I have a Dell Optiplex Gx 150 PIII PC. Its service tag # is 9MSMQ01. Can anybody tell me if this Dell uses a strange pinout on the mobo plug? Right now I have a plain aftermarket PSU in it and it runs fine. I'm going to buy a good PSU for it soon and I guess I need to know if I have a strange pinout.
Strange Dell Pinouts
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
"I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
John Paul Jones
There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
Rod SerlingTags: None -
Re: Strange Dell Pinouts
Found this page with the GX150 listed:
http://www.power-on.com/atx250dl.html
Also found this, listed as having adapters to change the pinout:
http://www.power-on.com/dell250x.html
So looks like the GX150 is ATX, but I would read up just to be sure. Too bad Dell had to do that with some models.
Anyone know if the Poweredge 1300 and 300 use a special power supply? They appear to be 24 pin. -
http://www.pcpower.com/products/powe...ector/dell.htm might offer the needed info.
This site should be bookmarked...i guess http://pinouts.ru/ Dell might be in there somewhere.?
Handy-dandy adapter. I'd prolly make my own..if ever needed http://www.endpcnoise.com/cgi-bin/e/...converter.htmlComment
because they want to keep it "in house" I suppose
A lot at one point or another do this....its a danger for those that assume that big names will follow conventional specs as laid down...think they have woken up a bit here but Apple is another to watch out for ...it may look like an ATX but its not wired to the standard
So anything from the big names in the past (and possibly present in apples case) I would check to be sure.
Dont relay on wire colour either as being a true guide to voltage etc
Yeah Gal the pinout RU is a good site
at lest someones tried to put them all together on one site for reference.
Just my thoughts
JP you did get My PM's ?You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...Comment
From what I understand, all of the newer Dell desktops are ATX standard.
That Russian site does have Dell pinouts. jonnyGURU offered that link last year.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by pickledeggHello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...10-02-2024, 04:54 PM -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
by SMDFleaDell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
Some models have a choice of 2 different firmwares, it depends on the dell SKU.
The SKU is in brackets (****)
EDIT: NVM65...-
- Loading...
<----Computer says I need more beer.
