielsen
                            Retired Tech
                            • 2327
                            http://www.linuxquestions.org/questi...-error-437543/
                            • binsonk
                              • Apr 2014
                              • 182
                              In BIOS, I did a manual check on all drives, including optical. Went through the BIOS, looking for something. Didn't find much wrong. Rebooted. Voila, desktop for the first time. Seagate drive is shown as an unmounted desktop icon. Looks good, normal. Restarted, cold booted, just works.
                              • binsonk
                                • Apr 2014
                                • 182
                                Small issue with sound card. After reboot, sound takes about 15 seconds to kick in the first time. After it kicks in, sound works until next reboot. With a cold boot, I have to call ALSA sound wizard to re-install the driver, ES1988 Alegro-1 (rev10).
                                EDIT: A Yamaha card worked flawlessly, so it's fixed.
                                • binsonk
                                  • Apr 2014
                                  • 182
                                  @stj
                                  I just ran a live CD of Slacko 5.5 (kernel 3.2.33) on the Asus mobo A7N8X. I heard onboard sound for the first time. It's good to know there's nothing wrong with the board. I guess I will set this unit aside for now.
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    It's a bug with Windows 98, but Microsoft won't fix it and claim it's a feature and not a bug, lol.
                                    It appears that at least on a system I tested, there was a 768 MB limit and if exceeded, causes the Windows loader to give a false insufficient memory error message.
                                    (This includes setting the virtual memory to bigger than 768 MB, on reboot the Windows loader will refuse to load Windows with a false insufficient memory error message.)
                                    ASRock B550 PG Velocita
                                    Ryzen 9 "Vermeer" 5900X
                                    Arc A770 16 GB
                                    eVGA Supernova G3 750W
                                    Alienware AW3423DWF OLED
                                    • privato89
                                      Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                                      by privato89
                                      I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                                      Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                                      Let's begin:
                                      Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                                      03-26-2024, 06:37 AM
                                    • Luke Anders
                                      Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                                      by Luke Anders
                                      A few details about the laptop itself:
                                      Name: Lenovo Legion 5
                                      Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                                      BIOS Version: GKCN60WW
                                      EC Version: GKEC65WW
                                      Serial Number: PF39AQ7Z
                                      Board Model: NM-D562 Rev 3.0
                                      RAM: 16GB Installed, DDR4 (brand new)
                                      NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                                      I bought this laptop recently from eBay as a faulty device....
                                      10-12-2024, 05:13 AM
                                    • hinisa
                                      Xiaomi router freezes at boot after re-capping
                                      by hinisa
                                      I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                                      When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                                      After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                                      Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                                      07-08-2023, 05:58 AM
                                    • NolesFan
                                      Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                      by NolesFan
                                      Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                      10-24-2024, 06:36 PM
                                    • torchzack
                                      Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                      by torchzack
                                      Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                      I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                      Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                      08-28-2023, 07:42 AM
