Is Memtest optimised for dual channel memory
  • gastorgrab
    • May 2007
    • 320
    The board i just recapped tests fine with the 1-Gig dual chanel memory, and the 1-Gig dual-chanel memory plus the 256Meg stick. When i run the system with just the 256 Meg stick it gives errors.
    And it only gives errors on even numbered passes.
  • gdement
    • Jan 2007
    • 690
    Re: Is Memtest optimised for dual channel memory
    That is odd. My first guess is that the board is automatically configuring the RAM speed, and when it sees the 256MB by itself it is trying to run it too aggressively. Maybe the other modules are steering your board towards more conservative settings.
    Also, are you sure the 256MB is actually getting used? Maybe it's being ignored in the presence of the other modules.
    Outside of that I can't think of a good explanation. The only wild guess I can think of is that the capacitance of the 1GB module is helping stabilize the adjacent 256MB just enough to make it marginally stable. That's a stretch though. When the 256MB is on it's own, your results show it still almost works but not quite, so we are dealing in the realm of tiny marginal changes.
    Are you sure it's not associated with a particular memory slot? Does the 256MB work in the same slot where it then starts glitching with the other modules removed? Some modules will be more sensitive to a given slot than others.
    I'm not sure what's meant by 1-gig dual channel. Is that 2x 1GB sticks? 2x 512MB? 1x 1GB module that's rated for use in dual channel?
    The even numbered passes thing is weird. How many loops did you run - are you sure it's not just a coincidence?
    • gastorgrab
      • May 2007
      • 320
      The system booted and ran a live MEPIS distro for hours and i never had a problem.
      Maybe the BIOS was hung. I could clear it and try again.
      Could the specs it was using be wrong because it got them from the Linux distro?
      • gg1978
        • Dec 2004
        • 431
        What version are you using?? I've run memtest86 on i865, Nforce, Nforce2, and AMD64 based dual channel systems with no issues.
        • gdement
          • Jan 2007
          • 690
          Memtest86 is deliberately trying to make it glitch, so it's more stressful than normal usage. If memtest is only barely able to produce a few errors, then you could probably run it for a long time without noticing a problem. But if you're having errors, something is probably wrong.
          • gastorgrab
            • May 2007
            • 320
            I checked and it says version 1.65, from http://www.memtest.org/.
            It could be the version i'm running.
            *** Enhancements in v1.70 : ***
            New Features
            Add new DMI polling feature
            Add Support for Core/Core2 Solo/Duo/Quad CPU
            Add Support for AMD K8 with DDR2 Memory
            Add Support for Intel CPU with 192/384 KB L2 Cache
            Add Support for FB-DIMM based memory (DMI)
            Add Detection for ALI CyberAladdin-T (M1644)
            Add Detection for Turion 64 X2
            Add Support for ATi Radeon xPress 3200
            Add Support for Intel i975X
            Add Support for Intel Q965/P965
            Add Support for Intel Q963/Q965
            Bug Fixes
            Force detection for AMD K8 with unknown chipsets
            It's a nForce3 board.
            • Maxxarcade
              • Jul 2006
              • 973
              What is the difference between Memtest86 and Memtest86+? Memtest86 is up to version 3.3 now I think.
              • PedroDaGr8
                • Oct 2006
                • 130
                Memtest86+ is a fork of the memtest tree. Basically, for a long time the developer of memtest86 stopped improving it. So some people took over development and released memtest86+. Now they typically are almost identical programs, with any releases in one being copied over to the other.
                • beauty123
                  • Jun 2007
                  Thank you all for this valuable thread!
                  __________
                  Ceramic Coatings
                  • Vspeed
                    Clevo P650RS-G no post with dual-channel memory configuration
                    by Vspeed
                    I have this Clevo laptop which is not booting when two RAM modules are inserted in dual-channel configuration.
                    I think that channel B is defective.
                    Can this be caused by the CPU? I ask this because there is a very visible discoloration in the CPU die. I can even spot with the naked eye, what looks to be straight lines, like tiny cracks in this spot. I notice this when replacing the thermal paste.
                    The laptop works fine with the ram configuration as single.
                    I don't have any experience with ram detection defects. Any hints on what to check?
                    01-02-2023, 11:54 AM
                  • mikey5791
                    Help on car amplifier only one channel works
                    by mikey5791
                    Hi all forum members,
                    Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                    My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                    08-06-2025, 10:36 PM
                  • eccerr0r
                    old X58 triple channel board... memtest86 memory speed?
                    by eccerr0r
                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                    06-28-2025, 09:06 AM
                  • dicky96
                    Hitachi V19B01922 Channel Tune problem
                    by dicky96
                    Hi Guys
                    I have a customer who has two Hitachi TVs in his bar, one is the model in the thread title and the other is a larger screen but has the same setup menu
                    He also has an LG TV, so three screens in the bar
                    I installed three Satlink ST-6503 DVB-T Modulators
                    This model https://www.aliexpress.com/item/32916553905.html
                    These connect to three satellite receivers via HDMI cables and then connect to a 4 way RF Amp that connects to the TVs on aerial cable. There is no incoming terrestrial antenna. I set the channel ID on the modulators to...
                    02-09-2023, 09:20 AM
                  • sima112
                    Marantz pm 6005 right channel not worknig
                    by sima112
                    Hi guys,
                    I need a help with my Marantz pm6005. It started to have weaker the right channel a few months ago, than it got back to normal and now it has lost sound completely on the right channel. At the final stage it was loosing the channel for a while and than it returned. After it has disappeared completely I could forced it back by unplugging the source form CD (which I normally use) to phone and back. It would then work for a few minutes and died again. Now it is possible power up and all function works normally (apart the right channel ) on all inputs, except the phone both channel...
                    01-30-2023, 12:11 PM
