Strange Dell Pinouts
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    I have a Dell Optiplex Gx 150 PIII PC. Its service tag # is 9MSMQ01. Can anybody tell me if this Dell uses a strange pinout on the mobo plug? Right now I have a plain aftermarket PSU in it and it runs fine. I'm going to buy a good PSU for it soon and I guess I need to know if I have a strange pinout.
    Mark Twain
    John Paul Jones
    Rod Serling
  • Maxxarcade
    • Jul 2006
    • 973
    Re: Strange Dell Pinouts
    Found this page with the GX150 listed:
    http://www.power-on.com/atx250dl.html
    Also found this, listed as having adapters to change the pinout:
    http://www.power-on.com/dell250x.html
    So looks like the GX150 is ATX, but I would read up just to be sure. Too bad Dell had to do that with some models.
    Anyone know if the Poweredge 1300 and 300 use a special power supply? They appear to be 24 pin.
    • Galvanized
      • Mar 2006
      • 468
      http://www.pcpower.com/products/powe...ector/dell.htm might offer the needed info.
      This site should be bookmarked...i guess http://pinouts.ru/ Dell might be in there somewhere.?
      Handy-dandy adapter. I'd prolly make my own..if ever needed http://www.endpcnoise.com/cgi-bin/e/...converter.html
      • pentium
        • Mar 2006
        • 2778
        *sigh*
        Why does dell refuse to conform to industry standards?
        Those are good links.
        Find Nedry!
        Check the Vending machines!!
        • starfury1
          • May 2006
          • 1256
          because they want to keep it "in house" I suppose
          A lot at one point or another do this....its a danger for those that assume that big names will follow conventional specs as laid down...think they have woken up a bit here but Apple is another to watch out for ...it may look like an ATX but its not wired to the standard
          So anything from the big names in the past (and possibly present in apples case) I would check to be sure.
          Dont relay on wire colour either as being a true guide to voltage etc
          Yeah Gal the pinout RU is a good site at lest someones tried to put them all together on one site for reference.
          Just my thoughts
          JP you did get My PM's ?
          • Galvanized
            • Mar 2006
            • 468
            From what I understand, all of the newer Dell desktops are ATX standard.
            That Russian site does have Dell pinouts. jonnyGURU offered that link last year.
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • pickledegg
              Dell Inspiron 7501 / Vostro 7500 (2020) - eDP connector pinout/panel compatibility question
              by pickledegg
              Hello. I have an Inspiron 7501 here, it's the same as a Vostro 7500 in some markets (no clue). I was looking to replace the LCD, the panels included with these models are terrible.
              I have the schematic and it is a 4 lane eDP port on the board but the pinout seems quite weird, my question is if anyone recognises this weird pinout and knows of any other Dell models that may use it or even any compatible panel models. I have the 40-40pin cable that was used for the models with touch but do not need touch capability, was just looking for a better quality screen and higher refresh to actually...
              10-02-2024, 04:54 PM
            • Akhlz001
              by Akhlz001
              09-20-2025, 07:15 PM
            • master3112
              by master3112
              07-29-2025, 01:55 PM
              Dell Thunderbolt Firmware
              by SMDFlea
              Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
              Some models have a choice of 2 different firmwares, it depends on the dell SKU.
              The SKU is in brackets (****)
              EDIT: NVM65...
              01-26-2025, 06:22 AM
