Modding gone mad/crazy
  • Dan81
    SNES-powered
    • Oct 2013
    • 1865
    • Romania
    Re: Modding gone mad/crazy
    Originally posted by Ed Herdman
    Aside from heat or interference issues, the mod seems awful from a usability standpoint unless you are using something which outputs a 15KHz signal (i.e., Powerstrip or Soft-15KHz). That probably wasn't a deal at the time that mod was dreamed up, but today you are going to have to lug your PC over to a classic TV (better than moving the mountain), or add an upscaler to even connect it to many modern TVs or computer monitor, let alone get acceptable quality and responsiveness. The PlayStation is tiny - even the original models - and its best output is RGB (the PS2 adds component).
    Or simply wire the composite video to a old PCI TV tuner card and the audio to the line in of a old sound card.Much easier than having to use Powerstrip and such.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • Ed Herdman
      • Apr 2014
      • 31
      Dunno what the lag to display is like on those, but probably not playable if it's anything like modern capture cards. Unless cards back then had a kind of pass-through-to-VGA function, that signal is traveling all the way through the PC, which isn't really quick.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        and folks call me a computer ricer for hooking truck batteries to a ups and putting anderson powerpole panels and lighter sockets in the front!
        • Dan81
          SNES-powered
          • Oct 2013
          • 1865
          • Romania
          By TV tuner card I was reffering to a mid-end capture card (like a Winfast TV2000 XP)that has at least:
          -1 RF output connector
          -1 S-Video connector
          -1 Composite connector.
          This is how my capture card is.For software to capture/view the output of S-Video and Composite I use DScaler and Winfast PVR2.There are also high end capture cards that use composite.(how else would you hook up a console to them then?RF quality on consoles isn't the best and I think those lack S-Video connectors but I don't really know)
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            Originally posted by kaboom
            That "computer" looks like it's ready for "Deer season."
            Aye Aye, captain
            See that "230 VAC" sticker on the back of the PSU in the first picture? When present, it indicates that you are dealing with an extra extra extra cheap Deer/L&C. On such units, they are cutting corners in every possible way imaginable. That means no 115V/230V selector switch either. I mean, don't you know how expensive those are?
            It also most likely has only a single cap per rail and missing PI coils. I've seen many of these. They are so minimalistic that you may as well consider them as "art" (or a miracle, if they run).
              • 31002
              am i the only one who noticed the idiot spray-painted the case with the side panels fitted.
              look at the mess down the right side.
              and it looks like there may be a fan in the top ahead of the psu pointing up - i hate that mod!
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                Or, you could just call it an "AC Power Supply" because the connected components will be getting more AC than DC
                • Logistics
                  • Apr 2007
                  • 721
                  Looks to me like a metallic color--the best way would be to paint the panels, together but he could have jambed the chassis, first to help in those areas.
                  Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                  • alas3376
                    • Nov 2011
                    • 382
                    • BENIN
                    #29
                    that's very............................
                    • Cableaddict
                      • Nov 2016
                      • 8
                      The guy lost me at "DELUX"
                      ROTFL .....
                        master hoarder
                        • May 2008
                        • 12170
                        • Bulgaria
                        #31
                        Oh man, I have forgotten about this thread. Now that you revived it and reminded me of it, I am going to save all of the pictures on my HDD. They are just priceless!
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          Looks like the fan is pointing air downward, just like HVAC of many buildings...
                          The worst mod so far that I saw, was the little fan on the outer vent of the PSU! It counter-acts the PSU fan, IIRC... (the fan with the purple sticker)
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • sda sad
                            my Xiaomi Notebook Pro X laptop fans work like crazy for no reason
                            by sda sad
                            Hope this is the right place, someone can help me.
                            My laptop started having a really strange problem....
                            When I turn it on the fans start working at a crazy rate and with random breaks...
                            They can work for say 10 seconds and stop for 2 seconds and then turn on again for 5 etc...
                            And it's from 0 to 100%. I tried to install AIDA and did the processor chip test and the graphics did not exceed 70 degrees and the fans were not even close to working at the power they work randomly.
                            The model of the computer:
                            Xiaomi Notebook Pro X 15 OLED (A30)
                            04-23-2024, 09:55 AM
                          • marce002
                            Macbook Core i7 2010 a1286 820 - 2850A CRAZY JUMPING voltages
                            by marce002
                            Hello
                            Need just to know how do you guys determine what the problem is, when we have some fluctuating volt, to discard a faulty TPS 51125 , or if the issue is after this IC.
                            CRAZY JUMPING
                            PP3V3_S5 = 0v to 3.33 v jumping
                            PPBUS_G3H = 12.4v to 12.48 jumping a little
                            PP5V_S5 = 2v to 5v aprox, jumping fast
                            P3V3S5_ENTRIP = crazy jumping from low volt
                            SMC_PM_G2_EN = jumping 0v to 3.3v crazy
                            STEADY
                            P3V42_G3H=3.39V steady
                            PP5V1_CHGR_VDD=5.06v steady
                            PPCHGR_DCIN= 18.29 to 18.31 jumping
                            09-08-2021, 04:08 PM
                          • tay147895412
                            HP EliteDesk 705 G1 mini request for bios modding
                            by tay147895412
                            Hi, I have an HP EliteDesk 705 G1 mini.
                            Model: HP EliteDesk 705 G1 Desktop Mini
                            Processor: AMD PRO A8-7600B
                            Motherboard PCB Marking: "APCB M3 94V-0" / "NPGC N-150TL"
                            BIOS Chip: Winbond 25PE20VG (2 Mbit SPI, 3.3V, 8-pin SOIC) and MX25L6473E 64Mbit (8MB), SPI NOR, 3.3V, 8-pin SOIC
                            Could someone help me with my bios , request:
                            unlock MPM/DMI with a BIOS patch/mod , dc tay42069 if someone could help me pls
                            Im gonna leave down below my working bios, if someone could mod it so it has the mpm...
                            07-02-2025, 02:23 PM
                          • Stephan Mathers
                            EDMI ATLAS MK10 Electronic Meter Discussion
                            by Stephan Mathers
                            Greetings, new guy here but always interested in the crazy universe of modding
                            We just finished construction of around 25 vacation houses, all inside the same private area.
                            Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                            The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                            Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                            05-20-2025, 09:09 AM
                          • lapot2
                            The Best and Fastest BIOS Flasher for Modding Under $2
                            by lapot2
                            Recently, the Raccoon Flash Explorer programmer has appeared.
                            It allows you to flash BIOS chips from any device without installing programs and drivers, and also very quickly make small changes without a long rewrite of the entire memory to change a few bytes.
                            Very easy to use and intuitive, even a housewife can handle it.
                            You can use absolutely any system binary file editor (HxD, WinHex, etc…) on any operating system, the possibilities are not limited by the ugly built-in editor like other programmers.
                            It has full cross-platform support, works...
                            04-21-2025, 09:37 AM
