Chipset problems???
+ More Options
Posts
  • brbpab94
    • Mar 2007
    • 22
    Chipset problems???
    is there a way to repair or replace a chipset on the motherboard?My daughter was on the computer and out of nowhere the moniter got no signal all the fans were still running.I tried a different video card and stil nothing.The msi 4 led stops at early chipset detection and stays there.
    msi k7n2 delta2 motherboard
    430 watt ps
    windows xp
    Please help
    Brian
  • gastorgrab
    • May 2007
    • 320
    Re: Chipset problems???
    And how do the capacitors look?
    • WNG
      • Sep 2006
      • 354
      I assume near the computer, as in the case? She knocked it over?
      Try resetting everything, memory especially. Unpower it, reset the BIOS via jumper, and try booting.
      “We the willing, led by the unknowing, are doing the impossible for the ungrateful.
      We have done so much, with so little, for so long, we are now qualified to do anything, with nothing.”
      • brbpab94
        • Mar 2007
        • 22
        the caps look good.I'll try unpluging and repluging everthing soon.
        • brbpab94
          • Mar 2007
          • 22
          is the bios and the comos jumper the same?
          • gastorgrab
            • May 2007
            • 320
            Yes.
            If your system doesn't have a jumper you could always remove the battery and hold a paperclip across the terminal for 10 seconds to achieve the same effect.
            • brbpab94
              • Mar 2007
              • 22
              She didn't knock anything over she was just on aim and looking at facebook.I tried everything you said and still nothing.
              • brbpab94
                • Mar 2007
                • 22
                they look normal.nice flat tops no bulges no ooze.
                • stevo1210
                  • Oct 2006
                  • 4156
                  430 watt ps
                  windows xp
                  Please help
                  Brian
                  What brand of PSU did that PC have??
                  I once had a Gigabyte GA-8i848P-G motherboard that did the same thing as that. Computer froze and blanked out on a word document then on restart there was no video on boot, but fans spun.
                  Found out that the Generic DEER brand PSU killed the southbridge because the 5v line pumped out too much voltage due to badcaps in the PSU.
                  • DynaxSC
                    Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                    by DynaxSC
                    Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                    For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                    06-10-2023, 11:30 AM
                  • jean luc ferre
                    laptop hp g72 b52sf screen problems
                    by jean luc ferre
                    on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                    the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                    i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                    i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                    06-07-2025, 03:27 PM
                  • qayyum786
                    *Use Full MOST COMMON I.C FOR LAPTOP YOU SHOULD HAVE IN STOCK*
                    by qayyum786
                    *MOST COMMON I.C FOR LAPTOP*
                    *YOU SHOULD HAVE IN STOCK*
                    *Charging IC
                    8682L OZ8682L OZ8682LN QFN-16 Chipset
                    OZ8681LN OZ8681L OZ8681 8681 8681L QFN-16 Chipset
                    ISL88731CHRTZ ISL88731C 88731C QFN-28 Chipset
                    ISL88731HRZ ISL88731QFN-28 Chipset
                    ISL6251AHAZ ISL6251A ISL6251 SOP-24
                    ISL95521HRZ ISL95521 95521HRZ QFN-32 Chipset
                    AXP288 QFN-76
                    AXP288C QFN-76
                    CD3301 CD3301RHHR QFN-36 Chipset
                    CD3301BRHHR CD3301B QFN-36
                    BQ24705
                    BQ24707 BQ707
                    BQ07A BQ24707A QFN-20
                    BQ715 BQ24715 BQ24715RGRR
                    05-26-2020, 06:13 AM
                  • clabr
                    Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                    by clabr
                    Need help to solve some problems with this laptop.
                    After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                    After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                    Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                    Before this had happened I observed some other problems:
                    When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                    12-02-2021, 08:09 AM
                  • sikocan
                    Lenovo X1 Carbon 9th Gen Black Screen
                    by sikocan
                    I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                    SN: PF3G1REP
                    MODEL: 20KW-00J1AU
                    PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                    Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                    06-24-2025, 09:01 PM
