Multilayer Ceramic Capacitors under chipsets??
  • stevo1210
    • Oct 2006
    • 4156
    Hello Everyone,
    I'm starting to notice something on certain motherboards. Why is it only motherboards that use VIA and SiS chipsets have Multilayer ceramic caps on the other side of the motherboard PCB.... odd thing is that they are directly underneath the Northbridge and southbridge.
    I have never ever seen an Intel Chipset motherboard with MLCCs on the other side of the chipsets.
    I have no idea about nvidia chipsets, but i'd really like to know if there are MLCCs on the other side of nvidia chipsets.... I'm planning to buy an nvidia nforce 4 chipset based motherboard and I want to know if they have MLCCs on the other side of them??
    Why do those chipsets need MLCCs on the other side??
    Multilayer Ceramic caps are a real pain for me because they can sometimes break off if I accidentally put the board against a table and slide it over etc. Then i have to solder them back on which is an even harder job.
    Thanks.
  • japlytic
    • Oct 2005
    • 2086
    Re: Multilayer Ceramic Capacitors under chipsets??
    The reason why the MLCCs are directly under the chipset is because of the close proximity required between the chip supply and ground pins for good transient suppression with MLCCs, especially with BGA packages or if other components are taking up the space around the package.
    • linuxguru
      • Apr 2005
      • 1564
      1) Intel probably has got well-designed Si in its Northbridges and Southbridges, probably with careful slew-rate control on all I/O buffers that allows them to keep Vcc transients under control even with the MLCCs located some distance away.
      2) Intel chipsets probably find their way into higher-end boards which are likely to use 6-layer PCBs including at least 2 power planes. That will offer some high-frequency transient suppression due to the distributed capacitance of the power planes. It's likely that most SiS and Via chipsets find their way into lower-end 4-layer boards.
      • stevo1210
        • Oct 2006
        • 4156
        What about nvidia chipsets?? do they also have MLCCs on the opposite side of the chipset??
        • linuxguru
          • Apr 2005
          • 1564
          A quick look at an old MS-6777 Nforce2 motherboard reveals that it has MLCCs below both the NB and SB BGA packages. BTW, that board has eaten up a couple of Thoroughbreds, but there's nothing visibly wrong with it - looks brand new.
          • chth96
            by chth96
            03-09-2024, 10:03 PM
            Surface Mount Fuses Fundamentals Datasheet
            TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
            TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
            10-07-2024, 06:07 AM
          • spleenharvester
            Ceramic capacitors/resistors - do suppliers matter?
            by spleenharvester
            I want to buy one of those SMD component books so I don't have to spend as much time searching my scrap boards for what I need, specifically ceramic caps and resistors as they seem to be what I spend most of my time replacing. But the only ones I can find are no name brands. Does manufacturer matter as much for SMD parts as it does with electrolytics or is the generic stuff likely to be fine?
            05-01-2025, 05:34 PM
          • Wolf1977
            dead transformer on ceramic oven
            by Wolf1977
            hi in ceramic oven the transformer is damaged
            and writes
            2x115v/2x12v/6VA 50-60hz ta105/f
            can you suggest me a compatible transformer ;
            i have found in 70 degrees celsius do you think is suitable for ceramic oven ;
            09-02-2023, 03:43 PM
          • Chaks
            Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
            by Chaks
            TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
            The specs says ...
            High antenna efficiency 868MHz ISM Band
            5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
            The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
            1. Should I Fix it with a glue.
            2. Should I fix it with a double side adhesive tape
            3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
            12-09-2024, 11:06 AM
