Laptop hard drive spindle motor?
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    I have a 2.5" laptop drive here my friend was using it as a external drive he left it plugged in one night by accident and when he went to power it up next time it would not work.
    I have tested the controller board on a bad drive and the disk spins up.
    I tested the ohms of the motor only 1 ohm less than the other motor.
    I applied 3vac to the bad drive motor and the platters shook back and forth as expected.
    On the drive with spindle motor issue no shaking at all felt through drive.
    so with ac applied spun whole drive and got the platters to shake but by the time i put controller board back on it had seized again.
    I have not opened up this drive due to dust and other contaminants that may enter the drive.
    My goal is to get it to spin up long enough to get data off it.
    My next attempt will be to heat drive to 50 deg C.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
  • spleenharvester
    • Mar 2010
    • 903
    Re: Laptop hard drive spindle motor?
    I don't know much about HDDs, but if you got it spinning using AC, is it worth just insulating the motor contacts from the PCB and trying it that way? Or does the HDD need some kind of info that the motor is spinning?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
      • 31070
      the motor is a multipole motor stepped by the pcb.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        and must run at a precise rpm and phase to work at all.
        i have done platter swaps but its very fussy and expensive.
        if you put the drive to your ear do you hear it try to spin?
        you might be able to give it a bit of help at the time you hear it try.
        be ready to copy off whatever is important as it may be your last chance.
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Can't get it to spin with single phase.
          My idea was to get itself to shake it loose.
          Drive does attempt to spin up but can't get the spindle to turn so gives up and then retries can't hear any rotation at all. only can hear the noise from motor drive.
          as i said pcb can spin up my failed head drive.
          I have a drive here with failed heads / preamp but would mean platter swap and head swap.
          My pc
          • Agent24
            I see dead caps
            • Oct 2007
            • 4973
            • New Zealand
            Stiction problem?
            http://en.wikipedia.org/wiki/Stiction#Hard_disk_drives
            -David VanHorn
            • joshnz
              • Feb 2011
              • 969
              • New Zealand
              Got the drive to spin up it is very unhappy I think the disk platter/s when it spun up were hitting the head ramp.
              Made a ticking
              Scrape noise that increase in speed as the drive spun up, once it got up to speed it went to find it's boot track And failed to do that, it only made two attempts.
              My pc
              • federalhouse
                **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                by federalhouse
                I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                **Background:**
                I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                **What I've Tried So Far:**
                1. I accessed
                08-01-2024, 07:03 PM
              • tmcw
                PC case - Hard drive rails
                by tmcw
                A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
                So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
                I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
                Now, the case is a CiT Gaming Case, and...
                05-22-2022, 12:04 PM
              • madura2010
                DAY11AM6E0 hard disk drive and optical disk drive not detected
                by madura2010
                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                i checked the connectivity of ribbon=good communication with hard and motherboard
                changed hard disk and checked=3f0 error persist
                sata power=+5v available
                Then checked data capacitors=all good
                Then checked data lines path connectivity to pch=all good
                reflashed...
                03-12-2023, 09:09 AM
              • ash91
                Hp pavilion 15 not detect hard drive
                by ash91
                Hello gentelmen .... this is my first post and sorry for my bad english,
                so my proplem is my laptop keep losing hard drive even if i but the
                hard disk in the cady (the box that can replace the dvd rom with hard disk)
                when i turn the laptop on the massage that said no boot media found pop on
                the hard disk is fine and to be sure i try another hard
                i also update my bios to the last update
                the 5 volt is present on the hard connector on the motherboard
                the dvd rom work fine when i but a windows dvd in it
                also when i boot from flash...
                06-07-2023, 01:45 PM
              • ChaosLegionnaire
                bug of the month: write caching setting for the hard drive in device manager
                by ChaosLegionnaire
                i recently bought a new wd re4 2tb with 2014 datecodes. when i got around to testing it tho in victoria hd tester, the write speed was very slow at 14 mb/s with a 256 sector transfer size. when i increased the transfer size to 1024 sectors, the write speed increased slightly to 44 mb/s. read speeds and sector verify speeds were fine and at normal speeds.
                so i just ass-u-med the drive's poor performance was due to it being an advanced format drive and i was using it on winxp. when i tried cloning my system disk to this wd re4 2tb drive and writing to it in linux, the write speed...
                10-06-2019, 01:39 PM
