Modding gone mad/crazy
Re: Modding gone mad/crazy
Dunno what the lag to display is like on those, but probably not playable if it's anything like modern capture cards. Unless cards back then had a kind of pass-through-to-VGA function, that signal is traveling all the way through the PC, which isn't really quick.Comment
By TV tuner card I was reffering to a mid-end capture card (like a Winfast TV2000 XP)that has at least:
-1 RF output connector
-1 S-Video connector
-1 Composite connector.
This is how my capture card is.For software to capture/view the output of S-Video and Composite I use DScaler and Winfast PVR2.There are also high end capture cards that use composite.(how else would you hook up a console to them then?RF quality on consoles isn't the best and I think those lack S-Video connectors but I don't really know)Last edited by Dan81; 04-16-2014, 01:18 AM.Main rig:
Gigabyte B75M-D3H
Core i5-3470 3.60GHz
16GB DDR3-1600
Samsung SH-224AB DVD-RW
Delux MG760 case
Aye Aye, captain
See that "230 VAC" sticker on the back of the PSU in the first picture? When present, it indicates that you are dealing with an extra extra extra cheap Deer/L&C. On such units, they are cutting corners in every possible way imaginable. That means no 115V/230V selector switch either. I mean, don't you know how expensive those are?
It also most likely has only a single cap per rail and missing PI coils. I've seen many of these. They are so minimalistic that you may as well consider them as "art" (or a miracle, if they run).Comment
am i the only one who noticed the idiot spray-painted the case with the side panels fitted.
look at the mess down the right side.
and it looks like there may be a fan in the top ahead of the psu pointing up - i hate that mod!Comment
Looks to me like a metallic color--the best way would be to paint the panels, together but he could have jambed the chassis, first to help in those areas.Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700Comment
Looks like the fan is pointing air downward, just like HVAC of many buildings...
The worst mod so far that I saw, was the little fan on the outer vent of the PSU! It counter-acts the PSU fan, IIRC... (the fan with the purple sticker)Last edited by RJARRRPCGP; 11-26-2016, 07:29 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747Comment
by sda sadHope this is the right place, someone can help me.
My laptop started having a really strange problem....
When I turn it on the fans start working at a crazy rate and with random breaks...
They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
The model of the computer:
Xiaomi Notebook Pro X 15 OLED (A30)
by marce002Hello
Need just to know how do you guys determine what the problem is, when we have some fluctuating volt, to discard a faulty TPS 51125 , or if the issue is after this IC.
CRAZY JUMPING
PP3V3_S5 = 0v to 3.33 v jumping
PPBUS_G3H = 12.4v to 12.48 jumping a little
PP5V_S5 = 2v to 5v aprox, jumping fast
P3V3S5_ENTRIP = crazy jumping from low volt
SMC_PM_G2_EN = jumping 0v to 3.3v crazy
STEADY
P3V42_G3H=3.39V steady
PP5V1_CHGR_VDD=5.06v steady
PPCHGR_DCIN= 18.29 to 18.31 jumping
Product ID: RZ09-0421
Motherboard: CH580
Bios File Size: 32,768 KB
Dear Forum Readers!
!!! MY RAZER BLADE...-
Channel: BIOS Requests ONLY!
Today, 05:52 PM -
by madan1Hi everyone.
Recently scored a dead amp from a mackie srm1801 subwoofer and after fixing it, now I'm thinking about a home cinema/party subwoofer project.
Most likely I will use a 15" JBL woofer, which I already have and a diy box.
After reading the mackie user manual, I noticed that it has a 40hz HPF (labeled as "36Hz BUTTERWORTH HPF" in the SM) to protect the speaker from low frequencies. Indeed this seems to be good idea for the intended usage - professional music subwoofer, but bad for movies, where one would expect to "feel" the SUBwoofer....-
by tay147895412Hi, I have an HP EliteDesk 705 G1 mini.
Model: HP EliteDesk 705 G1 Desktop Mini
Processor: AMD PRO A8-7600B
Motherboard PCB Marking: "APCB M3 94V-0" / "NPGC N-150TL"
BIOS Chip: Winbond 25PE20VG (2 Mbit SPI, 3.3V, 8-pin SOIC) and MX25L6473E 64Mbit (8MB), SPI NOR, 3.3V, 8-pin SOIC
Could someone help me with my bios , request:
unlock MPM/DMI with a BIOS patch/mod , dc tay42069 if someone could help me pls
Im gonna leave down below my working bios, if someone could mod it so it has the mpm...-
- Loading...
